SOURCE: Motorola H700C Pairing with LG VX8700
im having a problem with my h700c and my lg too it was paired with a samsung and i got the lg now the phone phone the BT fine it just wont pair,wat can it be?
SOURCE: Will not let me connect the blue tooth to my phone
ur just a ********..haha nah jk
i got the same problem. help...
SOURCE: My jabra BT160 won't charge
i had the same problem with mine.
the problem is with the completely empty battery.
solution is to disassemble it and force charge the battery inside.
you have to cut any usb cable leaving the side which connects to pc and remove the insolation from red and black wires. connect them for few seconds to battery soldering points on jabra board (red to red, black to black, sometimes you have to scratch the solder a bit if it oxidized a bit). once you see the light you can start charging it normally.
SOURCE: BT-15K2 doesn't seem to hold a charge.
It is using Li-ion battery.Its life is short.If available try to replace it is the only solution.
SOURCE: bt-15k2 wont power up
You probably got a defective unit. Look at the manufacture date. If after rev072010 you're ok. Look bottom by the scan bar code for the date.
