Question about Hobart D300-6036 Mixer
Ive got an industrial dough mixer, model no:SM 201. when the machine is empty then it runs perfect but as soon as the dough starts getting stiff then the machine immediately stops.its like the motor does not get power..not even a single noise.But as soon as i drop the lever where the bucket goes down then everything works again.What can be the problem? From Mr Mac
Posted by mcgregor476 on
5 Related Answers
Anonymous
  • 640 Answers
SOURCE: hobart 60 quart mixer
the motor protection board is doing its job.you should only use 1st speed to mix pizza dough.im a hobart technician and service these mixers all the time.let me know
Posted on Jan 28, 2008
Mark Egan
  • 1214 Answers
SOURCE: Hobart H600 wont shut off
Sounds like the side switch is the latching switch for the circuit, and you are right about it's operation. I strongly suspect where the wire comes off that slide switch and goes to the coil, there would be 2 wires at that connection, where the other one leads to one side of the start switch.
Looking forward to your reply. It will be easier to email the schematic that you come up with to me. Be sure and tell the the starter manufacturer that is installed as well.
[email protected]
Posted on Feb 15, 2009
Anonymous
  • 640 Answers
SOURCE: Dry clumps in pizza dough
Throw a quarter in the bowl,put the hook on and raise the bowl.Turn the mixer on and the hook should just skim and move the quarter.This is to check that the hook clearance to the bowl is right so the dough on the bottom of the bowl rides up the hook.I'm a hobart tech and repair these units often.Let me know.
Posted on Feb 21, 2009
Anonymous
  • 640 Answers
SOURCE: Hobart H-600-T Mixer Shuts down while mixing bread dough
What you replaced were the contacts on the overload,correct?These 'heaters' look like springs?If so you have other issues.I'm a hobart tech and repair these mixers often.Are you mixing pizza dough?
Posted on Mar 07, 2009
Anonymous
SOURCE: Hobart N-50 mixer clangs on 1st and 2nd speed
CE is the marking that shows its european conformant.  I think the difference is mostly in terms of the no volt interlock switch.  This means the KA style N50 bowl won't work with the CE models - too low.
Posted on Mar 17, 2009
When mixing cookie dough my kitchenaid mixer bogs down when the dough gets thicker .. replaced the brushes already and runs better but still bogs down .. does it need a new motor?
When using the dough hook the speed should be no higher than 2. That said, there is a limit as to how thick a dough the Artisan mixer can handle and you may well have reached that. Under these circumstances it is normal for the motor to slow down.
If the stress becomes too great, the worm (follower) gear will fail protecting the motor from burning out.
The Service Manual covering your model can be found at:
http://www.kitchenaidparts.eu/documents/pdf/service-manual/classic-svc-manual-new-email-version.pdf
The mixer runs for 4 seconds and then trips
other large equipment on same breaker, or dough too stiff in the bowl
2helpful
Hobart A-200 mixer gets hot and weak. Motor housing gets too hot to keep your hand on it. Service tech told me the motors usually don't go out. What other problem could it be?
I'd say you're most likely overloading the mixer. This mixer, and others similar in size, are frequently overloaded by people making pizza dough. If you are making dough, keep in mind the A-200's capacity is 9 lb. of 40% A.R. pizza dough, mixed for 5 minutes maximum. If you need to mix longer, the batch must be cut down even smaller, but I don't even know if you're mixing dough.
Try running the mixer unloaded (i.e. nothing in the bowl) for ten minutes or more and see if it gets hot. If it still gets hot, the motor's start circuit (varies depending upon age of the A-200; Hobart used numerous motors in the A-200 over the years, incorporating different starting circuits) most likely has problems. If it doesn't get hot when operating unloaded, then you're probably overheating the mixer by overloading it.
3helpful
2answers
Dough hook stuck immediately after use
I just got my dough hook unstuck! The problem was the bolt at the top of the dough hook. This bolt is used to adjust the height of the dough hook. This bolt came loose while mixing and went up towards the mixer. The force of the spinning actually tightened this bolt against the mixer so when I tried to release the dough hook by lifting and turning, it wouldn't lift. The bolt was in the way! The solution is to loosen this bolt. You'll need a thin wrench that's about 15 mm. You can test loosening this bolt on the other attachments since they loosen in the same manner. You'll have to bend the white shield down slightly to get the wrench in there. It's a tight squeeze even with a thin wrench. Hold on to the lower end of the dough hook and turn the wrench counterclockwise when looking down at it. Once you loosen the bolt, you'll be able to turn the lower portion of the dough hook to lower it. Then you can lower the bolt further. Once you have them low enough, you can remove the dough hook like normal - lift and turn. Sure beats boxing it up, shipping it for repair and paying for shipping both ways!
1helpful
Loud and throws flour all over
Do you find the motor running too fast at the lowest setting? Then you need to bring it to someone to adjust the low speed setting. If you are preparing double batches you are over loading the mixer and/or using too fast a speed setting to mix. Don't try to double recipes just because the bowl can handle the volume, the motor cannot and will not last very long if stressed mixing dough frequently.
1helpful
Dough mixer not working at all
it sounds like the mixer was overloaded and therefore broke a shaft,gears or sheared keys.
Hobart D300-6036 Mixer Logo
Top Hobart Food Mixers Experts
Ross Keen
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
