This error indicates that the scanner has not been linked to the desktop of the attached PC. Either launch the HP Toolbox and follow the scanner setup instructions, or if you do not have toolbox installed you will need to install the printer from the original disks that came with it.
The 49 code is related to one of three things on this unit.
1.
You accidentally used a refurbished toner instead of one directly from
the manufacturer which tends to cost a bit more. The certified one from
the dealer is known to clear this error code instantly.
2. Your internal memory cash will need to be reset
3.You have internal hardware failure which can not be repaired by the user and must be sent to the manufacturer.
This is an interesting question ... Im thinking maybe even a trick question ...
You want your scanner to not connect with the PC? Don't plug the printer USB into the PC - vola - no connection. The scanner will scan without relying on the PC and the copy function is the same.
If you scanner error 5 or printer hangs at scanner bulb warming up than the issue is with Scanning Assembly inside the printer and it is hardware issue.
My hp 3055 is working fine on the network bt problem is "SCAN TO" Button is not being configured with the PCs.It displays all the PC names bt not able to scan. it diplays an error "Unable to Connect".
can any body help me out of this matter
