Hello James Roadkin,
Sounds like you have it properly surrounded...
but the PART 5309918806 does NOT go with your
refrigerator... GHSC39ETJB2...
(rather part number 241547901)
I have pulled up an appliance store...
They provide excellent support and VIDEO
guides for the adventurous DIY (do-it-yourselfer)
home appliance repair persons...
Looking good...
appliancepartspros:
http://www.appliancepartspros.com/frigidaire-switch-light-lamp-241547901-ap3562983.html
Check out their video...
and then their competition...
Repairclinic: (look at their testing video)
Door Switch 241547901
Partselect
Frigidaire 241547901 SWITCH LIGHT LAMP PartSelect
All the parts are essentially the same
(let the price/guarantee be your guide).
Hope this helps
Carnac the Magnificent
SOURCE: frigidare
only 5 years is important, sounds very much like you have a bad compressor, It's trying to start asn cant so it shuts down(therees the noise your hearing. 5 year manufacture warr. so see if you can find your bill of sale. and give manufacture a call
SOURCE: INTERIOR FRIG LIGHT
replace the switch before the seal, nothing wrong with gasket., you may need to raise the refrig door a bit by , remove the door and install a small spacer to raise the door slightly for better contact
SOURCE: freezer door opens
its air pressure between the wo doors that cause it to open the freezer door.take some soapy water and clean the sels aroundboth doors to see itf thet dosent help use dish soap and a little water to clean the seals with it should stop it
SOURCE: Freezer not cooling
there is an external fan near the compressor usually at the bottom of the unit on the back side and if this fan does not run the freezer will not freeze. u can also look for a defrost timer located near the bottom of the refrigerator with the door open or just under the freezer in the refrigerator compartment. It will look like a plastic screw that can be turned only one way with a flathead screwdriver because of its design. Some times these timers just get stuck and will work again if u rotate it with a screwdriver one revolution or two. Allow an hour to see if freezer works after tuning. Please rate me
SOURCE: Fridge worked perfect for 3yrs, one day i took
you may have a big problem not sopose have the door open so long better you call service
