Question about Cisco Linksys Refurbished E3000 High-Performance Wireless-N Router - E3000-RM / E3000RM (REFURBISHED...
I have forgotten my passwork to my wireless cisco linksys E3000, how do I go about retrieving it?
Posted by jswayze on
david willimes
    New Friend:
    Problem Solver:
  • 11 Answers
Complete these steps in order to recover your password:
  1. Attach a terminal or PC with terminal emulation to the console port of the router.
Use these terminal settings:
    • 9600 baud rate
    • No parity
    • 8 data bits
    • 1 stop bit
    • No flow control
Refer to these documents for information on how to cable and connect a terminal to the console port or the AUX port:
  1. If you can access the router, type show version at the prompt, and record the configuration register setting. See Example of Password Recovery Procedure in order to view the output of a show version command.
Note: The configuration register is usually set to 0x2102 or 0x102. If you can no longer access the router (because of a lost login or TACACS password), you can safely assume that your configuration register is set to 0x2102.
  1. Use the power switch in order to turn off the router, and then turn the router back on.
Important Notes:
    • In order to simulate this step on a Cisco 6400, pull out and then plug in the Node Route Processor (NRP) or Node Switch Processor (NSP) card.
    • In order to simulate this step on a Cisco 6x00 with NI-2, pull out and then plug in the NI-2 card.
  1. Press Break on the terminal keyboard within 60 seconds of power up in order to put the router into ROMmon.
If the break sequence does not work, refer to Standard Break Key Sequence Combinations During Password Recovery for other key combinations.
  1. Type confreg 0x2142 at the rommon 1> prompt in order to boot from Flash.
This step bypasses the startup configuration where the passwords are stored.
  1. Type reset at the rommon 2> prompt.
The router reboots, but ignores the saved configuration.
  1. Type no after each setup question, or press Ctrl-C in order to skip the initial setup procedure.
  2. Type enable at the Router> prompt.
You are in enable mode and should see the Router# prompt.
  1. Type configure memory or copy startup-config running-config in order to copy the nonvolatile RAM (NVRAM) into memory.
KUMAppDataLocalTempmsohtmlclip1clip_image001.gif" alt="I have forgotten my passwork to my wireless cisco - warning" />Warning: Do not type copy running-config startup-config or write. These commands erase your startup configuration.
  1. Type show running-config.
The show running-config command shows the configuration of the router. In this configuration, the shutdown command appears under all interfaces, which indicates all interfaces are currently shut down. In addition, the passwords (enable password, enable secret, vty, console passwords) are in either an encrypted or unencrypted format. You can reuse unencrypted passwords. You must change encrypted passwords to a new password.
  1. Type configure terminal.
The hostname(config)# prompt appears.
  1. Type enable secret <password> in order to change the enable secret password. For example:
13.hostname(config)#enable secret cisco
14.
  1. Issue the no shutdown command on every interface that you use.
If you issue a show ip interface brief command, every interface that you want to use should display up up.
  1. Type config-register <configuration_register_setting>. Where configuration_register_settingis either the value you recorded in step 2 or 0x2102. For example:
17.hostname(config)#config-register 0x2102
18.
  1. Press Ctrl-z or end in order to leave the configuration mode.
The hostname# prompt appears.
  1. Type write memory or copy running-config startup-config in order to commit the changes.
http://www.cisco.com/c/en/us/support/docs/routers/2600-series-multiservice-platforms/22188-pswdrec-2600.html
for more help goto
CISCO Router Support
Posted on Jun 16, 2014
Jerry Nafe
    Sergeant:
  • 244 Answers
He WEP key is defined by the person who set your wireless router up. You will not be able to find out what the WEP key is, but you CAN change it if you have physical access to the router. If you are trying to connect to your wireless router and can't remember the WEP, then walk over to the router and on the back or bottom of it is a small little hole that you can fit a pen or paper clip into. Press the paper clip into the little hole for 10 seconds and release. This will reset all the settings on your router back to default and will allow you to access your wireless connection.
Note: doing this will take away all of your wireless security so make sure that you know what you're doing before messing with it!
Thanks and please rate if this helps you at all :).
Posted on Mar 29, 2011
He code to the wi fi
The default password and login to the router are 'admin' and 'admin'. For instructions to log in to the router, see Linksys E3000 Login Instructions
Through these instructions, you can change the Wifi password.
Feb 11, 2015 | Cisco linksys E3000 Wireless-n Router
Cisco e3000 router port forwarding
Do a full power down and reset to default settings.
Apr 21, 2013 | Cisco linksys E3000 Wireless-n Router
I have a new E3000 that i could log on to via remote connection, but i need to reboot it about 3 times a day. My wireless works after this reboot remotely. What could be the problem with this router?
there could be a problem with the firmware.
go to
http://homesupport.cisco.com/en-us/wireless/linksys/E3000
download the latest firmware for your router and reflash.
it could fix/resolve any bugs for your router.
May 26, 2011 | Linksys E3000 Wireless Router
What is the best router to use for this model
Hello
According to my recommendation, followings are the best
Cisco Linksys E3000 D-Link DIR-615 Wireless N Router
Cisco is the best in performance and price too
however D-link is good performance and affordable.
Hope it helps, if so do rate the solution
Dec 26, 2010 | Dell OptiPlex 170L PC Desktop
I DON'T HAVE THE PASSWORD AND USERS MY CISCO E 3000
opened Cisco Connect under all programs and go to the router settings tab .
Aug 06, 2010 | Linksys E3000 Wireless Router
Cisco wireless g router. Works fine. I want to
Well there are some steps in order to secrure your Cisco wireless G router:
1.Make sure you provide username and powerfull passworke like not less then 7 letters, it should inculde numbers, character,s and symobls.
2. Use Advanced Security: Wireless data encryption (WEP), so the hacker will not able to hack the wireless key.
3. enable Firewall
4. you can you internet access filter featuer , so u can block access to websites or any ftp sites.
5. remmber to backup your router
Jun 09, 2010 | Linksys -Cisco Wireless-G VPN Broadband...
Cisco Linksys Refurbished E3000 High-Performance Wireless-N Router - E3000-RM / E3000RM (REFURBISHED... Logo
137 people viewed this question
Top Cisco Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Jeffrey Groves
Jeffrey Groves
Mike
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
