SOURCE: blue rubber belt found in dishwasher after cycle
Dishwashers don't have belts only washing machines and tumble driers have them.
SOURCE: The rubber gasket inside the door falls off.
The gasket will have to be replaced. I've had customers with this problem and the only way to correct it is to replace the gasket
SOURCE: Maytag MDB5100AWB Dishwasher not draining
More than likely the filter is clogged,remove the spray arm(there is a threaded cap in the center of the arm twist it to the left,then remove the # 15 or 20 torx(star shaped) screws out of the filter cover(around the edges)The filter is round and runs around the outer edge of the pump housing it lifts right out,clean it and reverse the process.It's the most common issue with not draining on this model.
Testimonial: "The solution from TomZS was precisely what I needed to fix my Maytag washer. Thanks a million!"
SOURCE: found an oval rubber gasket
Hello, Thank You for using FixYa. I will be helping you today.Here is a parts break down of your model CLICK HERE See if you can locate it im not aware of an oval gasket.
Thank You and please rate my answer if it was helpful..
