Hey how's it going from what i can find the TV is a Hitachi C50-FD2000 - 50" Hi Definition Projection TV but for australia its call C50-FD3000 but they look the same. I had i guy look at it and he said that it was the red light going and said it would cost $2000 au. if you can tell me how to fix it or if it is worth it that would be great.
thanks
William
SOURCE: tvrepair
Hello my projection screen is cracked and in need to know where i can get it fixed and how much will it cost.
SOURCE: HITACHI Projection TV 53FDX20B having too much red color
my hitachi projection big screen tv 57SWX20B has a draping affect across top of screen why?
SOURCE: tv out of focus
Your convergence ICs need to be replaced. Please respond to this same post and verify your model number and I will post the correct ICs for your model and post a link where you can get replacements with free instalation instructions.
SOURCE: Hitachi rear projection lcd lp500 series
It is likely the projection lamp is weak, causing the picture to cycle on and off. Take the lamp out and examine the reflector. If it is dull and cloudy, it's time to replace the lamp. A new lamp will have a reflector that is shiny and looks like a mirror. Be sure to rate this solution. Thanks!
SOURCE: Hitachi 43FDX15B has a red tint...
This can be caused by a few things. The red crt/picture tube is going bad, which it would have to be replaced, tube can cost anywhere around $195 and up, if it is available. Another problem can be a bad transistor or IC on the red crt circuit board. Either way it should be taken to a repair shop. The average cost for repair could be over $300.
