Cars & Trucks Logo
Posted on Aug 06, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Battery keeps going dead. Especially if car not driven for day or two. KIA ran checks of electrical system but found nothing. Am on sixth battery. Newest one only 3 weeks old and went dead over weekend.
  • ronward7426 Oct 10, 2008
    I have the same problem with a 2003 kia optima, and the auto door locks doesnt work
  • Jaseam Oct 19, 2008
    Battery sounds drained but eventually starts. Sometimes after shuting it off, there is a electrical buzzing sound from a part behind the fuel injection system.
Wes Manacop
Level 2:
  • Expert 61 Answers
  • Posted on Aug 16, 2008
Wes Manacop
Expert
Level 2:
Answers
61
Questions
0
Helped
33000
Points
128
It may maybe that the alternator doesnt give out the specific amount of electricity to properly charge your battery. you may have to run some tests on the alternator itself to see if it is giving out the proper current to charge.
2answers
Why is battery draining ford 2002 Taurus SES
Remove negative cable from battery, connect a test light to negative terminal, opposite end off light to negative battery post. ( let sit for 3 to 5 minutes). Then start pulling fuses, when the light goes out that's your bad circuit. God-Bless! Its worth a try.
1helpful
What can keep causing my battery to be dead
The charging system is not working. Common suspects include:
Loose wires or connections
Blown fusible links
Bad alternator
Also, if the charging system is working, and the battery lives as long as you drive it regularly, you may have a phantom power draw that is draining your battery while it is parked. You may have some accessory plugged in, such as a gps or a cell phone charger or alarm that is causing the current draw. If not, some part of your car may be drawing current when it shouldn't.
A proper electrical diagnosis is needed to reveal the source of your symptom. In the meantime, you can rig a cheap trickle charger to the car while it is not being driven while you find someone who can diagnose electrical systems. This may or may not end up being a costly repair, depending on what the tech finds during the diagnosis. 25354831-u40lsvyytnuesyuv3fbafhtd-5-0.jpg
1helpful
2answers
Battery tested
sound like alternator has bad diode allowing battery discharge
Won't start
sounds like a bad ground to your solinoid its not the starter try tapping the solinoid
A couple of weeks ago I went out to start my Kia Sedona 08, however, found it was dead. I connected up battery to another car and jump started first time (and ran it for 30mins). It then started fine for...
Sounds like a battery to me. The cold doesnt drain the battery it just makes it more difficult to produce enough energy to crank the car. If the battery is weak already, the cold just makes it worse. Replace it and move on!
1helpful
New battery keeps going dead could it be my fuses? 2004 kia sorento dealer checked electrical, alternator - all good how do i check fuses?
circuits will drain batteries not fuses you will need to have someone check the draw on each circuit in the vehicle. start with any recent electrical installations. keep keys out of the vehicle then remove negative battery terminal and then use 12 volt light bulbin between the battery and cable. bright light means power draw. remove fuses one at a time till the light goes out. the circuit that makes the light go out is bad.
New battery keeps going dead kia 2004 sorento
buy cheap tester check alt for output 14-16 volts, check for blown fuses
2answers
Top Kia Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Kia Expert? Answer questions, earn points and help others
