Toshiba e330 Pocket PC Logo
Posted on Jan 29, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Toshiba Pocket PC e330 turns off immediately after disconnecting from AC power. Right after AC connection, everytime it needs re-setup starting with the screen alignment although the battery shows 100% charged. I might need the battery replaced. If so, where from I can have done it please?
Dick Monti
Level 3:
Dedicated:
Visited the website for 20 consecutive days.
  • Master 344 Answers
  • Posted on Jan 30, 2018
Dick Monti
Master
Level 3:
Dedicated:
Answers
344
Questions
0
Helped
448274
Points
1153
To get a new rechargeable battery for your e330, go here:
https://www.google.com/search?q=Toshiba+Pocket+PC+e330+battery&ie=utf-8&oe=utf-8&client=firefox-b-1
Also, is there a CMOS battery in that thing? If so, that might be your problem. Good luck.
5 Related Answers
Anonymous
  • 903 Answers
  • Posted on Sep 08, 2005
SOURCE: Reset my Pocket PC
A Reset of your Pocket PC is equivalent to "Restart" of a desktop computer. Carry out the Reset only in such unusual cases as when a button or tapping the screen does not respond. When your Pocket PC is reset, no data will be deleted. All stored information like Addresses, Contacts, Tasks or Programs are still stored in the Pocket PC memory. To Reset the Pocket PC, the power must be on. Then press the Reset switch with the stylus, then release. Your Pocket PC should function properly thereafter. If the functions cannot be restored, even after the reset button is pressed, Initialise your Pocket PC (refer to the FAQ article: How can I initialise my Pocket PC (Factory Reset).
Anonymous
  • 903 Answers
Anonymous
  • 903 Answers
SOURCE: Initialize my Pocket PC
When you initialize your Pocket PC, the factory default values are reset to the status as when you originally purchased the Pocket PC e330 or e310. NOTE: When you initialise your Pocket PC, all data stored in the memory is deleted. Your Pocket PC's initially installed programs are not deleted. Before initialization your Pocket PC, remove all storage cards. To initialize your Pocket PC, please follow the steps: Turn off the power Press the power button while pressing and holding the reset switch with the stylus. Then release the power button When a screen appears, release the reset switch When initialization is completed, the Welcome screen appears. Set up the system according to the screen as in the case of startup procedure.
Anonymous
  • 425 Answers
  • Posted on Sep 11, 2005
SOURCE: e330 crash
Use the reset button at the back side of your PDA. Keep pressing for a few seconds.
Anonymous
  • 903 Answers
SOURCE: Systemproblems with Toshiba e330
Hans is in a right way because there is no image to install. The system is installed at ROM in the PDA, so ROM means READ ONLY MEMORY, if it is read only you can't write on it! So there is only one way, switch the accu and perhaps it works properly after this troubleshotting!
Toshiba e330pocket pc
Please visit this below mentioned link to download the driver:
Toshiba e330 Pocket PC Driver
Unfortunately, this driver is not supported for Vista. But, it supports all other operating systems.
Thank you
2answers
Here is an easy proposal for troubleshooting. Did you push the ON/OFF button for a few seconds? Did you switch the battery and wait between switching a few minutes? If the pda doesn't work after this troubleshooting you should go to a Service partner because there could be a hardware problem.
GPS device not recognized
Firstly if you have a driver currently installed on your e330 for the GPS system, install it. (To uninstall - Start => Settings => System (Tab) => Remove Programs. One of the items in the list should be something like "PL-2303 USB Driver" Highlight it and click remove. You will probably be prompted for a restart to complete the process) Next, either reinstall the driver you got originally with the GPS receiver, or if you email me I will send you the one I have got. You will again need to restart your Pocket PC to complete the installation process. When you start your Tom Tom software, you may need to configure the GPS receiver. To do this, tap on the bottom right hand side of the screen, where the signal strength meter is and again tap on the signal meter on the next screen (top right corner) Next, click configure, specify your GPS hardware (I would presume you have a generic NMEA GPS?) click select, select your devices baud rate (again unless you know otherwise, and do consult your GPS receiver manual, I think the generic is 4800 and click done. Now you should have 4 options of how your GPS device connects to your Pocket Pc. The bottom option should say something like "COM4:" Select that one and within a few seconds the GPS Status should spring into life.
E330 crash
3helpful
2answers
My PC not turn on
The Toshiba Pocket PC e330 is shipped with an Enabled security feature, which switches off the batteries. In order to be able to turn on the unit, the Battery Switch must be in a battery "Supply" position. Please check if the Battery Switch is in a Stop position or Supply position. The Battery Switch can be found on the lower left edge of the unit, next to the "DC-In Socket". Please see the below diagram The Battery Switch supplies or stops power to the Pocket PC. When using the Pocket PC for the first time, slide this switch to the left with the stylus pen. If you have further questions, please refer to the Instruction Manual page 2-3 (20 of 105).
PDA e310, e330 or e740 together with Windows NT 4.0
The Toshiba Pocket PC's e310, e330 and e740 are designed to work together with Microsoft Windows 98, Windows 98SE, Millennium, Windows 2000 and Windows XP. Microsoft Windows NT4.0 is an older operating system, which does not work together with the Toshiba Pocket PC's e310,e330 and e740. Technical background: The Toshiba Pocket PC's have a USB and a Infrared interface to communicate with a Computer. Unfortunately, Microsoft Windows NT4.0 does not support USB nor Infrared. Windows NT supports a serial connection, but the serial interface is not available for the Pocket PC's e310,e330 and e740. Note: There is the possibility to synchronize a PDA over Network or Modem but the ActiveSync Software, which is responsible for the synchronization, will need a "first sync" to establish a "partnership" with the PDA. This "first sync" can only be done via USB.
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
