SOURCE: Microwave makes loud noise and does not heat. Smell of light burning
Chances are you have a bad magnetron.
If
it's within the magnetron portion of the warranty (usually 5-9 years)
but out of the original full warranty (usually 1 year), then your
manufacturer will cover the part cost, but not the cost to visit you or
the labor charge to do the work.
If
you or someone you know decide to look into it, we have critical safety
information, info on door switch diagnosis and replacement, and
disassembly information at our site, and our link is at our listing here on FixYa.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There
should also be a "mini-manual" hidden inside the unit behind the
control panel or hidden on the left side behind the grille, which is
very helpful when troubleshooting & testing.
We're happy to help you and we'd appreciate your
thoughtful rating of our answer.
SOURCE: GE Spacemaker XL1800(JVM1850CF001) - Loud Humming noise
You either have a bad magnetron tube (5 or 10 year parts warranty item through GE Factory Service 1-800-432-2737 or www.geappliances.com) or a shorted high voltage rectifier. I think the light being out is a secondary problem.
SOURCE: I have a Magic Chef microwave model mco153sf. The
HI. This is , indeed, an issue within the touch pad circuitry. it is damage, and will require replacement. I have located a replacement touch pad. Use the link below to access the touch pad. You can order the pad on-line, by clicking the link below.
CLICK HERE
SOURCE: Magic Chef MCO160UB Microwave only
Hi lindajcall,
There are several thermostats and thermal fuses inside the cabinet which
if bad can cause this to occur. To access them you need to remove the
cabinet and use a volt ohm meter to test the components. Unless you have a volt ohm meter there is nothing you can do.
Hope this helps.
Thank you for using FixYa.
