Question about LaCie 2 TB 2big Triple Interface External 301256U FireWire 400 Hard Drive
RE: Configuring Raid 1
the Lacie works fine with usb in mode "fast" (Raid 0), but when I switch to Raid 1 (as described in the user manual), windows xp do not recognize the device and for what I can see it appears that the drivers of the Lacie are not installed. I try installing the drivers, but xp is not able to find any driver.
Thanks in advance
Roberto
Posted by robert77591 on
5 Related Answers
headstrong
Pedro
  • 233 Answers
SOURCE: Can't access my lacie external hard drive
I would first plug it in to a different PC, this will tell you if the problem is the Lacie or Windows Vista.
if it works on a different PC then remove it from Device manager or go to the Lacie website for Vista updates.
If it does not work on a different PC then there are 3 possibilities
1. the drive got cleared data lost
2. the enclosure is bad (I would bet on this)
3. the drive is bad
purchase a USB enclosure, remove the drive and install it in the new enclosure plug in and test.
Hope this helps
thanks for rating
Posted on Jan 09, 2008
Anonymous
SOURCE: Lacie 2big Triple 2T - Raid 1 LED's blinking
Solved! After 17 hours of blinking, the status of the 3 leds is now to fixed blue. You just have to be patient...
Note that I had only put 1GB of data on the drive. I expect that the resynchronization time is not proportionnal to the amount of data on the disk!
Posted on Jun 29, 2008
tdk1988
  • 121 Answers
SOURCE: XP doesn't recognize 500GB external Lacie after almost 2 years
try it on different usb ports on your system
try replacing the cable which connects the hard drive with the usb port
if this does not works the problem lies in the portable hard drive and i think it would be under warranty period so get it checked
Posted on Jul 09, 2009
virtualhost
virtualhost
  • 2185 Answers
SOURCE: 4 big quadra 6 TB,
The hard disk might originally came from a computer with raid 0 configuration that is why no matter what you do to reformat, it will always give you the same drive space as your Raid 0. The solution to your problem is actually deleting the partition first from another computer before formatting.
You will be needing a windows installation disk and you can plugin the big quadra thru the usb cable in another computer. Run the windows installation disk (this could be xp or vista) and when it prompted you to choose a task, just press enter to start windows installation (DO NOT press R to go to recovery console). Next, the system will search of every available partition and will show you the drive partition for your Big Quadra. Select for it and delete the partition from there. After it has been deleted, you can cancel that installation process from that computer and try re-formatting your drive into Raid 5 again as you have been doing before.
Should you have any question, please feel free to ask. Good luck!
Posted on Feb 24, 2010
benomaton
SOURCE: I have a 1TB LaCie 2Big Quadra. It has 2 500GB
I have the same problem too on my 2big form lacie . If I use 2x 1,5 tera disk in "fast mode" or in "big mode" my disk manager only shows 746 gigs available (it should be at least 2,5 terra).
If I use "safe mode" so my system can see 1,3 tera available, wich is normal for a raid mirror configuration.
I hope to find a solution quickly.
Posted on Jan 11, 2011
Where can I download the drivers for Windows?
Drivers are for equipment, (hardware), in or connected to your computer, ie printer, network card, usb, video card etc. Windows is pretty good at finding the drivers for them automatically but if it fails you need to go to the manufacturers web site and download the appropriate driver. Or, if the hardware came with a disk insert the disk and run the install program which should automatically install the driver.
Drivers for Windows are supplied with with the operating system that you purchase from Microsoft or your local supplier.
Mar 18, 2015 | SimpleTech 1TB SimpleDrive Pro Duo...
I have a 1TB LaCie 2Big Quadra. It has 2 500GB and runs on RAID 1. I replaced both 500 GB LaCie drives with 1.5 TB LaCie drives, but my computer only recognizes the original 500 GB. I formatted both...
Dec 13, 2010 | LaCie Big Disk Extreme 500 GB Hard Drive
Product: LaCie 2big quadra ((Professional 2-Disk RAID. I have no back-up with the 2 disks, and this soon after purchase (August 2010). Serial number: 5102001839. Disk 2 does not work. At the front, light...
