Question about Dmm Vision Fitness T9500 Treadmill
Hi i have a vision fitness 9450 hrt and i'm getting an error message: E6
Posted by mwhelanusa on
vtechsupport
    New Friend:
Typically an E6 error message indicates that the machine needs to be recalibrated because the elevation motor is out of range or that you have a loose cable connection. Below are the auto calibration instructions. Please make sure that no one is on the machine because it will speed up quickly.
STEP 1 ENTER ENGINEERING MODE
With the safety key in place, hold "ELEVATION UP" and "SPEED
DOWN" buttons for 5 seconds. Software version will appear in display
window for a few seconds before model displays.
Press "STOP" , "ENG1" will appear in display window.
STEP 2 AUTO-CALIBRATE
Press "ELEVATION UP" until "ENG4" is displayed.
Press "SELECT" , display will read "AUTO".
Press "START". Unit will calibrate, when finished "END" appears in
display window, then "ENG1".
STEP 3 EXIT ENGINEERING
Press and hold "STOP" to exit engineering mode
I would also suggest that, with the power to the machine off, you check all of the wire connections underneath the motor cover, the assembly connection that sits where the mast meets the console and underneath the faceplate. Check to be sure that all of the connections are secure and that the pins within the cables are seated properly.
If you are still having any problems you can reach a knowledgeable Vision Fitness Representative toll free at 800-335-4348.
Posted on Mar 30, 2011
Stuck key error on my treadmill
Sometime talcum powder under the thread will get it working again, but you may eventually need a new tread. Less likely, a problem with the motor especially if it's underpowered.
Jul 31, 2016 | Vision Fitness - T9800 HRT Full Commercial...
How many amps in the Vision Fitness T9500 HRT Treadmill
it is a 3 horsepower motor, but no amperage specified. The review does say this model has drawbacks.
Vision T9600 HRT Comfort Treadmill review
However, I found this, so 23 to 28 amps based on a 3HP motor.
Note: the following table contains approximate full-load currents for motors of various types, speeds, and frequencies. Variations of ±10% may be expected.
Hp. of
Motor
Current - Full-Load (Amperes)
Direct-current Motors
Single-phase Motors
115
volt
230
volt
550
volt
110
volt
220
volt
¼
4.8
2.4
½
4.5
2.3
7
3.5
¾
6.5
3.3
1.4
9.4
4.7
4.2
1.7
11
5.5
1 ½
12.5
6.3
2.6
15.2
7.6
8.3
3.4
20
10
12.3
5.0
28
14
Oct 06, 2015 | Vision Fitness Exercise & Fitness
E6 error message
It appears that your elevation system is where the fault lies. This could be as simple as recalibrating the lift mechanism, or possibly correcting faulty wiring from the lower controller to the lift motor. Be sure to check the condition of the lift motor as well as the wires entering the lift motor. Sometimes the wires will pull away from the plastic connector causing a lift motor error
Mar 11, 2014 | Dmm Vision Fitness T9500 Treadmill
My vision treadmill T9800HRT when start shows speed stall and error 7
please see the 2 alternatives for error 7.God bless you
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
Sep 20, 2013 | Vision Fitness 2011 Vision T9800 Hrt...
My vision treadmill T9800 HRT when start shows speed stall and error 7
please see the 2 alternatives for error 7. God bless you
2)Alternative:
Using treadmill stopped and display shows E6 I can not start it again
E6 is error code. You need to go to Vision Fitness website to request the answer to your question. It probably has something to do with the timer circuit.
Dec 26, 2012 | Computers & Internet
VISUAL FITNESS t97005 e6 ERROR CODE
LUBE THE deck belt, this happen because lack of maintenance, do ti
2( lube the rollers bearing too
3( test the input voltage motor, if there are the motor need repair
4) test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
Sep 24, 2012 | Dmm Vision Fitness T9500 Treadmill
Hardware Internal Fault
This looks like a hardware fault. I hope (by now) that you have got an RMA and had it replaced.
Oct 13, 2007 | Visioneer 9450 Flatbed Scanner
Dmm Vision Fitness T9500 Treadmill Logo
1,704 people viewed this question
Top Dmm Exercise & Fitness Experts
Tom Chichester
ray gallant
Marvin
Marvin
Are you a Dmm Exercise and Fitnes Expert? Answer questions, earn points and help others
