Manual system
Electronic Automatic Temperature Control Module Self-Test
The EATC module self-test will detect concerns in the system control functions and will display hard diagnostic trouble codes (DTCs) in addition to continuous diagnostic trouble codes for concerns that occur during system operation.
To enter the self-test, press the OFF and floor position buttons simultaneously and then press the AUTOMATIC button within two seconds. The display will show a pulse tracer around the center of the display window. The test may run as long as 30 seconds. Record all DTCs displayed.
SOURCE: 2002 mustang GT serpentine routing
Hope this helps ya.. Cobra... :-)
Item
Part Number
Description
Generator pulley
Drive belt
8A528
Water pump pulley
3D673
Power steering pump pulley
5
63126
Crankshaft vibration damper
6
2E884
A/C clutch pulley
7
6B209
Drive belt tensioner
8
19A216
Belt idler pulley
9
19A216
Belt idler pulley
SOURCE: i need a fuse box diagram for ford mustang gt 2002
it is normally in the lid of the fuse box and in your owners manual but a dealership can also print you out one also you can get a 12 volt tester and locate the blown fuse that way
SOURCE: I need a fuse box diagram for a 2008 ford mustang
http://www.genuineservice.com/genuineservice/en/default?page=genuineService
Go to this website and pick owner guide in left task bar.Then input vehicle info and pick get owner guide. Then pick owner guide 3rd printing and your fuse info will begin on page 192.
SOURCE: A diagram of a 2003 Ford Mustang interior fuse box?
Fuse Box Diagram
Circuit Schematic
I trust that these are what you are looking for, they are screen captures of the requested information right from Ford.
SOURCE: Car wont start 2002 mustang gt dtc 1230 1233 codes
chec fuel pressure regulator it is in line of fuel next to engine-inpec for leaks insystem also-if u aquire a svc manual there is a list of codes or ask tech at dealer-look over ignition area to rule out
