Question about Uniden EXA45812.4 GHz Extended Range Compact Cordless Phone with Digital Answering System and Caller...
Uniden DSS 2465
I have a problem with the Uniden DSS 2465. The unit is frozen, flashing 3 messages, but I am unable to retrieve or clear messages, or make a call from the base station.
Is there any way to re-set the machine? Removing power cord does not work, and there is no reference in the manual to any reset procedure.
If any one can help, this would be appreciated!
Posted by 2day2nite on
5 Related Answers
cnavarro
Carl Navarro
  • 2460 Answers
SOURCE: remote retrieval of messages, uniden dect 6.0 cordless
30 seconds with a search engine got this page http://www.uniden.com/index/manuals_results.cfm?cat=59
Put in your model number and you're good to go.
Carl
Posted on Aug 27, 2008
Anonymous
  • 18 Answers
SOURCE: E4 code on base station
i know that you dont want to hear this but that means it must be replaced. you should be able to get a replacment form where you purchased the phone
Posted on Jan 09, 2009
Anonymous
SOURCE: The base ringer on my Uniden TRU9480 base station
I found my owners manual and to adjust the ringer on either the Base Station or Hand Set as follows:
with the hand set in place just use the base arrow up or down to go from 0 (off) to 2 (loud) and on the hand set just use the arrows for high low or off. Just bew sure to have the hand set on the base before adjusting the ringer
jackgee1
Posted on May 03, 2009
Anonymous
SOURCE: Uniden DSS7855+1, flashing ''welcome! please wait...'', wont work
This is not a direct solution to your problem, but a workaround for a similar situation. I have two headsets and two charging stations. One of the headsets was stuck with the message ''Welcome! please wait''. When I put the phone on the charging station it usually sits on nothing would happen, but when I put it on the other station the phone came back to life. The non-working charging station will still charge the phone so it is worth keeping.
Posted on Feb 02, 2010
hmerchant110
AliTech110
  • 7191 Answers
SOURCE: uniden 6.0 answer/base/ cord less message set up
Thanks for using FixYa.
Please let us know the complete model number of the phone.
Posted on May 15, 2010
How to recover a deleted message from a uniden powermax 2.4ghz
You cannot recover any deleted messages from that kind of answering machine, the message is stored on a memory chip and when you delete it, it is gone.
Jul 22, 2016 | Uniden DCT6485-3HS 328E 0204 PowerMax...
Light stays on in the base unit and light flashes on handset. No messages--all have been retrieved.
If your charge light is flashing and you have no messages on your answering system, you may have voicemail. Voicemail is provided by your telephone company and they would be able to assist you with retrieving those messages.
May 15, 2015 | Uniden TRU9488 Corded/Cordless Telephone -...
Flashing message light on uniden cordless phone
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
May 06, 2013 | Uniden 1588-3 Dect 6.0 With 4 Handsets...
Unable to find manual.....how do you retrieve messages when away from home ... do not remember pin if that is required to retrieve...
Pick the model of your phone from the list beginning at
http://www.uniden.com/owners-manuals/dect-phones/scat/dectphones_mnl
to get the manual.
Jul 19, 2011 | Uniden DECT 6.0 Cordless Phone ID
How do you retrieve messages on the Uniden DCT7585-3? Where can I find an online manual?
Press the play/stop button(to the right of on/off button) on the base unit. The unit will announce the number of new and old messages. The unit will give the message number, play the message, then give the time and date the message was recorded.
Press the select key(right button below the screen) on the handset. Press the 2 key on the dialpad to play messages. After playing message date and time is announced.
This link will take you to a site that has the manual to download. You will need to enter a valid email address to complete the download of your manual.
http://www.retrevo.com/d/ds/progress?doc=2e937b7fdaf136396efe79ae624a7b17&rk=0.5466390328323742
Dec 12, 2010 | Uniden DCT7585-3 Phone
Seeking Olympus DSS Player Pro Release 5.0.9
Try the manufacturers site. If there is an update available, it will be there.
https://www.olympus.co.uk/
Aug 05, 2017 | Olympus DS-2 Digital Voice Recorder
Flashing message indicator light is on but there is no message
from operators dss hit mw key then the ext you are trying to clear
May 19, 2009 | NEC 80570 Telephone
I have a flashing green light on a Dterm 80. The solution says to hit the message button at DSS. Do not know what DSS is and no message buttons on any other phones. help
All you have to do is dial "0" for the operator and it should clear the green light.
It is a feature of the attendant to notify that you received a hand written message while you were out. Practically no one uses this feature anymore.
Apr 17, 2009 | NEC DTH-8D-1 Corded Phone
How do I retrieve my voice mail when I'm away from home?
Go to the base unit.
scroll to the answering machine option.
Under there is a setting for your security key.
you can read what's there, or change it to your own two digit code.
when you call in, during the message, enter that two digit code and it'll go into messages. There's a "toll saver" mode so that the machine answers after two rings instead of 4, so that if you call and it rings 3 times, you know there's no new messages.
Manual:
http://www.uniden.com/pdf/DCT648-2om.pdf
Feb 03, 2009 | Uniden DCT648-3 Cordless Phone
Request help to retrieve message,then turn off answering function
maybe the flash ic and cpu is not working,you need to coldsolder this 2 components.
Mar 29, 2008 | Uniden Cordless Phone
Uniden EXA45812.4 GHz Extended Range Compact Cordless Phone with Digital Answering System and Caller... Logo
134 people viewed this question
Top Uniden Lands Phones Experts
Marvin
Marvin
martin hogg
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
