Question about Canon PIXMA MP780 All-In-One InkJet Printer
Printer idle Hi: I want to print something but the printer dialogue box says the printer is idle, even though the power is on, the printer is ready to go, the printer is recognized in the dialogue box, the cable connecting the printer and the computer is properly installed and the printer is ready. Help! I couldn't find this problem being addressed on this website or in the Pixma MP780 user manual that came with the printer. Thanks.
Posted by Msterry58 on
  • Msterry58 Aug 06, 2008
    Hello:
    Thank you so much for responding to my inquiry. I don't know what happened, but it is printing now. Thanks.
  • Tim Babcock
    Tim Babcock May 11, 2010
    That could be normal use. The printer could have a sleep mode on it as well.
    Are you able to print to it?
5 Related Answers
old marine
old marine
  • 2281 Answers
SOURCE: Lost installation disk for canon pixma mp780
Go to this link. Wait a few seconds for all the files to load. Select your OS in the box, then wait a few more seconds, and you will see the drivers displayed.
You will need to download and install both the driver and the MP Navigator (under the Software heading). Click on the link and follow the instructions to install.
Posted on May 20, 2008
pankaj_dic
pankaj rautela
  • 1252 Answers
SOURCE: Canon Pixma iP1600 Printer problem
this is the service error download canon chip resetter utility, then reset your printer , download IP resetter utility
Posted on Nov 14, 2008
sagarjd
JD Kiran Sagar
  • 95 Answers
SOURCE: Printer idle
hI,
You can try to make the printer ready by right clicking on the printer icon and selecting the option ready.
Here is the patch whcih you can try to fix the issue.
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-56143-2&cc=us&lc=en&dlc=en&product=1141647
Regards,
Sagarjd
Posted on Nov 21, 2008
Anonymous
  • 330 Answers
SOURCE: IDLE
check the print quee if is there delet the print quee then try .......if its not working means
uninstall the printer driver and reinstall again
Posted on Oct 06, 2009
Anonymous
SOURCE: my canon pixma MP145 showed E5 and wont print anymore
I have been using black and color ink refills for sometime now, but am unable to use my printer since last week. It shows E5 and on the dialogue box is stated that it cannot recognize the COLOR.
Posted on Jan 20, 2010
My dell 3100cn won't print, even though it says the printer is ready
look inside of printer.see if something is pulled or unpluged. see if there is ink and paper inside.
Jun 20, 2013 | Dell 3100cn Laser Printer
Hi, all i want to do is install a printer without the software thank you Jay.
You can add a printer though the print wizard built into Windows XP.
1. Open the add printer wizard.
2. Then select local printer... even if it is a network printer
3. If you are not using a USB cable to connect you printer, uncheck the box next to "automatically detect plug and play printer". --->click next. If you are using a USB cable Skip step 4.
4. Your selection on the screen depends on how the printer is connected. In you are using a parallel cable, you will selct the radio button next to "Use the following port" and select LPT1 from the dropdown box. If your printer is a network printer, you select "create a new port" and Standard TCP/IP port from the dropdown box. Then, enter the printers IP Address in the next dialogue box
5. When you come to the install printer software screen click "have disk" and navigate to your machine specific .inf file
6. Enjoy your printer without the annoying bells and whistles
Oct 29, 2010 | Epson Stylus CX5400
Can I make this a wireless printer?
You can connect the printer via USB to a single PC or via Ethernet on a network. Though it doesn't have wireless capability built-in, you could also connect it to a wireless router or a print server for a shared wireless connection.
Dec 06, 2009 | HP Photosmart C5180 All-In-One InkJet...
IDLE
Oct 06, 2009 | HP Photosmart C4180 All-In-One InkJet...
Printer says out of paper when the tray is loaded
1. Shut the printer down
2. disconnect the power cable and network cable if you have one
3. wait 5 minutes
4. put the cords back in
5. power the printer back up
Good Luck !!!!!
Jul 21, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
How to print in black and white only
Goto Control Panel > Printer and Faxes > Right Click > Printer Prefernces
(on your desired Printer)
A dialogue box will appear, now from here every printer got a bit different tabs.
Even though its too easy to find somthing like "color".
Under such tab you will find options like
  • Color Printing
  • Gray Scale
  • Black Ink Only
  • Toner Saver mode (For Lasers)
So select the Black & White option, and its done.
Do Rate Me!, If helpful.
Jul 17, 2009 | HP Officejet Pro L7680 All-In-One Printer
Does not print. Asks for output file instead.
The default printer is set to be "file". Here's what you must do:
- Go to printers dialogue box and right click on your printer name and selectd "Set s default printer"
 - Right click on printers name and chose Properties. then look for a check box saing something like "print to file" and unchek it.
This sould resolve the problem.
Best regards
Nov 12, 2008 | HP DeskJet F380 All-In-One Printer
Printer idle
hI,
Regards,
Sagarjd
Oct 13, 2008 | HP Photosmart C4180 All-In-One InkJet...
I Purchased new HP notebook - with vista operating system today. Loaded driver for my Konica Minolta 2530 DL from cd provided with printer. Indicated it was successfull. The printer indicates ready and...
that's a printer settings issue...when you open the print dialogue..go to print preferences, and make sure you are selecting the printer, and NOT print to file
Apr 27, 2008 | HP DeskJet F380 All-In-One Printer
Canon PIXMA MP780 All-In-One InkJet Printer Logo
373 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Ekse
