Posted on Apr 03, 2017
Incorrect Printer Job History
I need to know how can I configure the Print Log Information on Gestetner DSm618.
I look on the print Job History and the User name and User ID is missing.
Under the Status column it says Skipped due to Error but the print jobs are successfully printed. This is a display error that i need to configure. I want to see on the Printer Job history page the User Name and User ID of the user who sends a print job together with the correct status. The information under Document Name, Started At, and Page(s) is ok.
Thanks in advance,
Mihai
4 Related Answers
nadeem-1
  • Posted on Jun 03, 2008
SOURCE: Model number
Gestetner printer fax copier 320 drivers
Anonymous
  • 86 Answers
  • Posted on Jan 10, 2009
SOURCE: Printer stops during print job
Please check if it is giving an error and read any instruction given on the display when this happens and follows accordingly.
socalern
socalern
  • 48 Answers
  • Posted on Oct 20, 2009
SOURCE: How to cancel a print job
Press the Print key, press offline, select "reset print job"
gggg
  • 904 Answers
  • Posted on Jul 18, 2010
SOURCE: Gestetner DSc332
Sometimes a job will get caught up in memory. If you've already tried to reset the job from the copier and from your computer, turn the copier off with the main (orange) power switch and unplug it from the network cable and the wall. Wait 30 seconds, then plug it back in and turn it on.
2answers
Key is flashing. Internet blue light is on. Printer gets signal for print job but won't print until I USB connect it to my Macbook OS 10.6.
Follow the steps below to resolve the issue
The print queue and Dock printer icon
When you start a print job, you will see your printer icon appear in your Dock. Click the Printer icon to open the print queue, which is a list of print jobs that are printing, on hold, or paused. The print queue will also display messages sent from the printer.
You can alternatively open the print queue from the Print & Fax pane of System Preferences.
printer%20queue.png In the Print Queue toolbar you have these buttons:
  1. Delete - Deletes the selected print job.
  2. Hold / Resume - Will hold / resume the selected print job.
  3. Job Info - Shows details of the selected print job, such as job name, status, Completed, Job Message, and so forth.
  4. Pause / Resume Printer - To Pause / Resume the Print Queue.
  5. Supply Levels - Will drop down the Supply Levels sheet showing you the levels of ink / toner your printer has.
  6. Printer Setup - Lets you configure the printer's name and location details.
  7. Printer - Sets the Print Queue window into Printer mode.
  8. Scanner - Visible if you have a multi-function printer connected via USB. Click it to set the Print Queue into Scanner mode.
You can see what your print job looks like with Quick Look. Click the arrow on the print job just to the left of the Status column or select the print job and press the Spacebar.
From the Print Queue menu bar, the "Printer" menu has these additional options:
  1. Customize Toolbar... - Used to add and remove item from the Print Queue's toolbar.
  2. Make Default - Will set the printer pertaining to this Print Queue your default printer.
  3. Print Test Page - Will send the CUPS Printer Test Page to your printer.
  4. Network Diagnostics - Will bring up the Network Diagnostics application, used to check each layer of your network connection.
  5. Log & History - Used to open the Console application and show you the log entries for your current and past print jobs.
  6. Show Printer List - Will open the Print & Fax System Preference showing you the list of Print Queues.
From the Print Queue menu bar, the "Jobs" menu has these additional options:
  1. Show / Hide Completed Jobs - Will alternate Show / Hide in the Print Queue all completed printer jobs and completed functions, like checking the supply levels of your printer.
  2. Show Everyone's / My jobs - Will alternate showing Everyone's / My print jobs.
You can control-click (or right-click) your printer icon in the Dock for this convenient menu:
printer%20proxy%20dock%20menu.png From the Dock menu you can see your printer's status, toggle Pause and Resume Printer, Auto Quit (once print job completes) on / off, and from the Options sub-menu you can toggle Keep in Dock on / off.
Network interface. printer and scanner didn't work.
these are not devices that just anyone can install you have to know what you are doing and have the correct software because their different ways to configure these devices depending on environment and requirement please contact your service provider as they are suppose to set up the device for you or other wise contact your nearest RICOH dealership for support
I need drivers for gestetner dsm618
Hi, you can download the DSM618 drivers here:
http://support.aficio.com/bb/html/dr_ut_e/ges/model/x2015_18/x2015_18en.htm
Just pick your operating system and the specific driver(s) you want to download!
3answers
I have a Windows printer set up for the Ricoh 12332C. Jobs are sent and clear the queue, but do not print. They appear to be accepted by the Ricoh - they show in the job history log, but they do not print...
Usually the setting of yout network with your copier/printer setting is mismatched so your printer.copier did not understand. What you can do you should check the system setting of your copier/printer and print it out then you should find the driver of your printer/copier in the add printer hardware secrtion in control panel of your computer network . Before you reinstall it , you should uninstall the previous driver so there is no conflict when you reinstall new driver . Try it
I want to know all error codes for nashua tech dsm618 photocopier AND ITS TROUBLESHOOTING.....
Wow, you'll need a service manual for all of that info. Contact the manufacturer to see if it is available to you, as this information is generally only given to dealers or qualified service techs. However I was able to get a service manual for a Panasonic printer I won without too much trouble ($40 US).
2helpful
2answers
Scanner driver
you can download the driver from www.gestetner.co.za
1helpful
How to scan a doc on Gestetner Copier
You can install the Twain scanning driver which is provided on the Printer driver CD. Insert this CD and select to install the Twain driver only.
After installation od this driver, please open Word document and click on Insert, Picture and select from Scanner or Camera. Check and choose your twain scanner driver and click on insert.
Beforehand you must put the original on the exposure glass.
Try this or you can use scan to email but you need more setup details.
Hope you good luck.
2answers
Press the printer key. The printer screen will appear, and reset job will be an option. You must clear the print queue on the computer or it will just get sent again.
Gestetner 3225
Ax060267,This is the part number of the polygon mirror motor , it is worn out , your machine propably makes a high reving noise aswell when it starts to print , you can go to your nearest rico or gestetner outlet and get a new motor , it sits right in the middle of the machine , sometomes it helps to remove the motor and oil it with a very thin oil , but in mostcases it is beond repair .
Top Gestetner Office Equipment & Supplies Experts
Daniel Blask
Daniel Blask
ZJ Limited
ZJ Limited
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
