Question about Konica Minolta bizhub 250 All-In-One Laser Printer
Hi Bizhub 250 worked fine on Windows XP Installed windows 7 pro. and installed driver from your web site. Prints via TCP/IP port Konica Minolta 350/250/200 VXL The driver is installed on three computers and the same issue happens. When I print from any software package, I get message saying not responding after a minute or so the printer will print. Then I can carry on using the software package I was printing from. So basically very slow printing in Windows 7 Pro 64 bit, any ideas ? Kind regards Gavin Osborn
Posted by gavin911 on
Norman J Weimar Jr
  • Konica Minolta Master
  • 6,960 Answers
Did you down load the print drivers from KonicaMinolta??? mite also be the firmware, have tech come out and update it. try this site
Self Help Product Support Konica Minolta Business Solutions Inc
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Jun 18, 2017
5 Related Answers
Anonymous
  • 167 Answers
SOURCE: Printer Busy message
Try using the Appletalk protocal and not TCP/IP.
Posted on Jan 08, 2008
Anonymous
  • 8 Answers
SOURCE: Problem in configuring IP address in Konica Minolta bizhub 210 Copier, Printer, Fax
Is there network card is installed in it, if yes then you can configure it with your network go to machine Manu in machine control panel and the in network settings here you can give the IP address and subnet mask after then reboot the machine.
If network card is no installed behind the machine then you can use its built-in USB or and parallel printer without NIC card.
Posted on Feb 02, 2008
steven brickhouse
  • 19 Answers
SOURCE: bizhub 350 error code
c3852 means low fuser(hot section) temp setting. hold down utility or stop key, then you should be abel to do trouble reset. if problem persist it would most likely be a lamp or a sensor, which will require a technician to come out.
Posted on Apr 16, 2008
Anonymous
  • 3 Answers
SOURCE: Konica Minolta Magicolor 2400W -- Only Prints on Reboot!
I've had that problem before too, and found out that there were copies of the printer that had somehow installed themselves on my computer. All I needed to do was to choose to print with "konica minolta copy 1" instead of the one that I *thought* was installed and it worked. I then deleted the original printer and just stuck with the copy.
Posted on Aug 11, 2008
herminio_hal
Herminio Halili, Jr.
  • 210 Answers
SOURCE: Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
Posted on Jul 09, 2009
My bizhub is printing gibberish when i connect my laptop via office network.
Well if the other computers print ok to the Bizhub its not the machine, copier does not pick and chose which computer will not work. Try this web site for the most up to date print driver
Sep 11, 2014 | Konica Minolta Minolta Bizhub C353 Copier
1 tcp/ip printer works on 3 out of 5 computers XP and Win8
What version of driver are you using? I've found that sometimes an older driver will work for the new computers. I'm noticing that Dell has their Open Manage Print Software that covers all the drivers that you would need. The thing is, there are also multiple versions (A08, A09) of that as well. I would try them
Jan 28, 2014 | Dell 2130cn Laser Printer
I need a driver for minolta pageworks 20 that will work with Windows 7, where can I find one?
In Windows 7 in the Devices and Printers box, choose Add printer, then click on Add a local printer, choose existing port if one is already created (Parallel Port or IP Port) or if you have a Network card installed create new port and go to Standard TCP/IP Port. Enter the IP Address of the printer (It will also add the port Name automatically) then Next. Select Next again for Generic Network Card. This will bring you back to the Driver Install Window.
Here you will click on Windows Update, this will download more print drivers for all manufacturers. Once the download is complete select Konica Minolta under Manufacturer then select Konica Minolta Pi7200e PCL5e, go Next and finish off the installing the Driver.
I have a PageWorks 20 at home and using it on Win 7 64bit and this driver works with all paper sizes up to 11 x 17, duplex and optional tray. The driver is for a copier so disable tray 4, hole punch etc.
Oct 27, 2011 | Minolta PageWorks 20 Laser Printer
Can't get windows xp home edition to recognize wireless printer, even after assigning printer TCP/IP address. Windows 7 computer prints to it, but the Windows XP computer can't even find the...
Hi!
You din't wrote what's the model of your printer, but I think we can find a solution:
1. Try to ping the IP adress you assigned to the printer. If that works, please download the latest drivers or installation software from the manufacturer of your printer (or second option use the installation disk that came with your printer). If it does not reply to ping, be sure the IP adress you assigned to the printer is in same range as the IP adresses on your network.
2. It is possible that the installation software itself manage to find the printer on the network, and that means the problem is solved
3. If not, install the printer as it is local attached (e.g USB or LPT port)
4. After installing as local printer, please go to printer proprieties, go to port, choose add a new port, choose standard tcp/ip port and write for the port the IP adress you assigned to the printer.
5. Apply changes and ...that's it.
Please let me know if it helped,
Aug 10, 2011 | Microsoft Windows XP Home Edition
Hi, on Konica-Minolta Bizhub C450 printing speed is very slow. Attached to Ethernet, Data via TCP/IP. Speed 100 MBit fullduplex. Sending a full color A4 page with 300 dpi; f. E. from...
Am having little Challenge if I send job to printer Bizhub c451. D job will enter printer and it will wrote System Printing and it will not print
May 10, 2017 | Konica Minolta bizhub C450P Laser Printer
Konica minolta biz hub 250, causes all applications to not respond for about 1 minute every time we print from a machine with windows 7 64 bit pro. Got the latest window 7 64 bit driver, printer works...
Might have a KMBS tech come out and update the copiers Operating system (Firmware). Driver is for the computer firmware is for the copier which is located on a secure server KMBS wishes to protect its printing software
Apr 29, 2017 | Konica Minolta bizhub 250 All-In-One Laser...
How do I install Konica Minolta Bizhub C350 copier using a router and 1 computer with Vista 32-bit?
To setup LPR Printing, perform the following:
For Windows 2000/XP/Server 2003:
1. For Windows 2000, click the [Start] button, point to Settings, and then click Printers.
2. For Windows XP/Server 2003, click the [Start] button, and then click Printers and Faxes.
3. Right-click the icon of the installed printer, and then click Properties.
4. On the Ports tab, click the [Add Port] button.
5. In the Available Printer Ports list, select Standard TCP/IP Port, and then click the [New Port] button.
6. When the Add Standard TCP/IP Printer Port Wizard starts up, click the [Next] button.
7. In the Name of printer or IP address box, enter the IP address for this machine, and then click the [Next] button.
8. Select Custom, and then click the [Settings] button.
9. Select LPR, enter Print in the Queue Name box, and then click the [OK] button.
10. Click the [Next] button, and then click the [Finish] button to apply the setting.
Oct 05, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
I have two different domains that are connected via VPN connection through two routers. I can ping from domain to domain via IP address on clients and servers. However I can only do a net view command on...
So you verified ICMP traffic isn't blocked and it appears the servers allow the netBios traffic to pass.
On the client machine, check to make sure the windows print and file sharing is installed and the machine isn't blocking netBios traffic.
Make sure TCP ports 137,139, and 445 are open on the xp machine and any devices in between.
It's acting like the TCP data is being blocked by the client machine.
HTH,
-Aaron
Sep 28, 2009 | Microsoft Windows XP Professional
Konica Minolta bizhub 250 All-In-One Laser Printer Logo
244 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
