Question about LG LS-L1210CL Mini Split Air Conditioner
You can check LG's website on Air Conditioners that they manufacture at: http://www.lg.com/us/air-conditioners. you may be able to find a number where you can call them for further support. But I would check that website first. Do you know the Model/Serial Number of your unit? This is usually located on a metal piece attached to your unit. Having the correct Model/Serial Number of your product will help narrow your search for manuals to your question.
Posted on Dec 27, 2017
SOURCE: my LG air cond will only work when put on to manual ON
hi! there,
have you ever check the batteries,try to replace a new one.or if not function after replacing
try to clean the pads behind in any button of your remote.doing this open your remote there are quick lock in the side of your remote,use flat screw driver to loosen this be carefull to break the
lock,try to cleran the rubber pads by cotton buds
to remove oily debris and on circuit board if you have an eracer in pencil try to rub this gradually
until carbonize element disappear.then put back
pads and cover together and try.cheers and have a nice day don't forget to rate me thank's
Posted on Apr 04, 2009
SOURCE: LG Ductless Mini Split System LAN125hv: Heat pump doesn't run.
CA: Compressor Discharge Sensor Fault
Contact a qualified service technician and have them replace this sensor.
Posted on May 04, 2010
Mar 30, 2016 | LG Heating & Cooling
Sep 16, 2017 | Fujitsu ASU15RLQ Single Zone Wall Ductless...
Oct 21, 2011 | GE Quiet-Aire Ductless Mini Split System...
Jun 20, 2011 | LG LS-L1210CL Mini Split Air Conditioner
Nov 02, 2017 | Heating & Cooling
Aug 25, 2010 | LG Heating & Cooling
Feb 17, 2009 | LG Electronic Window Air Conditioner
Nov 16, 2008 | LG LS-L1210CL Mini Split Air Conditioner
Apr 27, 2008 | LG LSC121PMA Split System Air Conditioner
Jul 03, 2007 | LG 42PX4DR 42 in. Plasma TV
827 people viewed this question
