Question about Haier Televison & Video
I have a 32 inch lcd haier tv. waqnna use comcast remote with red center button. need code and procedure to put in code
Posted by tomstemaly on
STEVEN SEATON
    Master:
  • 525 Answers
Your comcast provider should have sent a code guide with the remote. If you have misplaced it you should call your provider and ask them to send you another one. The codes are all the same for all their remotes.
Posted on Mar 30, 2011
I have a 32 inch Haier TV and my comcast cable remote wont work with it. I need to know how to get my tv to sync with my cable remote.
there is an auto search method....some remotes you can hold the tv button down and then the select button simultanteously for a few seconds to make the light turn red and then proceed with codes, when you get the right code you press the select button again, the light blinks and you are done..... well with out a code its the luck of the draw..... the auto search method is similar to programming the code in....hold the tv button and the select button for a couple seconds until the tv button lights up, but instead of a code.....press the channel up button(that represents the first autosearch code), continue until the tv turns itself off and then press the select button to lock it into the remote...........if you go past the trigger point you can channel down to backtrack.... otherwise drop it in the toilet until it wont work, call the cable company and have them send out a tech with anew remote. they cant charge you for their equipment not working correctly.
trust me, i am a supervisor at a major cable company.
Jan 17, 2010 | Haier HTF20R21 20" TV
I have an haier model L32R1 and comcast cable just came to install and the comcast remote will not work can you tell me what the universal code is to get the remote to work.
i have the same problem and still looking for the code :( but for the mean time i just hook up my digital box to the tv threw the video inputs. hope this helps you.
Dec 03, 2009 | Haier HL32R 32 in. LCD TV
I need a remote for a soyo 32 inch tv or a code that works with a universal remote
The RCA RCR312wv sold at Wal-Mart for about 7 bucks has 2 SOYO codes and the second one worked on my 32" SOYO
Oct 27, 2009 | Soyo DYLT032D 32 in. LCD Television
Missing code for comcast remote to work new rca tv
Hit tv then hold the setup button untill in flashes....then you type in 991 and then hit tv power tv power.... untill your tv turns off when it dose hit setup to lock the code
Jun 11, 2009 | RCA L32HD31 32 in. LCD HDTV
I have the RCA model L32HD31R LCD TV and I need the 5 digit code for the Comcast DVR remote with the red OK button
I have a RCA model L32HD31R LCD, also but the codes from comcast will not turn tv on or off.
Jun 06, 2009 | RCA L32HD31 32 in. LCD HDTV
I have a haier tv with a comcast remote. Need the Haier code for the comcast remote
10768
  1. Turn on your device (i.e. TV).
  2. PRESS the button for the device you want to program (TV, VCR, CABLE, AUD, etc.) then RELEASE.
  3. PRESS and HOLD the SETUP button until the red LED for the selected device flashes twice, then RELEASE.
  4. ENTER the 5 digit code for your brand from the list above.
  5. You should receive 2 quick flashes on the LED for the selected device after entering your code.
  6. PRESS the POWER button to test the code. (On VCR,LD,and CD players use PLAY)
May 28, 2009 | Haier HL42E LCD TV
Need Comcast Remote Code for Samsung LN32A330 TV
I contacted Comcast and here are your codes for the three way remote with DVR Samsung 10812, 10766, 10814. I have the same TV Samsung LN32A330 and it was the very first code for my TV! Hope this cuts down your frustration!
Dec 13, 2008 | Samsung LN32A330 32 in. LCD TV
Televison & Video Logo
252 people viewed this question
Top Haier Televison & Video Experts
Eric Rotmil
Eric Rotmil
CoppellTVRepair.com
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
