The side marker light must be removed in order to get at the turn signal light.
There are two screws holding the side marker light which is situated above the turn signal.
Open the hood.
Remove the phillips head screw at the top of the side marker light.
Using a long #2 Phillips screwdriver, remove the screw on the outside of the side marker light. This can be seen by looking between the lower side of the side marker light and the top side of the turn signal.
The side marker can be moved.
The turn signal has one screw on the top of the fixture that must be removed.
Slide out the turn signal fixture. There is a small feature on the lower front corner of the turn signal fixture that you must note to properly reinstall the turn signal.
In order to get to the bulb, rotate the bulb socket 1/4 turn CW or CCW. The bulb socket is loose.
The bulb is simply pressed into the socket.
Not sure of the type, but it can be found at your locale auto parts store.
The bulb is used in several places on the 1994 GC, so get apacket with two, if possible.
Assembly in reverse. Be careful not to overtighten the screws as they are replaced.
