2001 Ford Focus Logo
Posted on Aug 05, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Radio reset codes - 2001 Ford Focus
  • 5 more comments
  • Anonymous Aug 20, 2008
    I needed a new battery and now my radio will not work. Dodge Durango 2001
  • Anonymous Jan 23, 2009
    I changed the battery in my renault clio and then the radio was asking for the code. I have this code printed on my maintenance book and have typed it in correctly but it keeps saying error and still wont work. Any ideas?
  • Anonymous Feb 12, 2009
    2000 model focus 4000 RDS SER?° NO: M211643 KEY CODE LAZIM yard?±m edenlere te?Ÿekkür ederim.!!!!!!!!!!!!
  • DAVERIGA Feb 19, 2009
    mondeo serial M507000?
  • Anonymous Feb 20, 2009
    radio cd demande anti vol code dodge dakota SLT 2007
  • Anonymous May 11, 2010
    my ford radio did not work when i changed the battary. the radio is 2015 model
  • Patrick
    Patrick Jan 05, 2014
    I changed the battery in my Hond Element and then entered the wrong code too many times and now it won't let me enter the correct code.
Colin Stickland
Level 3:
  • Ford Master 22,516 Answers
  • Posted on Nov 16, 2008
Colin Stickland
Ford Master
Level 3:
Answers
22516
Questions
Helped
6989926
Points
66324
Look in boot left had side and radio code in stuck to bodywork
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 19, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
5201
Points
I have a 2001 focus ..radio suddenly stopped playing after being at garage.  I thought that the battery was disconnected and the radio neede reset code, as it has a rad blinking dash anti-theft light.  i went to ford garage and they told me they don't have reset codes on the focus.  Is this true?
Anonymous
Level 1:
New Friend:
  • Posted on May 08, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
5201
Points
Please assist with resetting a locked 10 status of my Ford Focus 2001 2l engine. Model AYJMM4401,. The radio/cd 6000 CD RDS E.O.N.
I called Ford Germiston 3 times, a technician has not called back as the receptionist promissed.
My email is [email protected]. Please help me. I cannot remove the tape from the dashboard, it is too complicated for me.
Thank you in advance.
A
Anonymous
Codes for blaupunkt car2003 f 7 694
200 321
A
Anonymous
If the car battery has been disconnected the radio shuts down. to reset the radio you will need the serial number which is on the side of the radio. REMOVE THE RADIO. take this number to your ford dealer and they will give you the four digit code to reset your radio. if you cannot remove the radio yourself your ford dealer will do this for a small fee.
A
Anonymous
Cd /radio may have an anti theft code to reset..sometimes removing the radio and getting the serial number then call your dealer may provide the code to reset the radio cd/player..but do call your dealer first before removing unit....did you check fuses? Check to see if unit is getting power?
May have to disconect battery while removing unit,,don't want to set off an air bag...
Anonymous
Level 1:
  • Posted on Aug 27, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
5201
Points
Change battery an radio do not work need help about the codes
  • Anonymous Aug 27, 2008
    u all have to upgrade the ford focus cars and stop making them so difficult to fix
3answers
I need a code or whatever to get my radio on after repairs
Hello, Dixie -
The resetting code for your car radio should be with the owner's manual and other documentation that came with your car. The instructions for resetting the radio will be in the owner's manual.
If you don't happen to have that, then, you will need to contact an automobile dealership which sells your make of car.
When you find the code or obtain one from a dealership, I suggest you do what I have done: write the code inside your owner's manual on the page with the instructions for resetting the radio, so you will be able to reset the radio again, whenever needed. Note: When the car battery is replaced will be another time you will have to reset the radio.
tip
Reset the Radio on your 2001-2005 Honda Civic
If the radio on your 2001-2005 Honda Civic (as well as some other Honda products) has lost power for any reason (i.e. dead battery, blown fuse, etc), you will need to enter the reset code.
The reset code for the factory installed radio is located in the glove box. Open the compartment; On the back of the door, usually near the left side, there should be a small white sticker. The sticker has one alph-numeric set and one set containing five numeric digits. The number set with five digits is the reset code for your factory installed radio.
Turn on the radio. When you see "CODE", use the corresponding station pre-set buttons to enter the code. If entered correctly, the radio should active immediately.
I got a 2010 Honda Odyssey radio is locked up and giving me a code e I have the code to reset
when you turn the vehicle on after radio shows message enter code, if it is the correct code after entering last digit of the code radio should unlock, if not suspect faulty radio and replace. or you have the wrong code, also try unpluging the battery and repluggin it to reset the radio
2answers
4answers
How do i reset radio after battery is replaced.
hello,
search the internet with the radio brand name and model, and look for the reset code, with instructions of how to enter it,
will be the best if you could get the radio service manual or operating manual, the reset code will be there, there are many manuals offered for free
good luck
Reset radio code
do you have the radio code ? if not contact a chrysler dealer as they can supply the code and the instruction to reset the radio which should be in the radio manual as well
1helpful
Code radio
In the owners maunel you should have a card with the radio code on it.
The radio will only display EEE or OFF when the wrong code has been entered and the radio is locked depending on model - this is due to the battery being disconnected and the incorrect radio code being entered 3 times. You will neet to reset the radio. To do this the radio has to be on for either 2 or 4 hours - see the manual for your model. If you got the code from a card from Volvo, and it didn't work, then the radio has been changed or it has been reset by the dealer and your current code is invalid. You will have to pull the radio and find the serial & model number, and get Volvo to look up the code for that radio or the dealer may be able to lookup the radio code via vin# from Volvo. The dealer can reset the radio and enter a new code. When the radio is "ready" to accept an unlock code the display will say "codE". You will need this code if your battery is ever disconnected.
Resetting radio code
You need to be very careful Each failed attempt causes a long delay before you can enter it again. Follow the instructions exactly. You may need to use the car for a day or more before attempting it again if you failed too many times. The radio should say CODE not ERROR. Error means no code can be entered now. You must wait until the radio displays CODE.
My battery died I replace the battery and now radio do not except a code.
If the radio will not except the codes because radio codes was attempted to many times, you can reset the radio by disconnecting the battery for 30 seconds and the radio will reset it self for you to re-enter the radio code. Good luck and keep me posted.
Code for radio, changed battery and now no power
Check the manuel, the code may have been written in there and give you the instructions to resetting the radio, and check for a sticker in the glove box for the radio code. If you have a good relationship with the dealer they may even help you reset your radio without a fee or minimal amount.
Good luck and if that does not help you and they want a crazy amount to reset the radio try www.radio-code.com. Keep me posted
Top Ford Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Ford Expert? Answer questions, earn points and help others
