Question about American Standard Plumbing
SOURCE: We have a Delta pop up drain in our bathtub. The
Drains are different. Try unscrewing it or pulling or even holding on to the inner most part while unscrewing .
Posted on Jul 05, 2009
SOURCE: eljer garden garden tub drain
Tub overflows are not required in all states but I highly recommend drilling the hole and installing the proper waste and overflow drain I recommend the Gerber brand and also when you set the tub you need to set it in a light concrete for stability I use great stuff foam for setting tubs 2 cans spray on floor and set and level tub tub will never wobble or move
Posted on Nov 15, 2009
SOURCE: Kohler bathtub drain seems to be disconnected from
Okay, remove 2 phillips head screws at lever handle/overflow.
Pull firmly with much effort and bowing the connecting rod a bit.
Up will come a heavy duty spring on the end of the rod.(prolly a big slimly hair ball too!)
Hope you get the spring, cause that's what works the drain stop.
If spring doesn't come out you'll have to "fish" it out.
Clean everything up real good and flush drain good also now.
The "Secret" now is to put the Lever,rod and spring assembly back in and replace screws and get the lever flipped to the left BEFORE you put the Drain Stop in.
Posted on Jan 01, 2010
Testimonial: "The info was very helpful and thanks for the "secret"!"
SOURCE: removing a lift and twist type of drain plug to get at trap (scal
yes it can be changed without removing the tub, but you must open up wall, floor whatever it takes to be able to see all this drainage, as you can see, you can't change the parts from in the tub,.....good luck, cracklin joe
Posted on Jan 08, 2010
SOURCE: my tub overflow and bottom drain appear to be
yes,1 1/2 in slip tail piece extension
Posted on Apr 19, 2010
Testimonial: "thank you"
Dec 18, 2017 | Coby TF-TV3217 32 in. LCD TV
Dec 24, 2013 | Geberit Bath Waste and Overflow Tub Drain...
Sep 09, 2012 | NAD Audio Players & Recorders
Aug 18, 2011 | Jacuzzi Home
Apr 07, 2011 | Home
Jan 05, 2011 | Jacuzzi 8730-829 Bath Rotary Drain Kit,...
Apr 20, 2010 | Moen Home
Dec 30, 2009 | Kohler Plumbing
Jul 24, 2009 | American Standard 2771.018WC.222 Cadet 5'...
Jul 12, 2009 | Jacuzzi 8730-829 Bath Rotary Drain Kit,...
Nov 01, 2017 | American Standard Plumbing
133 people viewed this question
