Question about Samsung SF-350 Plain Paper Inkjet Fax
Samsung SF-370 FAX MACHINE cannot send or receive faxes
Hi, I found this sit after trawling through google. My problem : I bought this machine 5 days ago to replace an ageing Phillips Magic 3 (but it worked). After coupling to phone line and power same as Phillips was, I cannot send or receive now and get send and receive error message. I have contacted Samsung about this with no solution yet, maybe you can help!!!
Posted by sizzy on
5 Related Answers
Anonymous
SOURCE: Samsung SF-3100 Fax Windows XP drivers for pc
the star button push hard and operae
Posted on Oct 13, 2007
Soulvisitor
Soulvisitor
  • 1113 Answers
SOURCE: Samsung SF-5100P
Machine will require fuser(hot bit at rear) replaced before it will operate, take to dealer for quote or if brave and 240v happy then buy a fuser and get your tools out rip off the covers and in the back you will find fuser assy.
link to service item fuser U.S.
http://www.samsungparts.com/part_detail.asp?catalog%5Fname=Parts+and+Accessories&product%5Fid=JC96%2D01621A&search%5Fmodel=SF5100
Posted on Nov 14, 2007
Anonymous
SOURCE: PHILLIPS MAGIC 2 USER MANUAL
Try http://www.queenborough.btinternet.co.uk/images/Philips_Magic_2_Fax_User_Guide.pdf
Posted on Feb 09, 2008
leroyal
Leroy Elliott
  • 2120 Answers
SOURCE: Samsung Laser Fax Machine SF 5100 Manual
What is your question?
Posted on Sep 05, 2008
SOURCE: samsung fax machine SF 560R states 'comms error'
When it has no paper then your all incoming fax documents save memory,Insert paper in cassette box and press start key or memory check button.
Posted on Dec 09, 2009
When did doris day die
Doris Day Born Doris Mary Ann Kappelhoff April 3, 1922 (age 94) or April 3, 1924 (age 92) [Note 1] Cincinnati, Ohio, U.S. Occupation Actress, singer, animal rights activist Years active 1939-present 1948-1973 (acting) Political party Republican 5 more rows
Doris Day - Wikipedia
https://en.wikipedia.org/wiki/Doris_Day When did doris day die Google Search
Dec 02, 2016 | Cars & Trucks
Where can I get memory cards for my Janome 9000
I own the MC9000. I bought the Magic Box plus and I download designs from embroidery websites and transfer them to the memory card (ATA PC card) that came with the Magic Box. It is rewritable so I just switch out designs as I please. I bought the Magic Box about 5 years ago and paid $200 for it. It is super easy to use. I hope this helps.
Aug 15, 2012 | Janome Memory Craft 9000 Computerized...
When did they stop making MC electric dryers? We have one that works like a charm so I was shocked when I found out they are not manufactured now.
The Magic Chef brand was a product of the Maytag company and Maytag was bought by Whirlpool about 5 years ago so the Magic Chef brand went away when Whirlpool took over
Aug 16, 2011 | Magic Chef Dryers
How do i add freon to system
Get a saddle valve like THIS ONE. Sand down the suction line or compressor ear and attach the valve. Connect hoses to the valve and add some freon. The low side pressure should be around
5 PSI.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 30, 2010 | Magic Chef Chest Freezer MCCF5WBX
Large print job saved in memory that I want to cancle
press MENU 4 5 7227 OK
to delete all fax memory. Other settings will remain in place.
Jun 08, 2010 | Philips PPF-531 Plain Paper Thermal...
Fan cool fridge working 3years bought new 2days ago starts blowin
Good day,
I don't understand your caption..........
Fan cool fridge working 3years bought new 2days ago... However, it sounds as if the compressor is trying to start and cannot.
If the machine is under 5 years of age, the compressor is under factory warranty.
There is a relay, capacitor, and overload which are connected to the side of the compressor after removing the back bottom rear cover.
These items could be removed and taken to an appliance parts house, where they would be glad to test them for you. Replace failed parts.
However, if it is under 5 years of age, I would recommend you call for factory warranty service. They may have to charge you for one of these parts, but since it could be a failed compressor, and not the starting components it is better to let them service it and maintain the balance of your compressor warranty.
Jan 29, 2010 | Jenn-Air JBL2086HES Bottom Freezer...
I am looking for a manual for phillips Magic 3 primo, can anyone give me a download link or copy. thanks omegauk
Hi d_rutherford
Click the link below, you'll see an installation instructions and manual which you can download.
http://safemanuals.com/user-guide-instructions-owner-manual/PHILIPS/MAGIC3-2%20PRIMO-_E
Hope this will work for you.
If this was helpful, please give a rating
Have a good day
luciana44
Nov 28, 2009 | Philips Office Equipment & Supplies
Phillips magic 5 voice dect fax
phillips magic 5 dect fax showing ''1 pending error''
cant remov e it
Nov 16, 2009 | Philips Office Equipment & Supplies
MAGIC CHEF 5 YRS OLD WONT AGITATE
Ours started doing the very same thing. I took the top off and found that a mouse had chewed a hole in the vacuum tube. I replaced it with a 3/16" ID small engine gas line hose I bought at local implement dealer. Works like a charm.
tjn
Jul 23, 2008 | Magic Chef CAV2000AWW Top Load Washer
Samsung SF-350 Plain Paper Inkjet Fax Logo
Top Samsung Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Muntejaya Ginting
Muntejaya Ginting
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
