Danze D500511BN Brushed Nickel Melrose?? Single Handle Pressure Balanced Logo
Question about Danze D500511BN Brushed Nickel Melrose?? Single Handle Pressure Balanced
Loud knocking when washing machine turns on (solenoid)
lbecker478
  • 86 Answers
This is caused by plumber not strapping pipes properly and probably not having air chambers install for knock...not much you can do unless you can get to pipe and strap...or spray with spray foam to set and secure pipes...
Posted on May 22, 2014
The outer Drum is making a knocking cluttering noise. When you manually turn the tub slowly round either clockwise/anti-clockwise it's like it's grabbing or unlodged itself off.
This is the typical sign of a collapsed bearing, it may be fixable but it depends on the age and brand of the machine if it's worth while fixing
Front loading washing machine makes loud knock on spin cycle
Move the empty drum by hands upp and down listen for noise, drumbaring my have been worne. Or is there some loose outside drum?
Air power bubble washing machine model -dwf -1150p
Daewoo Airpower Bubble Wash Machine Model - DWP - 1150P
My Machine does not want to spin anymore. It makes a knocking sound and then stops and starts filling up with water again, then drains it and wants to start spining and again makes a loud knocking sound and the repaets the already mentiond sycle. Can you help me with this problem? Does Daewoo not have service centers for these machines?
There is a loud knocking noise wehn my machine is on spin cycle, can you help?
Hello my name is Heath it will be my pleasure to assist you. The loud knocking you hear is the drum hitting the side of the machine from either a broken or disconnected balancing spring or shock.
2helpful
Loud knocking sound when in wash cycle GEWDSR2080
After taking off the front cover, look up at the top of the tub just under the lid. there should be a thick rubber strap at each corner of the machine tying in the tub to the top. These are called dampening straps. One or more may be broken. I usually replace all four if I do one.
Machine knocks and walks when spinning a small load
amke sure it is level and on a solid floor with little bounce.
Washing machine knocks in cycle
if its a whirlpool top loading washer, sounds like a bad motor coupling.( the machines equivilent to a belt.)
Loud Knocking
this is a collapsed drum bearing, one of the most costly of the repairs apart from the timer and motor, not normally a job for the diy man unless has an engineering background, sorry, the cost of repair depends on the age and replacement cost of a machine, a bit like a car, would you buy an engine for a 20 year old car, if you have a machine thats expensive then the repair could be worth it? stop running it you will cause more damage both to the clothes and the machine sorry (ps i am a retired appliance engineer of 20 years service)
Top Danze Home Experts
David Shaub
Mike
Paul Bade
Are you a Danze Home Expert? Answer questions, earn points and help others
