Question about Kenmore Dryers
DRYER CAUSING SPOTS ON CLOTHES
I am experience spots/marks on clothes when they come out of the dryer. The spots are approximately 1.25 inch long, and a pale orange color. I have cleaned out the dryer, and there doesn't appear to be anything on the inside. I wonder if this is some sort of rust spot.
The marks are especially noticeable on white clothes.
Do you have any suggestions?
Thanks,
Mary Boyert
[email protected]
Posted by mboyert on
steve
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Kenmore Master
  • 35,302 Answers
Maybe you have high iron content in your water?? if so theres a product called iron out. supposedly it works well. good luck
Posted on May 23, 2017
5 Related Answers
jmeredith
Jude Meredith
  • 417 Answers
SOURCE: grease spots on clothes
That could mean your overloading your dryer to the point the wheel bearings are squished really bad. When loading your washing machine you should always be able to see the water level more than the clothes, your clothes should be floating in the water. That way, when you unload your washing machine and go to dry, you will have the right amount of clothes everytime
J
Posted on Jul 11, 2008
David Shaub
  • 2976 Answers
SOURCE: rust spots showing up on the clothes?
Give the clothes more drying time and then remove them as soon as the dryer stops. Over the years, dryers get chipped inside and if damp clothing is allowed to lay on the chipped areas, rust spots will appear.
Also, If you have a lot of iron deposits in your water, you might want to put a filter in your line into your washer.
Posted on Feb 17, 2009
Bassplyr1
Bassplyr
  • 77 Answers
SOURCE: brown spots on clean white clothes
The drum seal is bad in your dryer. Those brown spots are burn marks. It's actually burning your clothes. Unfortunately this is not an easy fix. The same thing happened to my wife and I. I can fix many things, but I decided this wasn't worth fixing since I'd have to take apart the whole dryer to fix it. It would've been very time consuming and you'd have to have the technical ability to tackle the job. We just bought a new dryer.
Posted on Jul 12, 2009
Patrick Rayome
  • 1757 Answers
SOURCE: Frigidaire FDE336RES2 Dryer marking Clothes
Excessive lint on or near the heater coils will send smoldering lint onto the clothes. Use a flash light and go inside the drum to see the heating coils or lifting the top up who should be able to see the lint build-up on the coils. These need to be cleaned.
Posted on Nov 10, 2009
david tobias
  • 11 Answers
SOURCE: Rust Problem
that is not the cause of the brown spots, the front or rear felt is worn out, i've seen the rusty inlet and output for 19 yrs and never saw that cause brown spots yet, your clothes will never come into contact with the holes long enough to cause a spot!
Posted on Nov 16, 2009
I am frequently getting brownish-tan crescent shaped stains/marks/burns? on mostly light colored cotton clothes. The stripes are 2-4 inches by 1/4-1/2 inch. I am not sure if they are coming from the...
Hi , Could be oil from the drum bearings if its noisy during spin. Could also be residue from the drain/ Sink disconnect and check drain hose is it very dirty...........
Feb 04, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Dryer is leaving marks on my clothes. At least I think it's the dryer. It could be the washer. It's just leaving little gray lines, about an inch to an inch and a half long, in various places on my...
The dryer is prone upon leaving marks on clothes. The felt band surrounding the drum has worn out. Replacing this felt band will keep your clothes streak free again
Apr 28, 2010 | Washing Machines
Nov 10, 2009 | Dryers
Frigidaire FSGC747GE gas dryer is causing spots
you may need to replace the upper and lower drum felts, if they are worn, some of the clothing may be getting caught agains the drum and getting a mark on them. if the mark is like a pencil line mark it will be from the dryer, if it is more like an oil spot it will be from your washer. take a look at #20 & 21 in this picture.you may also need to replace the rear bearing which is #12 in this other picture. hope these help you.
Oct 24, 2009 | Frigidaire Dryers
Same thing
Liquid fabric softners usually cause spots and/or marks on light colored clothing . If you rewash the clothing and the marks dissapear , then try using dryer sheets instead . However , if you have an older dryer , then clothing could be getting rubbed between the rear drum seal and panel , but that would cause streaks but no spotting .
Jul 26, 2009 | Washing Machines
Brown spots on clean white clothes
Jul 12, 2009 | Amana DLE330RAW Electric Dryer
Kenmore he4 dryer model # 110.85089400
drum seal tends to change to a rust color after a few years of use 2 options replace both front and rear seal(best) or remove drum and try to clean both seals with bleach /water solution or spray cleaner with bleach ..if seals are not worn to bad this may work as a tempory fix
Jul 04, 2008 | Whirlpool GEW9250 Electric Dryer
Dryer is leaving brown streaks on cotton clothes
To all victims of the brownish colored streak marks: I share your frustration!!! I have the same problem with my dryer which started when my dryer was only 3 or 4 years old - - totally unacceptable for an expensive top of the line dryer! A repair guy showed me how the brownish streak marks come from the felt liner which goes around the drum. Look inside your dryer for the beige or tan colored felt which sticks out around the circular drum. If you rub the felt with an old white t-shirt or paper towel, you will see the same brownish colored marks. My repairman recommended getting the felt replaced eventually, but until then, he gave me the following tips which really help avoid getting the streaks: For white or light colored clothes susceptible to the brownish streak marks: I dry these items as part of a very lightweight dryer load - with just a few other lightweight items. By doing a small lightweight load, clothing is less likely to get caught up & rub against the felt edges. For example, I dry 4 light colored men's dress shirts with 2 or 3 other lightweight shirts. OR for white or light colored athletic "dry fit" type athletic apparel, I dry 6 - 8 total lightweight shirts/shorts. If I throw my white Nike top or white pair of summer pants into the dryer with all my "whites", they will be doomed to getting brownish streaks due to the heavy load pushing them against the darned felt liner! Whenever possible, I wash susceptible items on permanent press to avoid wrinkling, then hang dry. Prior to putting these clothes in the dryer, I also "pre-clean" the felt with an old white cotton t-shirt by reaching into the dryer and rubbing along the felt edges until I'm not getting as much brownish color on the t-shirt rag. For a permanent fix, call a repairman or see the following do-it-yourself YouTube video on "Dryer Repair - Replacing the Lower Front Drum Felt Seal": http://www.youtube.com/watch?v=XoYP_YsGP68 . I have a repair person coming today to fix 2 other appliances, so I'm finally getting my dryer fixed, and I will post an update soon.
Dec 30, 2007 | Dryers
Dryers Logo
54 people viewed this question
Top Kenmore Dryers Experts
Marvin
Marvin
Ned Halaweh
Ned Halaweh
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
