Question about Makita Drills
Hi, I have repaired 3 Makita 18V 3Ah Li-Ion batteries recently by removing good cells from other faulty batteries. The Voltages are good now on all 3 and they charge/discharge OK on my own charger but flash as faulty on the Makita charger. Have received info stating the circuits on the batteries lock-up when more than 3 attempts to charge them when they were faulty. is this correct? Does anyone know how to reset them?? Cheers Mike
Posted by mick_tommo on
James
    Habit-Forming:
    New Friend:
  • 42 Answers
You can get a 18V replacement Makita battery for your drill. The replacement one is cheaper. Replacement MAKITA BL1830 battery pack 100% compatible with the original BL1830 battery, high quality, wholesale price.
http://www.drillbattery.com.au/buybattery.php/makita_BL1830_power+tool+battery.html
Hi, I have repaired 3 Makita 18V 3Ah Li-Ion - 238a8cd6-2a12-46da-8552-39dd93276d4c.jpg
Posted on Jul 21, 2017
richie46
    Top Expert:
  • Makita Master
  • 12,962 Answers
Some manufacturers put some chip on their battery so it can be identified by their charger. If you use a generic battery often, it will not charge or work properly. LG does this with their phone batteries! So you have to use another charger to charge them.
Posted on Jul 07, 2017
4 Related Answers
Anonymous
  • 111 Answers
SOURCE: Makita DC18RA Li-Ion 18V Battery Charger
Most likely, but unless the transformer blew, which is somewhat unlikely, a good repair shop should be able to fix it. Basically the charger unit is a transformer, some diodes to convert ac into dc, and some sensing circuitry to tell you when the battery is done charging. Diodes and sensing cisrcuitry are commonly available parts and not expensive. Transformers are expensive. Even if you get it repaired youll still need an adaptor to convert from the mains 240 to the 120 that the charger wants to see. Get one with a high enough wattage for the charger. Wattage is printed on charger base.
Posted on May 20, 2008
Anonymous
  • 9 Answers
SOURCE: 18v Lithuim Ion battery will not charge
If you have been a bad boy and managed to short the battery by using it for non-proscribed purposes, the fusible link will blow (kind of like a fuse) To fix it, open up the battery (use a Torx 10 security bit, or a small flathead in a pinch) On the battery connection nearest the spring-loaded white catch there is a small bridge of metal with a hole in the center. If this is melted you can solder it back together by sanding the two pieces and putting a glob of solder on them. This will void your warranty (duh!) and remove the battery's fuse protection, but it WILL work again. If the link is intact and nothing else is obviously wrong, you almost certainly have a bad cell. I recommend pulling out the bad cell ( it will be the one that does not read between 2.5 - 4 vdc) and replacing it with one from another dud battery- this requires some fudging and re-soldering. Or do what I did, pull the cell, toss the electronics and the short pink wire, add a cigarette lighter socket and voila! you have a portable power supply giving around 14 volts. Charge it up by wiring two cigarette lighter male ends together (check polarity , + to + (tip end) and - to -) and plug it into your car, but only while it is running or you will be charging your car battery with it! Hope that helps.
Matt Binns GiantGlobes.com
Posted on Aug 18, 2009
durikniz
  • 34 Answers
SOURCE: my makita 18v li-lon impact driver has only 70%
Worn brushes or wrong trigger.
Posted on Oct 20, 2010
rowdy45176
David Ford
  • 2176 Answers
SOURCE: One question please, I have makita cordlless
according to the schematic I saw yes you can and I think that you will be pleased with its performance, their operator manual even lists the weight of tool with this battery. Makita has a 1 year limited warranty on the Li-Ion battery that you might want to consider if you have the receipt.
Posted on May 12, 2011
Testimonial: "thanks"
Why will a makita Li-ion 1.3ah battery not fit in other makita tools?
Some of the Makita 18v LXT tools require the BL1830 3.0AH battery and are designed that the 1.5AH battery will not fit.
Jan 12, 2013 | Makita 18V LXT Lithium - Ion Cordless...
