Question about Danby Heating & Cooling
Danby air conditioner. Model # DPAC8020 or 7599 according to the Manual. The water is leaking out, it seems to be around the "Quick connect" nozzle at the back. The conection seems good, the tank is not full, it even does it when empty. It is not damaged and does still fill the tank while it leaks. Help please.
Posted by pdann on
Jimbo Bigbelly
    Habit-Forming:
    New Friend:
  • 18 Answers
I believe that model has a catch tray under the coils which catch the droplets of water and route that water into the tank. First, make sure your unit is pretty level. Then take a look at the bottom of the coils for the catch tray to make sure it's not dislodged or not level. Lastly check the catch tray outlet to make sure it's not blocked and will allow water to flow easily into the tank. The other thing is to make sure the tank is inserted correctly, and the catch tray water is routed into it. You don't mention if it ever worked correctly, but if this unit has been working for a long while, it may be dirty and you need to clean it to get the water to drip down correctly.
Posted on Nov 24, 2017
5 Related Answers
Anonymous
SOURCE: Danby air conditioner model #DPAC10060(R)
here is the manual link: http://www.danby.ca/manuals/DPAC8020.pdf
Posted on Jun 15, 2007
Anonymous
  • 203 Answers
SOURCE: air conditioner is leaking but lights not blinking
Make sure the drainage port is closed as per the instructions. If you continue to have leakage you may have a leak in the tank.
dcp2
Daniel Phillips
  • 63 Answers
SOURCE: Water leaking from portable air conditioner
Sounds like the drain line is blocked you would have to take this unit apart in order to check this. I would use a can of air to blow out the leakage. Also make sure the unit is level
Posted on Jan 25, 2008
Anonymous
SOURCE: Leaking water; reservoirs empty
I have this too we had that problem as well, nothing we could do about it either..
i need a new hose and exaust kit you know anywhere to get that?
this unit is ancient
Posted on Jun 12, 2008
Anonymous
SOURCE: Manual
found it here: http://www.retrevo.com/support/Danby-DPAC8020-Air-Conditioners-manual/id/886bh630/t/2/
Posted on Jul 25, 2008
Need to fix leaking on my simplicity portable air conditioner 6077 and how the drain works
If it is water in a thru window installation you will need to tilt the unit up a little so the condensate water drips outside. I hope this helps! Thank you and please leave feedback.
Jul 11, 2016 | Heating & Cooling
My DPAC10061 is filling up the water bucket to soon after emptying like 20 minutes. Why?
  1. DANBY DPAC10061 MANUAL Pdf Download. - ManualsLib
    www.manualslib.com > ... > Air Conditioner > DPAC10061
    View and Download DANBY DPAC10061 manual online. DPAC10061 Air Conditioner pdf manual download.
Aug 03, 2015 | Danby Heating & Cooling
Danby r410a leaking water
Hi There,
I'd love to help you, however r410a is not a correct Danby model number. Can you please provide a model number?
Thanks!
Jun 24, 2012 | Danby Heating & Cooling
Need a product manual for Danby DPAC7820
The model number you listed, according to Danby "has been retired" (Discontinued). However, if you contact Consumer help line: 800-263-2629, they may can help you.
Jul 05, 2011 | Danby DPAC7820 Air Conditioner
Dandy model DPAC8399 water lear from rear water hold tank
Dandy instructions are located here:https://www.danby.com/wp-content/uploads/2016/04/DPAC83991.pdf
Basically, you need to attach the external tank tray at the bottom, remove the tank male fitting and screw it into the external tank female port.
Nov 24, 2017 | Danby DPAC8399 Air Conditioner
The air onditioner leaks water, can't remember if
Mine is a different brand, but it has a "bucket" in the back I have to empty every day.
Jul 24, 2009 | Danby DPAC8020 Air Conditioner
Need new external water tank quick release for Danby DPAC9030
You can order it from Danby directly (you can get their contact online from the Danby website). They cost like 4$+shipping, I had to buy one last summer. They ship to Canada and the US.
Jun 19, 2009 | Danby DPAC9030 Air Conditioner
Danby PORTABLE Air Conditioner model DPAC10071 is leaking water from bottom base. The unit is 2 weeks old.
The base needs to be dumped regularly. The air conditioner sweats water during operation and the pan collects it. Your manual should give you the procedure on how this is done. In some cases there is a hose attached to the drain pan so that you can direct the drainage to a more conventional drain location.
Jun 27, 2008 | Danby Heating & Cooling
Seems fully operational but not blowing cold air
Sounds like you may have a small leak in the sealed system. If you don't have the receipt, contact the factory and provide them with your model and serial numbers, and if they fall within the warranty manufacture date, you should be able to get any Danby factory authorized service center to repair it for you, in accordance with the factory warranty policy.
Jun 02, 2008 | Danby DAC8003D Air Conditioner
Jun 03, 2007 | Danby DPAC8020 Air Conditioner
Heating & Cooling Logo
91 people viewed this question
Top Danby Heating & Cooling Experts
Dennis Boxerman
CheckitRight
CheckitRight
Marvin
Marvin
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
