Question about Car Audio & Video
Car Cd Changer Sony XR-CA370X no power
Hi, my car cd changer seems to have broken down yesterday, as there is no power to it at all.
It has one of those removable facias and I wondered if there was a loose connection between the facia and the main unit, but I tested the unit and there is no power to it at all.
I checked the fuses in the car, one by one and they're all fine.
Do I need to look inside the main unit of the cd player? And if yes, what and where do I need to look for in there
Any advise would be greatly appreciated.
Thanks, Robert
Posted by robertthe1st on
3 Related Answers
Anonymous
  • 4 Answers
SOURCE: Sony Cassette Car Stereo - 10 disc changer - XR-C5120R/XR-C5110R/xr-c4120
NEED TO REMOVE POWER FROM UNIT THERE SHOULD BE A BLACK CABLE THAT GOES IN TO CHANGER REMOVE IT WAIT 5 SEC AND INSTALL BACK LIKE IT WAS AND THIS WILL CUT ALL POWER TO UNIT AND WILL 50% FIX THE PROBLEM
LET ME KNOW
Posted on Jul 15, 2008
Anonymous
SOURCE: Remove CD Magazine - No power to unit!
I fixed my similar problem by applying 12v to the unit according to the pinout found here:
http://users.ntplx.net/~andrew/sony/unilink/
(note that -12v goes to the connector barrel)
Posted on Apr 06, 2009
xxxxxx xxx
  • 5013 Answers
SOURCE: remove cd player from car
Have a look around this site for the removal instructions
http://www.fitaudio.com/
Posted on Sep 12, 2009
Testimonial: "Very quick response. Thanks."
Need wiring diagram for sony xr-c8200.need to know what color wire is the power wire.
red is switched or ignition power, yellow is constant power, black is ground.
Feb 18, 2011 | Sony XR-C8200 CD Changer
Sony XR-C350 - cassettes get rejected
Hi I do not have a solution but my XR-C350 is having the exact same problem. I just had some repair work done on the car and the baterry had to come out. I have not reset the the system so I might try that? Any help would be greatly appreciated
Tony
Oct 10, 2009 | Sony XR-C350 CD Changer
Remove cd player from car
Sep 12, 2009 | Sony XR-C5100 CD Changer
Can't get it out of demo mode; radio/cd changer won't come on. reads only welcome to sony and shows clock.
try holding down the mode or power button... another menu should pop up... also refer to manual
May 28, 2009 | Car Audio & Video
I have a problem with my car Audio SONY XR-C300
hi i need to know the year make and model to help you with your problem and to clarify which head unit you are trying to install
May 16, 2009 | Sony XR-C300 CD Changer
Blaupunk car stereo
There could be a loose connection somewhere.
Does the sound stops on a regular time interval or only on certain conditions?
Would there be a chance that there's water leakage at the area where the CD changer is stored?
Jun 08, 2008 | Sony XR-C5100 CD Changer
In car audio
Hook the remote leads from your amplifiers to the blue/white wire at the back of the Sony head unit.
Dec 30, 2006 | Sony XR-4890 CD Changer
In car audio
hi sounds like you have the amps switching on via the aerial remote and not the amp remote. easy way to test this is to switch the AF or traffic function on your radio. if this cures the problem then you have the amp remote and aerial remote connected around the wrong way regards Mark www.carradiospares.co.uk
Car Audio & Video Logo
95 people viewed this question
Top Car Audio & Video Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
