RCA model# R52WH74
Our RCA R52WH74 tv from what i have researched, has some sort of convergence problem. the top and bottom of the tv is bowed and the screen appeares in 3-D. on the menu, there is no option for convergence (i was reading some other blogs and some had asked about that), and when you go to the menu or change the channel everything is green/ blue/ and red triple vision. we are trying to fix this ourselves. we got the tv for free and called to get a quote on fixing it but everyone is saying possibly 400 but they dont know till they see it. i think that is ridiculous because it costs 100 dollars just to get them to look at it! i was to try to do this myself but i need some advice as to what the problem definately is, or could be anyhow, so we can order the parts online. we also need to know what tools we will need to fix it. here is a link to a couple pictures that i took that may better help diagnose the problem. sorry about the poor quality but its the best pictures i could get... http://s44.photobucket.com/albums/f15/wmwshannonwmw/
also, if there is a way to fix this myself if you could try to provide the website i can order the part(s) from, and maybe even part #'s?
thanks a million, shannon
Posted by wwshannonww on
  • ptcarlo69 Nov 30, 2008
    I have a problem my r52wh74 is red and when I went out and came back he color was all mess up I went and to try to fix the color going to the auto convergence and at the end you play with the cross hairs and the red was fine but the blue crosshair was only half or not even I have unplug it a few time but nothin happen so I try to watch tv it all bright red .I need help if any one can it be great and where is the convergence board and is there a reset button on this tv and this is my second one in two years two repair shops could fix the first problem when the tv shut off and would come back it took 6 months before I seen my tv and in the end they replaced it for no one could fix and not even rca I do wish I neverf bought this all I had s problems soo if any one canhelp me it be great
5 Related Answers
Vista Electronics
  • 1694 Answers
SOURCE: convergence problem
Part # STK392-040 X 2 Do not use generic-they won't hold up.
I use Panasonic brand with no recalls------wholesale cost about
30.00 each. Always replace both at same time = more efficient.
After replacement, alignment may be needed = let me know.
Please rate this solution...................T.
Posted on Nov 12, 2007
Willie Howell
  • 1030 Answers
SOURCE: RED GREEN BLUE CONVERGENCE IS OUT.
if you have a rca hd56w66 chasis itc222 you may have the common fl231 fuse problem. I see this everday at the shop. to determine if you may have this problem. i have written a little article on this subject. Consult tips and tricks section under my profile. Going into maintence mode might have reset some settings.
Posted on Dec 05, 2008
Anonymous
  • 71 Answers
SOURCE: Convergence problem with Philips 51PW936317F TV
bad news probably not economic to repair
Posted on Dec 15, 2008
Anonymous
  • 7 Answers
SOURCE: Bowing at top and bottom, can't adjust convergence replaced IC
you must have the original toshiba remote control in order to fix this problem,if you check th resistors are ok ,you have to go to the aligment by push and hold mute buttom on the remote control and menu in the front of the tv set,
Posted on Mar 22, 2009
Willie Howell
  • 1030 Answers
SOURCE: RCA Model #R52Wh74 HDTV Rear Projection
Do you have the convergence option in the customer setup menu? IF YOU DO NOT consult the tips and tricks section of this website for the article ' "The fl231 fuse problem" If you do then it will need some more trouble shooting
Posted on Apr 04, 2009
I have a Rca Model# R52WH74 the picture looks bowed at the top and bottom and has double vision of objects.
The convergence is out, and the convergence ICs' need change, or it will have to be repair, and it will run around 350, on repairs.
Aug 23, 2011 | RCA R52WH73 Projection Television
I have a 52" projection
Bad convergence. Possible bad convergence board(s), or bad connections at flyback on power board along with a little brown/orange fuse by the flyback.
Jan 17, 2011 | RCA HD52W56 52" Rear Projection HDTV
RCA projection tv R52WH74
quick question do you have the convergence option in the customer setup menu. if you do not then goto the tips and tricks section and read the fl231 fuse problem
Apr 23, 2009 | RCA HD52W58 52" TV
Where is the convergance amp?
Accros the top of the chassi.conv power supply is to the left
Apr 04, 2009 | RCA P52921 52" Rear Projection Television
Bow tie looking picture with 3d color mis-alignment
you have lost convergence. First thing to check is to see if you are missing the convergence option in the customer setup menu. if you do not have this option then i suggest reading the article in the tips and tricks section entiltled "the fl231 fuse problem" this is a common and sometime easy repair if you do have it then you might need a convergence power board
Mar 09, 2009 | RCA R52WH73 Projection Television
R52WH74 WONT CONVERGE
first question is the picture also bowed in on top and bottom. if so you may have the common fl231 fuse problem if you do consult the fl231 problem under the tips and tricks section. if you dont then you defently hav a convergence issue. the thing to look for is under setup do you have the autoconvegence option if you dont then you have that problem.
Jan 17, 2009 | RCA HD52W59 HDTV Projection Television
Help with RCA projection TV P46812BL (chasis ptk195AA)
You have probably blown one of the convergence ICs. Effectively the easiest thing to do is replacing the whole convergence board, so that no soldering is involved.
Here you can buy a replacement convergence board, just select your model.
Let me know if you need further help.
Sep 13, 2008 | RCA P52930BL 52" Rear Projection...
Rca model r52wh74
You could get into service mode and set the convergence. The only problem is....RCA decided to remove it from the menu for the R52WH74. It only runs 1 time during the first setup, according to RCA Customer Service. This is the 2nd one I've bougt in 6 years. Enough RCA Garbage!
Dec 02, 2007 | RCA (T120PAK12) VHS Tape (12-Pack)
Televison & Video Logo
211 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
