Question about Kenmore 92420 / 92421 / 92422 / 92424 / 92429 Electric Kitchen Range
Opening the oven door causes the oven to reset and PF on the display
We have a Kenmore elilte electric stove that has been repeatedly moved over the past few years. The house we're in now had a 3 prong outlet and the this stove has 4. I was told it was OK to simply wire the 4 prong outlet leaving the bottom prong open just the ground and the left/right wired.
The stove powers up but when the stove top is used it makes a loud click when the burner cycles and after setting the clock, opening the oven door causes the unit to reset itself and the display shows PF with a blinking 12:00
Do you think the problem is that 3rd leg on the power cord or has something been knocked loose with all the moving or ?
Thanks
Posted by wkpinmiss on
5 Related Answers
Anonymous
  • 87 Answers
SOURCE: kenmore ele dryer
Remove the ground strap from the middle terminal block in the dryer. Attach the white wire to this terminal. Take the green wire and attach it to the frame of the dryer. Attach the red wire to the right hand terminal, and the black wire to the left side terminal.
Posted on Jun 08, 2007
reg501
Richard
  • 413 Answers
SOURCE: Kenmore range model 790.90152300 the
The electronic oven controller has failed. The cost is around $160.00.
Posted on Jun 26, 2008
Jaime Hernandez
  • 2337 Answers
SOURCE: Kenmore Washer/Dryer Combo Unit Cord Issue
Click here for more info on the electrical connections from a 3 to prong.
I would suggest to check with the superintendent of the building first before hooking the appliance. That way you will know if the wiring will be able to handle the amount of power require to operate the appliance.
Posted on Sep 15, 2008
jsrock516
Jeff Rockwell
  • 5911 Answers
SOURCE: No heat-switched from 4 prong to 3 prong-Ground????
There should be a ground bonding ******** the Neutral (White) wire at the terminal block for 3-prong configuration. The following link explains:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
Read through the information, thoroughly. Instructions on how to convert from 4 to 3 prong are mentioned in the "Additional Notes" section. If you have questions, or require addtional assistance please let me know. I hope this helps you.
Posted on Jan 13, 2009
jsrock516
Jeff Rockwell
  • 5911 Answers
SOURCE: Kenmore series electric dryer need to replace 3 prong w/4 prong
The following link explains how to convert a 3-prong appliance cord to a 4-prong and vice-versa:
If you still have questions, please let me know. I hope this helps you.
Posted on Feb 27, 2009
Converting a 3prong to 4 prong electric outlet, need order of colored wires
call an electrician before you kill yourself or burn down the house
Feb 20, 2018 | Kenmore Elite HE4 Electric Dryer
Maytag neptune endeavor 3 prong electrical cord conversion
Yes this can be done but this is removing the ground wire in the plug which if you have a thunderstorm and a purge comes threw it may blow the board now this is a maybe so it will have to be hooked up L1Black L2 red And white. on the back of the dryer instead of L1 L2 Common and ground. They have operated this way for 20 years. Please rate my solution and leave testimonial it is how i earn my achievements thanks in advance.
Apr 23, 2012 | Maytag Neptune MDE5500AY Electric Dryer
Just moved, the dryer has a 4 prong plug and house has 3. Should it replace plug to dryer to 3 prong or house plug?
Buy a 3 wire cord and install it on the dryer. Hang onto the 4 wire one in case you move again.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 28, 2011 | Whirlpool LER4634J Electric Dryer
Dryer is 2 years old. Worked fine until we moved to a new house and could not hook it up. 1 year later I finally had the electric problem fixed and hooked the dryer up No Heat. Dryer turns on but NO Heat.
is the outlet 3 or 4 prongs?. voltage check the outlet for propper voltage. check connection at dryer power cord. 2 of the wires power the motor circuitry(120vac) the other 2 the heating element. you may have a loose connection in outlet,switch wires or bad-half trip breaker. if not,,,, there's a dryer problem, call us again with update please. good luck to you.
Feb 07, 2011 | Dryers
Two out of three of my timers have jammed up. the timer does not turn at a certain point without forcing it. they are like 2 weeks old. can I fix this or should i just change brand
I test timers.
4-6% arrive defective >>> and most last less than a year. But some last a long time.
Plug-in timers are made cheaper today.
Inside the timer is small clock motor that rotates plastic gears that rotate time dial.
Plastic arm rides along the time dial.
When segments or pins are up-or-out, plastic arm moves back-n-forth and opens and closes electrical contacts.
If motor is not able to turn the dial, then motor is overheating and is in downward spiral.
They don't make replacement motors for inexpensive plug-in timers.
So you need a new timer.
Amazon has interesting page that shows wide selection:
http://picclick.com/Amazon/Home-Improvement/Electrical/Timers/
Amazon sells 2-pack of plug-in timers with 2 prong outlet
http://www.amazon.com/59419-Appliance-2-Prong-Outlet-24-Hour/dp/B002Y1KZHQ
3-prong outlet
http://www.amazon.com/59366-Appliance-3-Prong-Outlet-Repeats/dp/B001D8VIKE
Here are Woods timers:
http://waterheatertimer.org/Woods-timers-and-manuals.html
Tork timers:
http://waterheatertimer.org/Tork-consumer-timers-and-manuals.html
Dec 18, 2010 | Woods 59200 Lamp and Appliance Timer with...
Changing a 3 prong plug into a regular outlet plug.
Your plug is for 220v and a regular wall outlet is 110volts. It simply will not work. You will burn out your dryer, and place yourself at risk of electrocution.
Nov 03, 2009 | Maytag Neptune MDE6800A Electric Dryer
We have a Kenmore 70 series Electric dryer and it heats just fine and stays hot, air flow is good,(checked), however the clothes are not getting dry. My husband replaced the cord to the outlet from a 3...
Did the dryer get clothes dry in your old home with the 3 prong plug?
If so, id put the 3 prong plug back on it, and switch to outlet to a 3 prong...
Jul 10, 2009 | Kenmore 63942 Dryer
Feb 15, 2009 | Kenmore 62802 Electric Dryer
Kemore Gas Stove - longer electrical cord?
of course you can at any store that sells extension cords . just get one for appliances
Jul 25, 2017 | Kitchen Ranges
3 prong outlet/4 prong plug
If you bought an electric range , it is a 220 volt range with a BIG plug and can only be used in a 220 volt outlet.
If you can plug a small appliance into that outlet then the outlet is only 110 volts and you need an electrician to run a new 220 line!!!!!!
Was the range you are replacing a gas range??? If so that runs on 110 volts like you TV and toaster and every other small appliance in your house!
If you are not sure what you are doing get a professional to help you!
Every year in the United States thousands of people die buy trying to fix the electrical in their home alone!
BEWARE 220 Volts will shock you! BUT USUALLY will kill you if you touch it!
ngafm
Please rate me on this site before you sign off!
How old is the appliance?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
You will be fine
Bless You ngafm
PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF!!!!!!!!!!!!!!!!!liance in your house!???????????????
Sep 06, 2008 | Ovens
Kenmore 92420 / 92421 / 92422 / 92424 / 92429 Electric Kitchen Range Logo
Top Kenmore Kitchen Ranges Experts
Marvin
Marvin
Paul Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
