Question about Samsung PCL5415RB 54" Rear Projection Television
Almost every day our t.v. fades in&out for a few seconds. Maybe once. Maybe twice or more. It's seems to be the back ground of the picture. It's during the light of the day. Good color. No other issues & we really like set. It's 46" LED. we bought @ Xmas. Can you help. R.Barg 586-731-6060. THANK YOU
Posted by rlbarg on
5 Related Answers
robert landry
  • 96 Answers
SOURCE: PCN5425R Fading in and out
No It is not the picture tube.
First, I would suspect a bad solder connection (cold solder connection) to find this problem hit the side cassing to see if the picuture goes away or comes back.
Another way is take the back cover off and tap gently on the boards with something not conductive or your hair would look like mine. The most commond section is power supply and neer the Horizontal flyback transformor.
The horizontal transformor look at it, it's a big greyish darty little thing about 3" x 4" and stand up about 4" with a big red wire going out of it. Don't touch it, it has very high voltages, just look what it done to my hair I'm telling you don't touch it along with it's red lead's. Just look to see if it is arking if so replace it.
When you have convegence problem , it is mis aligment of the colours in the genmentry aligments.
I would suspect more in the power supply section.
Regards
What about Bob
Timmins, Ontario
Home of Shania Twain.
Posted on Mar 08, 2008
Anonymous
  • 3587 Answers
SOURCE: Yellow Tint over picture...
well..it's simple really...yellow is from a degrading video unit and system board..so, you'll find that it's high time for a major service situation.
Posted on May 10, 2008
Nick DelRegno
  • 49 Answers
SOURCE: HL-R6768W not turning on. High pitch spin sound. Bad color wheel?
The high-pitched whine is definitely the color wheel.  The early color wheels had problems and many had to be replaced.  As part of the turn-on process, the TV checks for light and then checks for color wheel sync.  If the bearings are wearing out/dried out, it could cause issues with getting the proper color wheel sync, causing the set to not pass the turn on sequence.
Check Sears or partstore.com for a color wheel.  I like sears for experimental replacements since they allow easy returns.
BTW, mine is an early 61".  My color wheel was replaced when I had to replace my Light Engine.  My in-laws 50" was an early one and theirs went out within 2 years.
Posted on Jan 24, 2009
Anonymous
  • 184 Answers
SOURCE: HLN5065W picture turns black and white and shuts down
Sounds like your color wheel may be at fault. Do you ever hear any unusual noises coming from the rear of the TV? Color Wheels usually make a humming sound as they go bad. This is because the tiny bearings in the color wheel motor have begun to misshape from use and heat. This is a known issue in this TV! Expect to spend $300-500 to have this serviced by a service company. If you have the right stuff, you can do it yourself. If you search the web, you'll find a color wheel for this TV for under $100, but installation can be tricky.
michtech
Posted on Feb 16, 2009
Anonymous
  • 304 Answers
SOURCE: 46 Picture issues.
The Digital bd has gone bad and needs to be replaced. Part# is BP94-02065A
Posted on Jul 16, 2009
TV picture randomly fades to black. Bang on sides and pix comes back for few monents b4 fading out again. TV works great except for this one little problem---no picture.
You have an aging TV with a very common problem . The board inside by now has many bad solder grounds. The grounds would inculde resoldering the vertical IC chip. It is located on a large heatsink. And check solder grounds on the horizontal output transistor also mounted on a heatsink. The horizontal transformer is another suspect, resolder this. Check for grounds on large resistors and the flyback transformer. Also make sure there is a good connection on the suction cup that is mounted on the back of the picture tube. Please be careful when checking the connection on the suction cup..quite a powerful shock. Also be sure you have good solder grounds on the small board that is connected to the picture tube. This should restore the video on your TV. Be very careful and good luck. Thanks for asking and show a few hands of support.
Dec 15, 2010 | Mitsubishi CS-36309 36" TV
Whites in tv picture fade to blue. White helmet, white shirt, white sidelines, etc. Same on regular and HD. Thanks, Randy
This maybe very complex to analyze. Condensation maybe the first suspect; use a fan to dry it out, while you are watching TV. Contact resistance maybe the second suspect. You pat gently on sides of the TV to move the lcd contacts to other circuits. You might be lucky to get the picture back to normal. The last suspect is moisture in the lcd, use your TV all day all night to see if the moisture will burn off. You might get lucky doing all three solutions.
Nov 22, 2010 | Televison & Video
The machine struggles to move grounds through after brewing. The tray seems to be locked in.
Your brew unit is probably dirty and needs cleaning. However, it won`t always help just running the cleaning program. Try to clean out all the used ground that is stuck inside the brew unit; use your fingers or a toothbrush maybe. Then run the cleaning program. It may be smart to run the program once or twice after this too, but you don`t have to use the tablet everytime.
It is the grounds blade that holds the used ground container so you can`t get it out. This means that the brew unit stops in a wrong position, and don`t get back to grinding position before timeout. If you shut down the machine for a few hours, it usually moves back during startup. But of course; this indicates that you need to clean up inside...
Jul 16, 2009 | Jura Capresso Impressa S8 Coffee Maker,...
Monitor picture fades out.
I thought my problem was originally monitor related. However since I posted, the picture disappeared altogether, and my PC wouldn't even start to bootup. Fearing my mobo may have died I removed the hardware components, cleaned then re-assembled them. After all that, it turned out that my graphics card has a tendency to become slightly unseated. Once I was aware of this problem booting up resumed normally. It seems that the problem of the fading monitor picture seems to still occur, but soon after I use the machine after 'hibernation' state, and even then it doesn't always occur if I do use hibernation. I haven't used hibernation for a little while and so far the problem has not returned
Mar 28, 2009 | NEC Mitsubishi Diamond Pro 920 19" CRT...
Regards
What about Bob
Timmins, Ontario
Mar 08, 2008 | Samsung PCN5425R 54" Rear Projection...
Spontaneously shorted, now blowing fuses on amp too.
Time to go to the repair shop. Sounds like you have a blown amp. Good luck.
Feb 22, 2007 | Rockford Fosgate Punch P4004 Car Audio...
Power Problems on NEFF H7871 Combi Microwave
It would seem there is a bad connection in the fuse holder or in the wall socket or in the microwave itself. Maybe you can narrow it down to the microwave by trying other devices in the wall socket. If it's the microwave, it's time to call for serivce.
Dec 11, 2006 | Neff H7871N2GB Convection / Microwave Oven
Samsung PCL5415RB 54" Rear Projection Television Logo
Demonic-2011
Demonic-2011
