RCA TruFlat  27F520T 27" TV Logo
Posted on Mar 29, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i get the fpa lock off without the original remote?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 03, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
744
Points
How do i remove bloqueado without a remote
Level 3:
Top Expert:
  • RCA Master 76,851 Answers
  • Posted on Mar 29, 2011
RCA Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15004876
Points
237762
Hello
It is very difficult to unlock the FPA lock of RCA, without it original remote control. Just try to get it from anyone amoung your friends or relatives; just to open the FPA lock. You can use it after that, with the help of any other univrsal remote control. To open the FPA lock, do one amoung the following till you get the correct process for your TV.
Most RCA TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
  1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
  4. Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
OK.
5 Related Answers
Anonymous
  • Posted on Aug 06, 2008
SOURCE: FPA LOCK
I had the same problem on my rca tv. FPA was locked out. i lost the remote and could not turn the tv on.
i have the answer for you. yay me.
THE FPA CAN BE MANUALLY RESET BY DOING THE FOLLOWING.
YOU MUST QUICK CYCLE THE POWER.
DO THIS BY RAPIDLY PLUGING AND UNPLUGING THE POWER CORD FROM THE WALL OUTLET.
DO NOT UN PLUG IT COMPLETELY OUT OF THE WALL SOCKET. JUST FAR ENOUGH TO SEVER THE FLOW OF ELECTRICITY. YOU MUST GO IN AND OUT VERY FAST. AND WALLAH, PROBLEM FIXED. YOU CAN THANK ME IF YOU WISH. HAVE A GREAT DAY.
Anonymous
  • 119 Answers
  • Posted on Nov 03, 2006
SOURCE: FPA Lock
After doing a little research, it looke like the front panel lock , can only be removed from the parental control menu using your remote. If your universal remote does not get you into the menu, see if you can borrow a friends rca remote long enough to get you into your menu & remove the fpa.
Anonymous
  • 556 Answers
  • Posted on Oct 06, 2007
SOURCE: RCA 27V412T FPA LOCK ON & REMOTE LOCK
If the front panel lock is on, you will need a working original remote (or a universal remote properly programmed for RCA) to turn the set on. The IR receiver is next to the buttons on the fromt but the RCA IR receivers are very reliable, and I have yet to see a bad one in a modern RCA TV. Once you turn the set on by remote, you can enter the menu and turn the FPA off.
Anonymous
  • Posted on Jun 07, 2009
SOURCE: FPA lock on; have no remote control
FPA Lock On and have no remote for the TV on a RCA TV
Anonymous
  • 1961 Answers
  • Posted on Sep 20, 2010
SOURCE: i accidently locked the fpa how do i unlock it
Unfortunately, there is really no other way to unlock fpa other than using a remote control.
You can buy any universal remote control and this can be use to unlock fpa.
Good luck.
FPA lock is on
The FPA lock is a control panel lock to keep children, for example, from changing the channel or input by pressing buttons on the TV. You enable or disable the lock from the original remote control or one that matches all of the original's features. Only the power button will work with the FPA lock enabled. (The power button may only allow for turning off the TV.)
For directions on how to disable the FPA, you will need to add a comment with the make and model of the TV. Every manufacturer uses a different pattern to toggle the lock on and off.
I hope this helps.
What is FPA lock on mean
FPA locks the front buttons so children can not access programs without the remote. Use the remote to access the main menu then parental controls. On some models you might have to select special or chanell menu first. If FPA is on it will ask for a password. Turn off parental controls and all should work. This will require the original remote or a universal.
1helpful
How do you turn off the FPA lock on the RCA TRUFLAT TV? I Can't access menu.
Hello
First of all, you must ahve its original remote control to unlock FPA lock. If you have it, go through the folloing steps.
* Hold down Menu button on the remote control, and the Volume Down button on the at the same time for at least 4 seconds. "The set won't say so, but the lock will be released".
** Hold down Zero button on the remote control, and the Volume Down button on the TV. The set won't say so, but the lock will be released.
*** Hold down Menu button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. The set won't say so, but the lock will be released.
Is RCA 24V511T digital or analog? Also can I use a universal remote or do I need the replacement for the original remote that came with it? I
Hello
This CRT based tV is an anlogue one. You can use a universal remote control, except to unlock the FPA lock to this TV. By anyway, this TV has been locked with FPA lock, you must have its original remote control to unlock the lock. You can use most of the RCA universal remote controls with this TV.
RCA RCR 311W will be better. The setup codes are:
1000, 1002, 1004, 1005, 1014, 1025, 1078, 1081, 1095, 1096, 1097, 1098, 1099, 1100, 1101, 1111, 1128, 1130, 1132, 1134, 1144, 1146, 1149, 1171, 1205
OK.
4helpful
2answers
I have a TruFlat RCA model # 27F520T have lost original remote and FPA lock is on how do I unlock without original remote? Dish universal remote not working to unlock tv, it will pull up menu but cannot...
Try this -
  1. Press menu for main menu.
  2. Press CH + or CH - to highlight preferences.
  3. Press "OK" to enter preferences submenu.
  4. Press CH + or CH - to high light "FPA"
  5. Press VOL + or VOL - to turn the FPA on or off.
  6. Press MENU repeatedly to exit.
  7. Back to normal
  • FPA stands for Front Panel Lock. It makes it so kids don't push all the buttons on the front of your TV. The power button on the TV will still work and the remote will still function as normal.
Regards, Tony
10helpful
2answers
My tv wont come back on fpa lock on
Press Menu Button from any Remote control ( RC) by which could turn on your TV, press menu , menu drop down list will be visible on ur screen then wait 4 a minute or more till ur RC stop blinking , then go to Preference menu , go to FPA lock, turn it off. enjoy.
Deva
Lost orig remote/ fpa lock on
I have a 20f511t RCA Tru Flat with FPA lock on, using an universal GE remote press setup, then menu, channel down to preferences, press enter, channel down to FPA LOCK, volume up to change to on or off, press menu to remove, all shoud work now
RCA TruFlat 27F520T - FPA on and NO REMOTE
If you've lost the original remote there is nearly no possible way to unlock the unit. RCA built their PL so that the combination could be set and the parents would merely have to take the remote with them and it couldn't be changed...
As to the DVD I don't believe there is an input button on the face of the unit and I'm not real sure if you could find a universal that would allow that... Not even Miracle remote makes an alternative and their remoted are as good as the originals...
Sorry
Bill
14helpful
4answers
FDA Lock
I have never heard of FDA lock. If you mean FPA lock, this is the Front Panel Access lock (also called Child Lock) built into the TV. To unlock FPA, turn the set on with the original remote, enter the menu, navigate to the page with FPA and set it to off.
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