If the failed hard disk drive is replaced with the exact same capacity, RPM and make of hard drive, then the array can be rebuilt. Raid 0 cannot be rebuilt as each drive contains half of the data, If RAID 1 then can be rebuilt as data on each drive is an exact copy. However if combination of RAID 0 and RAID 1 then can be rebuilt. It's best really to handel this hands on, I recommend taking it to a computer technician especially if the information on it is important.
Thanking you
damnor01
Nov 13, 2010 | LaCie 2TB 2BIG QUADRA RAID EXT ESATA FW800...
Backup slow
You don't specify whether previously on your USB it was the same lacie external or whether it was a different external drive. It sounds like you were using a different external drive, most likely a single drive.
You've specified that you've got your lacie setup in raid 5. Raid 5 gives a very good read spead and a good redundancy for incase a drive fails, however it's write speed is very very slow.
It will be much slower than a single drive on USB for writing to it (i.e. backups), but you should see a huge performance boost in reading from the drive than your previous usb.
If you need it to be faster, you would be better suited looking at configuring it for one of the following raid setups:
Raid 0: striping (not recommended for backups) - data is split over all drives, however if 1 drive fails you lose all data.
Raid 10: striping + mirror . half the drives are striped (like above), but the other half mirror the striping half so if one drive fails there's a backup of it. You only get half the disk space though, so if you have 4 x 1Tb drives, then you'll only get 2Tb of space.
Apr 06, 2010 | LaCie 2500 GB Network Storage Server
4 big quadra 6 TB, win7.0 pro,i can see the unit, format it,etc. but always in raid 0, the unit doesn´t change when i tried to reconfigure it to raid 5, and i have followed the lacie instructions
Feb 24, 2010 | LaCie Computers & Internet
Dell XPS w/Mirrored drives. No C drive when using boot disk.
As RAID uses block for block copy, a re-sync when adding in a new mirror on RAID 1 will take some time, and system performance will be affected during that time period. There is no indication in windows if the rebuild is complete as this is being done on a hardware level by the controller. Both Raid 5 and RAID 10 have added benefits , but alos require more storage (a lot more in case of RAID 10 as you will have effectivly 3 spares for 1 data.) Raid 5 has the best space/protection pay off, but will be slightly slower than both RAID 1 and RAID 0 as parity has to be calculated for each write. As caffineshark states your best option is to use a combination of the methods we have described:
1) Use the two SATA disks as RAID 0 for performance and reliability.
2) Make backup images of the boot volume using Drive Image / Ghost and store on external USB IDE drive, and then offsite.
If you make an image in the USB drive, make sure you run a verfiy of the image after creation to make sure it's valid.
This should allow you to restore in a DR sutuation, but also give you some decent HDD crash protection.
Jan 29, 2010 | Dell My XPS M2010 Notebook
Pci ide controller for third hard disk i have connected a third hard disk160 gb in my desktop via pci ide controller card in windows xp. hard disk is not being...
first u shud check if the BIOS is detecting ur new HDD.
if its not u can activate the new port through bios in the advanced peripherals options sectin :)
Jan 30, 2009 | Sabrent SBT-RDIT PCI IDE Silicon Image...
Lacie 250GB Hard Disk is not being recognized by PC (Windows XP)
Some PC's cannot deliver enough power to the USB devices to function properly through the USB port.
Does your Lacie hard disk have a power input connector if so conect a power adapter to it before you put it into your USB port.
Another alternative, get a powered USB hub connect it into your computer then connect the Lacie hard drive to the powered USB hub.
Jan 03, 2009 | LaCie (300728U) 250 GB Hard Drive
Jun 07, 2008 | LaCie 1 TB 2big Spare Drive 301307 SATA...
Blinking Power Light
My Disk has been formated.Not recognized by Windows.How can,I reset the USB.
Dec 02, 2007 | LaCie Big Disk Extreme with Triple...
LaCie 2 TB 2big Triple Interface External 301256U FireWire 400 Hard Drive Logo
Top LaCie Computers & Internet Experts
Ekse
ChinthakaJ
ChinthakaJ
Marvin
Marvin
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
