SOURCE: radio wiring diagram please
com on man hook up the amp turn on wire will fix the problen, and stop being cheap use harnesses
SOURCE: 2000 ford windstar anti theft light flashing vehicle won't start
This means that your key is not being recogonized.Ethier the chip in the key is bad or the patts transciever at the lock cylinder. Do you have a spare key? If not you will have to get 2 new keyss cut and programmed.
SOURCE: Stock Speakers wont work with new stereo plzzzz HELP
U have a Factory audio auxiliary amp in the truck, the radio is just a head unit with a preamp feeding a main amp, that is behind the right rear 1/4 panel trim panel in the cargo area, if your new sound unit has preamp outputs use them, other wise u must wire around the Ford factory amplifier.
SOURCE: Car Door Speakers wont work after installing new Stereo
check you Fade and Balance,sometime the ground is used for two speakers sometimes a ground is used more then once will cause your problem ........Good luck......
SOURCE: 2000 ford windstar 3.8L Front heater has
what stopped? the air doesnt blow,if thats the case then replace the blowermotor resistor, its located on heater box on passengerside next to blower motor.hope this helps, let me know if this was the problem.
disconnect the negative battery cable from the Altima's battery.
Pry up the trim panel surrounding the gear stick. The trip panel is held in place by plastic clips that will disengage when the panel is pried up. Use a flat-head screwdriver to pry up the panel. The panel doesn't need to be completely removed, just pried up enough to reveal two Phillips screws along the bottom of the radio trim panel.
Remove the two Phillips screws along the bottom edge of the radio trim panel, just above the gear stick. Remove the two Phillips screws from above the radio. Remove the ashtray.
Pry the radio trim panel loose with your fingers or a flat-head screwdriver and remove it.
Remove the four Phillips screws holding the radio in place. Set the screws aside for use later. Slide the radio forward and disconnect the wires from the back of the device.
Slide the cage included with your new stereo into your dash adapter. Slide the stereo into the cage and dash adapter.
Connect the wires from the dash to the back of your new stereo. All stereos have slightly different connections methods, so refer to the owner's manual accompanying your new stereo for the proper connection procedure.
Slide the stereo and dash adapter into the dashboard. Use the previously removed Phillips screws to mount the stereo in place. Replace the radio trim panel and gear stick trim panel. Reconnect your battery.
If you are putting a aftermarket stero make sure you buy a stero harness that plugs into the cars harness, on the back side of the harness you just installed will have open wires to conet to your new stero. If you cut the wires from your car to try to splice it to the new raido it can cause problems with the electrical system includeing making the transmission shift or act funny. you can pick the harness at wall-mart, car auido, best buy, or any car auido place.
