None of these are of any help... the only way I have found for my computer to boot normally is with a live linux usb and let that take me to my original hard drive. As in I put the usb in, boot up, brings me to live usb prompt, I do nothing until it boots from hard drive and I'm stuck scratching my head at why this works.
SOURCE: Fn +F2-F3-F4-F7-F11-F12 how do you use
dear bdgdag,
please visit the following site for more information about the functional keys.
remember to vote for me if its useful
http://www.aarp.org/learntech/computers/howto/a2003-03-28-functionkeys.html
SOURCE: i have a msi u100 series netbook.my problem am hav...
This information is intended for experienced users. It is not intended for basic users, hackers, or computer thieves. Please do not try any of following procedures if you are not familiar with computer hardware. I'll not be responsible for the use or misuse of this information, including personal injury, loss of data or hardware damage. So use it at your own risk.
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
SOURCE: i have a msi u130
The key combination for turning the wi-fi on-off is the Fn+F11 (not just the F11). In case this is not working you might have problems with the drivers. Use this official link and choose your op. system (win xp or win 7) and download the wi-fi drivers.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
I have the same problem with my MSI U160, can not boot to USB, all unnecessary equipment is removed, but still the same error, also tried to remove the bios battery for 15 minutes, but no positive result.
