Question about Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony Wega Triniton KV-32FS100 TV For the last week my TV has been going to a black screen for 10 secondsor so then the picture returns. It has been continual. Last night itstopped going to black screen, but now the standby light flashes 5consecutive times and the color went haywire. A lot of red andeverything that is suppose to be black is green. I did a soft and hard reset with no success. What's wrong and is it worth fixing? Bought new in November 2002.
    Top Expert:
  • Sony Master
  • 76,376 Answers
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Posted on Jun 01, 2017
5 Related Answers
Anonymous
SOURCE: Sony WEGA KV 32FS100
No picture. Standby light blinks 5 times. Tried unplugging and restarting. Same problem
Posted on May 09, 2008
welcomejee
Shahid Electronics
  • 10594 Answers
SOURCE: Pop sound, flashing standby light, blank screen
How many times this light flases in TV?
Posted on Aug 01, 2008
welcomejee
Shahid Electronics
  • 10594 Answers
SOURCE: tv turning off
Hello
Sony FD Triniton Wega KV-36XBR400 service manual has no info for 11 times flash. It has info up to 7 falshes. Please count again. Error codes are in below pictures...
Regards,
Posted on Aug 27, 2008
Anonymous
SOURCE: set up Sony Wega TV on Video 2 for a Wii system
In the set up screen: Video reset ports and activated them individually to allow the TV to recognize the game and the DVD players...
Posted on Dec 28, 2008
Anonymous
SOURCE: digital tuner?
Good question, Mike. I wondered about my fs210 model, too, and I found the answer at a Sony tech-support site.
1. Go to: http://esupport.sony.com/US/perl/select-system.pl?DIRECTOR=DOCS
2. Enter your TV's model number, which, in this case, is: kv-32fs100 (and then click on Continue).
3. At the resulting page, under "Support by Type" in the left margin, click on "News & Alerts."
4. At the next page, click on: 04/02/2008: Critical: Is my Sony® television ready for the Digital TV (DTV) transition?
5. Your TV and mine are analog, but scroll down the page mentioned in #4, above, to see all of your options.
Consumers can determine whether any Sony TV is digital, just by entering the model number and following the steps listed above. ~ Kind regards, Gilda M. (replied 1/23/09)
Posted on Jan 23, 2009
I have just bought a used SONY TRINITON KV-36FS70 without a manual. My problem is that on the top left of the screen I have a circle with an arrow going in to it and on the right I have 1 AV 1 and I can't...
hello use your remote control to delete the display...on your remote control there is a particular button labeled display just press the button and the display will dissapear press it again then display will appear again..tnx
please vote for my help tnx.
Jun 04, 2010 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Tv turning off
Hello
Regards,
Aug 27, 2008 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
Sony FD Trinitron Wega model KV-34BR800
For the last week my TV has been going to a black screen for 10 seconds or so then the picture returns. It has been continual. Last night it stopped going to black screen, but now the standby light flashes 5 consecutive times and the color went haywire. A lot of red and everything that is suppose to be black is green.
Aug 01, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony Trinitron KV-32S40 32" TV problem
This is a simple and common problem. The solder joints on the vertical output IC have cracked loose. I actually did a housecall on the exact same set with the exact same symptoms this morning! A good tech will resolder the pins of the vertical output IC and all other major solder joints on the main board and the set will play fine.
Sep 30, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony TV
your problem is due to video or luminance section. remember it is loose contact only in that section or print loose. please check 1 crt base loose 2 supply line loose contact. 3 loose contact near chroma signal processor in luminance section only. 4 any connector loose. 5 no component failure.
Sep 24, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sonny tv triniton
Buddy, Not a problem for the average Home Technician. Unless you are good at Solid state Electronics service. Problem is faulty Red Outpuit Transistor or associated components. Best to seek professional hellp.
Mar 31, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony FD Trinitron WEGA KV-32FS100 32" TV Logo
55 people viewed this question
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
