Question about Denon Audio Players & Recorders
How do I restore factory defaults on my Denon AVR-2809? I can't see it in the manual. Thanks
    Brigadier General:
  • 8,546 Answers
Register and download the USER GUIDE (10.6MB) for free at retrevo.com
http://www.retrevo.com/support/Denon-AVR-2809CI-Receivers-manual/id/21864dj590/t/2/
Page 60
Resetting the Microprocessor
Perform this procedure if the display is abnormal or if operations cannot be performed.
When the microprocessor is reset, all the settings are reset to their default values.
1 Turn off the power using <POWER>.
2 Press <POWER> while simultaneously pressing
<STANDARD> and <DSP SIMULATION>.
3 Once the display starts flashing at intervals of about 1
second, release the two buttons.
Posted on Mar 30, 2011
How to reset denon avr 3805
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Reset procedure to many electronic entertainment equipment are given.
Jul 30, 2014 | Denon AVR-3805 Receiver
Reset factory settings of my Denon avr 2800
From Denon support:
To reboot, turn receiver off using the small on/off button, not the big standby button. While off press the night and pure direct button at the same time and keep holding them with your right hand while pressing the small on/off button with your left. You will see your receiver menu flash. When you see it flash let go of the night and pure direct button and the receiver will reset it self to the radio station 87.50. The receiver's microprocessor has now been set back to factory default.
Sep 08, 2013 | Denon AVR-2800 Receiver
Denon avr 3805 is blinking red and blinking green and won't stay on
Hello
Do a reset to the set. Just unplug it from AC mains wall socket and replug it after 3 minutes or so; or just go to ints user manual to know, how to reset it to factory defaults, and do it. OK.
Jan 19, 2012 | Denon Audio Players & Recorders
I lost the sound on my denen avr-1508 receiver
You may reset your unit to factory default settings. Check user manual.
Oct 20, 2011 | Denon AVR-1508 Receiver
What is the button combination to reset the Denon AVR-1601 to factory presets?
switch off, then hold A and B speakers, then switch on and hold about 3 seconds. This is reset to factory defaults.
Jul 22, 2011 | Denon AVR-1601 Receiver
I have a denon 2809 set up with 7.1 speakers. When watching digital TV the 2809 sends sound to all speakers but when I play a blu-ray through either my pioneer player or playstation I get no sound at all...
There will be settings for the socket you play the Blue Ray on. Perhaps it has be set to a mode that doesn't use the full speaker settings? Or is not set to either the optical or coaxial connection needed to play back Dolby sounds?
Jul 11, 2017 | Denon AVR-2809CI
I have a denon avr 2802. the remote powers the
Try doing a factory reset by turning off main power switch.hold down speaker a and b buttons while turning on main power switch ,display will flash 3 time s then release buttons,this then returns unit to factory default settings.
Apr 13, 2010 | Denon AVR-2802
Denon avr -1709 how do i get it reset to factory specs
SWITCH OFF THE UNIT..PUSH AND HOLD DOWN BOTH SPEAKER A AND SPEAKER B BUTTON WHILE HOLDING DOWN BUTTONS TURN ON MAIN POWER THE DISPLAY WILL FLASH WAIT FOR 3 FLASHES THEN RELEASE. THIS WILL RETURN EVERYTHING BACK TO RFACTORY DEFAULT
Mar 21, 2010 | Denon AVR-1708 Receiver
How do i restore my denon avvr-1609 back to factory default??
Not familiar with that model. I used the Denon pro DRA397 units on my jobs. But it my be the same for you.
The reset was as follows. If it works give me a thumbs up.
Power off and not in stand by, hold down the speakers a and b buttons at the same time. Then turn on the hard power button while holding the a and b down. The display will start to flash across the entire screen. Release the buttons and the unit should reset.
Aug 19, 2009 | Denon AVR-1609 Receiver
How do you reboot the Denon AVR-2807 to factory settings
To reboot, turn receiver off by the small on/off button, not the big standby button. While off press the night and pure direct button at the same time and keep holding them with your right hand while pressing the small on/off button with your left. You will see your receiver menu flash. When you see it flash let go of the night and pure direct button and the receiver will reset it self to the radio station 87.50. The receiver's microprocessor has now been set back to factory. Enjoy this info is straight from Denon's Tech support. I had to do this on mine
Nov 25, 2007 | Denon AVR-2807 Receiver
2,632 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
