Question about Dell (4G889) for Inspiron 2500, Inspiron 4000, Inspiron 8000, Inspiron 8100 Modem
PCI network card
The pci network card doesn't appear to work, no flashing lights. I'm unable to use with a virgin broadband router. I've tried to locate a driver in case that fixes the problem but can't find one anywhere. The laptop is a Dell Inspiron 2500 running W2K. I downloaded and paid for Driver Genius pro but that didn;t help either. I'm wondering if the card is not working any longer but not sure how to tell.
Any help would be appreciated.
Regards
Jason
Posted by maddie10 on
Mohammed Jamal
    Master:
  • Dell Master
  • 126 Answers
Posted on Jun 03, 2017
5 Related Answers
Anonymous
  • 103 Answers
SOURCE: Mini PCI card OW9764 for Dell Inspiron 630m
Try this one
I found someone else that was having the same problem locating this and it worked for them. It was a very slow link when I tried it, but be patient.
http://support.dell.com/support/downloads/download.aspx?c=us&cs=19&l=en&s=dhs&releaseid=R107434&SystemID=XPS_M140&os=WW1&osl=en&deviceid=8274&devlib=0&typecnt=1&vercnt=1&formatcnt=1&libid=5&fileid=139213
Posted on Apr 27, 2008
Anonymous
SOURCE: Dell Inspiron 1000 Notebook Windows XP PRO
dsasasasafd
Posted on Jun 18, 2008
Anonymous
SOURCE: my laptop cannot connect to my local network (LAN)
SHOW WITH ICONS IT IS VERY EASY TO USER
Posted on Sep 04, 2008
Barry Parks
  • 202 Answers
SOURCE: i lost my wire less connector and wish to install it
Here is a link to the Dell support website for the D610. You can download all of the drivers from there. I would suggest that you also download and install the BIOS flash to make sure the computer is up to date that way.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&os=WW1&osl=en&catid=&impid=&SystemID=LAT_PNT_P3C_C610
Good luck and please let me know how this works out for you.
~ Spoem
Posted on Mar 26, 2009
Patrick Kam
  • 88 Answers
SOURCE: after i formatted my pc! i have no pci modem neither network controller, and i tried searching in dell's support site no use! please help:S
Try this link for the Conexant chipset modem driver from Dell. If it expires then you have to navigate through from http://supportapj.dell.com/support/downloads/index.aspx?c=au&l=en&s=gen&~ck=bt You may also check whether you have the latest BIOS update (A16, 5 Jul 2005) too.
Posted on May 27, 2009
Sony SMP N200 Network Media Player - unable to connect to home wireless network
You may need to enter the SSID in the wireless configuration in the Sony.
Check the Netgear wireless setting ie. the SSID, WPA or WPA2 encryption key, then apply these settings to the Sony wireless card settings.
Mar 20, 2012 | Computers & Internet
Linksys wireless b broadband router driver
if you want to download the cd driver for linksys router then you need to go to linksys official site .
Jan 05, 2012 | Linksys BEFW11S4 802.11b Wireless...
How do I change from wired hookup to wireless? Bob
Instructions
Things You'll Need
Broadband modem
Router compatible with modem
Internal or external wireless network adapter
Phillips screwdriver
Suggest Edits
  1. Prepare the Network
  • Purchase and setup a wireless broadband router by interfacing it with your wired computer. Choose a router that is compatible with your broadband modem and that supports the wireless network type you desire.
  • Enable WPA or WPA-2 security, and change your router's default password. Give your SSID or wireless network a memorable name.
  • Connect your modem to the WAN (wide area network) port on your router.
  1. Install an Internal Card
  • Purchase a wireless network card that is compatible with the router you purchased and with your computer. For example, if you bought a 802.11 b/g router, do not purchase an 802.11 n adapter.
  • Shut down your computer. Remove all cables and peripheral devices.
  • Remove the left side panel while facing the front of the case. You may need to remove screws or to manipulate latches and notches. Consult your case or computer manufacturer's documentation if you are unsure of how to remove the panel.
  • Clip the metal part of the anti-static wrist bracelet to a metal object, and ******** the bracelet.
  • Locate an available PCI or PCI-Express slot. Unscrew the screw that secures the slot cover that corresponds with the slot, then remove the slot cover.
  • Line up the wireless adapter's pins with the slot. Insert the card until it clicks into place. Do not force the card into the slot, or you may damage the card's connectors. If you feel resistance, remove the card, line up the card with the slot again, and reinsert.
  • Secure the card with the slot cover screw. Reattach the side panel, and replace any screws you removed earlier.
  • Reinsert all cables, and plug in all peripherals. Boot the computer.
  • Allow Windows the opportunity to detect the card. It should automatically install the drivers for the card. If you have updated drivers, insert the disk and install according to on-screen instructions.
  1. Install an External Card
  • Boot up your computer.
  • Insert your external wireless adapter into the appropriate slot. For example, if you purchased a USB slot, insert it into a USB port.
  • Complete Setup
  • Double-click the network icon in the task bar.
  • Highlight your wireless network. Windows will display the name you entered when setting up your router
  • Click the "Connect" button.
  • Enter and verify the security key you created when setting up the router. Click on "Connect."
If you have further query then try to let me know. Thanks for using FixYa.
Aug 27, 2011 | Cisco Linksys Wirelessn Router Black...
I AM ON TOTAL BROADBAND HOW DO I CONNECT WIRELESS TO MY COMPUTOR
With a broadband connection you will need a wireless router (you will connect your broadband modem to the router) a wireless adaptor for every computer you want to be wireless. If you have a desktop you can either add a pci wireless card (you will need to open your pc and insert the card in a pci slot) or you can use a usb wireless adaptor.
Oct 28, 2009 | Computers & Internet
Network adapter not being recognized by pc
you need to disable the old network card go to the computer setting (CMOS) and disqble the network card (you are having a hardware addressing conflict.
Jul 01, 2009 | Computers & Internet
Lost network key on belkin router with virgin broadband
the easiest would be to login to the router and set another network key.
if you're unable to login you'll have to reset the router and reconfigure it.
Mar 23, 2009 | Belkin (F5D7230-4) Router (587009)
11g wireless adsl modem router tew-435brm
virgin media is dsl not adsl which is the router you had
Nov 27, 2008 | Trendware TRENDnet TEW-435BRM 802.11g...
I have recently moved house from a virgin broadband connection taking my router and lap top with me. My new home has existing virgin broadband. Having plugged everything in as should be my laptop finds the...
Try reseating te broadband connection to the router.
It soundslike your router works if it connects to your laptop with a great signal. But its not sending any information through.
Try reseating. if it does not work. you might need to do a fresh reinstall of the router. Usually the broadband connections attach itself to a mac address of a network card. If you recently put a new router the network cards MAC address is different and it might not send signals through. like for me for cable i have the same issue.
Try this let me know how it does. If any problems please let me know.
I hope this helps
Please Rate.
Sep 18, 2008 | Belkin Computers & Internet
Virgin broadband to laptop
Try setting a static IP on your computer with the DNS provided by the modem- to set this up contact Virgin and have them help you setup a static IP(or if you know how to set static IP on the computer use the same IP information you getting from the DHCP).
May 13, 2008 | Belkin (F5D9230-4) Wireless Router...
How to use 1800 HG on a non BT IP
i got all green lights on my route and was working a week ago but for some reason it has stop work. please help
Jan 27, 2008 | 2wire 1800HG Router (RG1800HG00)
Computers & Internet Logo
65 people viewed this question
Lee Hodgson
Lee Hodgson
Ekse
efs_perpends
efs_perpends
