I have a Cinego D-1000 projector. I am trying to connect it to my laptop. I have tried using both VGA and S-Video cables (not at the same time). I lowered the screen resolution on my laptop. I have auto select source enabled. I press the SRC button, it searches for a minute or two, then defaults back to DVD. I have a presentation on Thursday. Please help.
Unfortunately, there is no simple VGA-to-RCA adapter cable if you're connecting to a composite video input (usually colored yellow) or s-video input. VGA output is separate red, green and blue video and synchronizing signals, and they all need to be combined. You need a VGA-to-video converter to do this.
If the projector has component video input jacks, then you can buy a simple adapter cable.
The projector has a computer video cable input on the side of the unit. If yor MacBook has a female VGA output, simply purchase a VGA cable (double male) at a Radio Shack or WalMart, or other comparable retailer, and connect the two. The Cinego will find the input signal from the Mac, and you have to press the right keys on the Mac keyboard to tell it to put the screen signal through the VGA output on the side of the MacBook.
We just solved a similar issue. Most likely your PC or laptop is currently set to a display resolution that is too high for the projector or is one that it cannot handle. Try setting your computer display to 640 x 480 or 800 x 600 and see if you can get the projector to work. If it does, then you can figure out the maximum display resolution you can use. Also consult your projector documentation for supported resolution modes.
For the PICO in particular, it looks like those are in general for small mobile devices (320 x 240 or less displays), and the PK102 model has native VGA (640 x 480) support with extended support for 800 x 600. You will not be able to use this on most modern computers except at the lowest resolution setting for the PC.
The question seems to indicate that you don't have the cables. The unit comes with three different cable for video input. One for Component (HD), one for S-Video (looks like the round plug for a mouse on a computer, but is wired differently), and one that has a single yellow plug that probably is compatible with your VCR. If you don't have the proper cables, get with your Radio Shack dealer to get the, since trying to use a cable which was not designed for the unit may cause damage.
always make all connections first !! after that : switch on the laptop, or else no detection of an external monitor/projection device is possible. Please check also your bios settings, some can be set to force simultaneous display of external screen and lcd of the laptop. some laptops also require ddc communication between external connected devices. Try to use a full wired ( except pin 9) VGA cable.
Three (3) things you can try: 1. Lower down the Screen resolution of your laptop as well as the Color quality and the Screen refresh rate before doing the Fn + F5. If it works, adjust thereafter; 2. Do a soft (Factory) reset of your Cinego in the in the Management Menu (credit to Cooljazz); and/or 3. it is just "slow" in sensing the presence of a VGA source as it
cycles in its selection, internal DVD, VGA, Composite Video IN. Since
it does not have a manual source selection, your only option is to
really wait or ...Verify that "Auto Source Select" is enabled in the
Management Menu (buttons-Proj/Setup then >/9) and "tap" the "SRC"
button on the projector itself to manually initiate the input/source
selection.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