Replacing brushes Bosch impact driver
If it has the replaceable brushes it should be no problem, just unscrew and replace. Try oasistools.co.uk
Dec 28, 2012 | Bosch Gdr18v-Li 18V 2-Speed Multi-Function...
Replace brushes on makita bhp452 drill
Here's a link on how to remove brushes.http://www.youtube.com/watch?v=x-drC2HEzRo
Oct 06, 2012 | Makita Bhp452Rfe 18v Cordless LXT Combi...
I have a makita 6391D cordless drill with 18v ni-cd 1.3ah batteries, just had one battery and charger stolen so have to buy replacements is there any way i can convert it now to lithium batteries if
Replacement MAKITA 6391D battery pack 100% compatible with the original 6391D battery, high quality, wholesale price.
http://www.drillbattery.com.au/buybattery.php/makita_6391D_power+tool+battery.html
Jul 06, 2012 | Drills
Three makita batteries wont charge 18v li-on
I did get an educated electronics eng. tell me li ion batteries 4handtools,are manufactured to only be recharged a set number of times,to avoid tool damage.
Oct 13, 2011 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
May 11, 2011 | Makita 18V LXT Lithium - Ion Cordless...
I have a li-ion Makita BL1830 18V 3.0Ah battery that can't be charged...when on the charger the bottom two lights flash red..it will charge my other battery, so it doesn't seem to be the charger
Sorry Mate your battery is dead...
The makita lithium batterys dont like getting worked hard quickly.
There is a chip in them that recognice each battery to each specific charger. Try another charger. This has not worked for me. Try anyway
Nov 01, 2009 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Problem charging makita batteries 18v li-ion
Unfortunately, Makita’s li-ion battery packs have a design flaw. After having the same problem with my two batteries, I took it apart and saw the problem immediately. You see each battery pack has ten li-ion battery cells and a circuit board with a memory chip witch holds the charging history of the battery pack. But that memory chip constantly draws power from 2 of the 10 batteries. The current it draws is very small but if you consider it over 8 month or more, the power drain becomes very significant. You end up with a battery pack with 8 still fully charged battery cells and 2 drained battery cells. When you put this battery pack in the charger, it detects weak battery cells, assumes they are defective and refuses to charge. To avoid this problem you should charge your battery pack often, even if you haven't used it, every two months should be ok.
I suspect that Makita doesn’t make these battery packs, they make power tools, good ones too. Buy Makita should definitely have a few words with their supplier before they become a liability!
Aug 16, 2008 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Battery charger just flashes to say the battery has to cool down but will not start charging.tried another charger same thing happens but does not show that the batteries are faulty!
Unfortunately, Makita’s li-ion battery packs have a design flaw. After having the same problem with my two batteries, I took it apart and saw the problem immediately. You see each battery pack has ten li-ion battery cells and a circuit board with a memory chip witch holds the charging history of the battery pack. But that memory chip constantly draws power from 2 of the 10 batteries. The current it draws is very small but if you consider it over 6 month or more, the power drain becomes very significant. You end up with a battery pack with 8 still fully charged battery cells and 2 drained battery cells. When you put this battery pack in the charger, it detects weak battery cells, assumes they are defective and refuses to charge. To avoid this problem you should charge your battery pack often, even if you haven't used it, every two months should be ok.
I suspect that Makita doesn’t make these battery packs, they make power tools, good ones too. But Makita should definitely have a few words with their supplier before they become a liability!
Jul 03, 2008 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Makita dc1804f charger will not charge new i-mh 1834 18v battery
I think your tryiong to charge NIMH batteries oon a charger designed for Lithium Ion batteries. With all the new style batteries such as NICAD, NIMH and LI-ION, charging becomes difficult. Most chargers pre NIMH and LI-ion, were designed for NICAD's. The best advise, match your batteries with the correct charger
Feb 06, 2008 | Makita 18V LXT Lithium - Ion Cordless...
Drills Logo
699 people viewed this question
Top Makita Drills Experts
efs_perpends
efs_perpends
epangan29
Mike
Are you a Makita Drill Expert? Answer questions, earn points and help others
