Question about White Sewing 1766 Mechanical Sewing Machine
Singer sewing machine - hand wheel
On my singer the hand wheel has a smaller wheel inside the larger hand wheel that you push/pivet to release the hand wheel so you can use the bobbin winder, which I have done successfully.
I then snapped the smaller wheel back into place and away I go. The needle moves up an down for about 10-15 stitches and then the smaller wheel pops back into the bobbin winding position. I've used this machine many, many times and never had this happen.
And, of course, I'm right in the middle of a huge sewing project. Can you help?
[email protected]
Posted by kdsauer on
  • White Sewing Master
  • 18,342 Answers
Posted on Apr 14, 2017
5 Related Answers
Anonymous
SOURCE: Bobbin won't wind
I have checked the gears underneath and see no missing teeth for the bobbin part. The bobbin "seat" does raise, but does not engage. Thanks
Posted on Dec 23, 2007
Anonymous
  • 323 Answers
SOURCE: my singer athena 2000 won't
I think if you watch the hook as you turn the wheel you will see that it is not moving.If it's not moving it can't pick up the thread or sew or wind the bobbin. If you really like this machine you can take it to a technician who is going to tell you you have a broken gear.Always have them replaced in pairs. On this machine there are 2 gears( 1 Pair) on the left and 2 gears( 1 Pair) on the right. If the machine is making buzzing noises, replace the machine instead of the gears. Singer makes a nice machine which sells for around $300 which will do more than the one you have and it is easier to use. Look at Model 7467. I sell quite a few of these and they don't give me or my customers problems.
sewman7
Posted on Aug 29, 2008
dupina
Theo du Preez
  • 110 Answers
SOURCE: Bobbin won't wind Singer 7422
Your problem lies with the main shaft that is to tight to release the bobbin winder mechanism, because of old grease and oil becoming sticky. A short term solution will be to remove the needle, in order not to hurt you, and then hold on to the needle bar with your left hand, while engaging the bobbin lever with your left hand. This will prevent the main shaft to rotate and your winder should work. In the long term, take it to your dealer to clean the oil and grease. You will not be able to open the machine casing yourselve, as you might damage the casing and or electronics.
Posted on Nov 11, 2008
Page Gettman
  • 30 Answers
SOURCE: Hand wheel spins without moving the needle
I used to have an old Bernina that had an inner and outer hand wheel. Loosening the inner wheel disconnected the needle bar from the motor so you could wind the bobbin without running the needle up and down. It sounds to me like your machine has the same feature, but resistance on the needle makes the inner wheel loosen up. I don't know whether wrenching on it as tight as you can would be enough, or whether this is a symptom indicating that there is something loose internally in the connection between the inner and outer wheels. Good luck!
Posted on Jan 24, 2009
Anonymous
SOURCE: Singer 6267 self winding bobbin winds around shaft under
I just figured out why my bobbine was winding on shaft instead of on the bobbin. first of all make sure the bobbin is setting up high enough, top of bobbin needs to be a fraction higher then the bobbin shuttle, next check to make sure there are no burrs on the bobbin, then make sure that the thear is catching in the groove (**** in top) of the bobbin. In order to get mine to wind i had to lett the tread go down and then slip the thread in the groove. also remember to leave the pressure foot up do not put it down. let me know if this helps.
Posted on Mar 08, 2009
Singer One Sewing machine purchased new about 6 months ago..
You may need the assistance of a store than works on sewing machines. Or - try Pushing really hard to re-engage the hand wheel. Good luck. PS - do not let the repair guy adjust your machine. Most men do not sew, ergo they make a mess of all adjustments.
Dec 14, 2017 | Singer Sewing Machines
SINGER TOUCH N SEW 771
Use the wheel at side of machine and gently push back and forth it should release reverse lever
Mar 04, 2015 | Singer Sewing Machines
How do I add thread to the bobbin on Singer sewing machine 3114?
Your repair shop will have to fix the handwheel, but you can still wind your bobbin. UNTHREAD the machine completely, and take the needle out. Set up your thread to wind the bobbin, and push the winder over until it clicks. Wind your bobbin. I don't have a picture of your model; this is just standard.
Feb 23, 2015 | Singer Sewing Machines
Singer CG500 Needle hits the needle plate. Needle was replaced. Verified needle in correctly. Tried hand wheel - still hits. Machine has yet to be used!!
Unless you need all the bells and whistles to sew get you a pre-1930 treadle or handcrank. I have 2 electric Singers, 1947 model 66 and 1948 201-2 both with attachments. Also I have 1903 Singer handcrank made in Scotland. The plastic new one just don't have the ability to hang in there .... All my pre 1930 Singers sew... I love them!
Apr 17, 2014 | Singer CG500 Mechanical Sewing Machine
Hand wheel not moving
sounds as though the hand wheel at the right end of the machine needs tightening by hand to engage inner workings. Hold the larger wheel with one hand tighten the smaller wheel.
Dec 07, 2013 | Janome Memory Craft 3000
Why is my singer SEWING MACHINE prelude HAND WHEEL RESISTING
Make sure the bobbin winder is in the position away from the bobbin stopper. When you fill a bobbin, you have to push the "spindle" towards the handwheel. If you do not push the "spindle" back into position (away from the handwheel), the wheel will remain locked.
Jul 18, 2012 | Singer 8280 Mechanical Sewing Machine
Hand wheel turns bobbin but not presser foot
it needs to be checked by a sewing machine repair shop to see what wrong with it
Jan 28, 2012 | Singer 3116 Simple
My needle keeps moving while I try to wind my bobbin
hi there,
the hand wheel and clutch should be disengage so that needle will not move also w/ the bobbins,doing this is hold the hand wheel then grip hold also at the center hand wheel.rotate center counter clockwise to release clutch.other type is push and pull hand wheel.any of them,try to run machine if needle is move again.cheers have a nice day don't forget to rate me.
Apr 07, 2009 | Singer 7436 - INGENUITY
White Sewing 1766 Mechanical Sewing Machine Logo
177 people viewed this question
Top White Sewing Sewing Machines Experts
radcal
tsalagi152
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
