Hi ericandmonac,
If you are getting the error message 70 on your Brother printer it usually means:
1. There's a paper jam.
2. Dirty encoder strip.(Most common reason)
3. Or the encoder strip is out of position.
4. There might be also something (piece of paper or any small object) that is stuck inside the machine.
To address this issue You should remove the top cover. Then, check inside for any possible piece of paper or dirt on the right or left most part of the carriage that is preventing it from moving. After clearing any jam turn off the machine and turn it back on again.
Hope it helps.
Thank you for using Fixya.
