TRANSMISSION DONT HAVE DIP STICK,YOU HAVE A CHECK PLUG LOCATED UNDER TRANSMISSION NEAR THE PAN ADJACENT TO THE ENGINE OIL DRAIN PLUG.CHECK PLUG IS A METRIC 11M OR 12M METRIC BOLT.TO CHECK FLUID CAR HAS TO BE LEVEL AND ENGINE RUNNING.WHEN YOU REMOVE CHECK PLUG, IF FLUID POUR OUT YOU HAVE TOO MUCH TRANSMISSION FLUID IN TRANSMISSION, IF FLUID SLOW DRIP YOU HAVE ENOUGH FLUID IN TRANSMISSION, IF NO FLUID DONT DRIP OUT WHEN CHECK PLUG REMOVED,ADD A PINT OF TRANSMISSION FLUID AT A TIME.YOU POUR FLUID AT TOP OF TRANSMISSION UNDER THE HOOD,YOU WILL SEE A RED VENT FILL CAP, REMOVE CAP, YOU NEED A VERY LONG FUNNEL TO POUR TRANSMISSION FLUID IN THE TRANSMISSION. IF YOU HAVE TRANSMISSION SHIFTING OR SLIPPING PROBLEMS,MOST TIME TRANSMISSION DUE FOR FILTER AND FLUID CHANGE IF YOU AT THE 60000 MILES TO 120000 MILES TIME FOR FLUID AND FILTER CHANGE.
Ther isn't one, there is a plug on trans used to check and fill kind of like a manual trans.
If this is a stick shift then you need to pull the speed sensor out and the fill level should be to the bottom of the speed sensor gear.
Drive the car for several miles or until the engine has reached its normal temperature, as indicated by the temperature gauge. Position the vehicle on a flat surface, shift the transmission to the "Park" position and apply the parking brake.Raise the hood and allow the vehicle to idle.
Withdraw the transmission's dipstick. The dipstick features a T-shaped handle with the words "Trans. Fluid" stamped into the top of the handle.Wipe the dipstick clean of any transmission fluid with a clean shop rag. As the vehicle is driven, transmission fluid may splash onto the dipstick, resulting in a false fluid level reading.Insert the dipstick into its tube until the handle rests securely against the top of the tube, then withdraw the dipstick and note the fluid level. The fluid level should be at or just below the "Warm Full" mark stamped into the dipstick. If the level is low, fluid must be added.Add Mercon V transmission fluid in small increments to avoid overfilling the transmission. Insert a funnel into the top of the dipstick tube, then pour the transmission fluid into the funnel, periodically checking the fluid level on the dipstick.
Pull out the dipstick.
With the gearshift in Neutral or Park and the parking brake on, let your engine run. Be sure the engine is warm when you pull out the dipstick. (Don't turn off the engine.)
Check the fluid.
Dip the tip of your index finger into the fluid on the dipstick and rub the fluid between your finger and the tip of your thumb. The transmission fluid on the dipstick should be pinkish and almost clear. If it looks or smells burnt or has particles in it, have a mechanic drain and change the fluid.
Wipe the dipstick with a clean, lint-free rag; then reinsert it and pull it out again.
If the transmission fluid is clear but doesn't reach the "Full" line on the dipstick, use a funnel to pour just enough transmission fluid down the dipstick tube to reach the line. Don't overfill!
