Question about Logitech ClearChat Stereo Headset Headset
Logitech usb headset problem
Sound not switching over to usb headset when playing game on windows vista. When we plug in the headset in our new windows vista computer, we can hear sound from the headset. But when we startup the counterstrike source game, the sound from the game is still coming out of the speakers that are built into the monitor.
Posted by datiyeh on
  • Anonymous Nov 24, 2008
    I just went out and bought a new logitech headset for my computer because my old USB headset kicked the bucket. I'm running the 64 bit version of windows vista on my computer. My headset works just fine for vent, but when I try to run counterstrike source and tell it to output on the headset the sound continues to come out the speakers. Any suggestions?
5 Related Answers
Anonymous
  • 5 Answers
SOURCE: No sound from my Logitech headset when on SKYPE
Maybe you need to select which Audio device you are using within Skype. It the Settings under Audio you should be able to select the default audio device that Skype talks to. If you set it to the USB headset, it might work properly.
Posted on Nov 10, 2007
Anonymous
SOURCE: logitech clearchat pro headset
I WASTED 40 ******* DOLLARS ON A PIECE OF **** THAT DOESNT WORK ALL IT DOES IS MAKE A ******* SPUELLING NOISE
Posted on Jul 03, 2008
praky16
Prakash Ram
  • 744 Answers
SOURCE: logitech headset not working
did u connect both the output wires from ur headset to ur system audio port.?
Posted on Feb 08, 2009
Anonymous
  • 18 Answers
SOURCE: my speakers are built into my monitor how do I
try controll panel / sounds and audio devices.
Posted on Jul 14, 2009
Anonymous
  • 6 Answers
SOURCE: want to turn off logitech headset and turn on monitor speakers
I know this works on Windows XP:
Settings -> Control Panel -> Sounds and Audio Devices -> Audio Tab
Select your normal input/output from the dropdown list (not the one that says Logiteck USB headset)
Important step - Close the program you were trying to change the audio for, and open it again. It should work. If not, leave it for a minute and try again.
Posted on Aug 25, 2009
ClearChat Pro USB headset asks for driver upon install
  1. (Vista) Confirm your system restore point first. It needs to be prior to what you're going to attempt here. If it has a recent restore point, great, but if not, make a system restore before you do this, in case it doesn't work.
  2. In the Control Panel, click System, Advanced System Settings, click System Protection, and click System Restore.
  3. (Optional) Try updating your usb drivers before trying the final step, reinstalling the Vista Service Pack 2.
  4. Here's how to verify if your USB (drivers) in the Device Manager are up to date.
  5. Open the Control Panel, System, Device Manager.
  6. Open the Universal Serial Bus controllers (usually at the bottom of the device list).
  7. Right-click, on your first USB, Updating Driver Software. It will look for the update or let you know (which may take a bit of time) that it is up to date already. Repeat this process on all the USB devices.
  8. If that doesn't work, try this: plug in your headset, and keep it plugged into the usb.
  9. In your Windows Updates, re-install the Service Pack 2. After Vista reboots your computer and finishes the install, unplug your headset from the USB and then replug it in. What you are likely to see is a Windows message indicating that it sees the software and is installing it (minus the windows pop-up message of "where's the driver disc for it?").
  10. Now the trick is to get the headset to play the microphone through the speakers appropriately!
Oct 20, 2009 | Logitech ClearChat Pro USB Headset
Logitech ClearChatStyle Headset + Skype + Vista Premium Home
Vista always has sound card problem.
I had too because with my headset (microphone) It works through your sound card
but it works well now after I installed it as below
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=US&swItem=ob-78911-1
ADI SoundMAX Integrated HD Audio Driver for Windows Vista
Hope can help
Aug 15, 2009 | Logitech ClearChat Stereo Headset Headset
I'm thinking of buying Logitech USB Desktop Microphone but I want to know if it works well with multiplayer games because that what i would use it for. I haven't been able to find any info on how the mic...
Yes, this mic does work well. Headset usually work the best, but I do know a few people who use this mic for their gaming.
Control and convenience
  • Advanced digital USB: Experience superior sound clarity with the simplicity of a single USB plug-and-play connection.
  • Noise-canceling microphone: Filters out unwanted background noise.
  • Power switch: Illuminates when microphone is active.
  • Adjustable microphone: Pivots on base to hold preferred position.
  • Eight-foot shielded cord: Gives you more desktop flexibility.
  • Mute switch on base: Instant and easy muting.
  • Weighted base: Adds stability.
Technical Specifications
    • Frequency response: 100 Hz–16 kHz
    • Input sensitivity: -67 dBV/µbar, -47 dBV/Pa +/- 4 dB
    • 8-foot shielded cord with USB connector
    • Connector: USB 1.1
YOU CAN GET USER REVIEWS HERE:
http://www.google.com/products/catalog?q=logitech+usb+desktop+mic&oe=utf-8&rls=org.mozilla:en-US:official&client=firefox-a&um=1&ie=UTF-8&cid=16452149199579405298&ei=GyxWSr-ePIrQM7aJvZ0I&sa=X&oi=product_catalog_result&ct=result&resnum=5#ps-sellers
Jul 09, 2009 | Logitech USB Desktop Consumer Microphone
Lose webcam connection in Skype when using a headset
Have you checked the recording settings in Windows and in Skype? Try changing the default recording device to specifically indicate the device that has your headset plugged. I think the webcam also has a mic and that should not be selected.
Other thing to check is if there is some kind of resource conflict between your USB controller and audio card (use Device Manager).
Jules
Mar 02, 2009 | Logitech Quickcam Chat Webcam
Logitech usb headset A-0374A does not play
probably need to set the Logitech headset as your default device in Control Panel-Sound. XP or Vista updates may reset the audio-video default devices
Nov 19, 2008 | Audio Players & Recorders
My Ps3 Headset -- LOGITECH
This sort of happened to mine, but i just switched my headset output to the default, so it comes out my telly instead of the ear piece...
Hope this helps
Feb 21, 2008 | Logitech (980174) Headset
Vista and logitech phones
Maybe Sound Card problem Vista always has sound card problem.
I am using Vista 32-bit, Logitech Clear Chat Style
Hope can help
Dec 27, 2007 | Logitech ClearChat Stereo Headset Headset
Logitech headset usb A-0356A
Ok, here is what might help, goto control panel, sound and audio devices,then audio. click the pop down list and see if it is there, that is how i got my plug and play to work on my 250....
Nov 13, 2007 | Logitech 250 Headset
Check to see if the headset plugs are into the right port. If you still have problem let me know of your operating system: » Microsoft Windows Vista » Microsoft Windows XP
Oct 06, 2007 | Logitech 250 Headset
Logitech ClearChat Stereo Headset Headset Logo
Top Logitech Radio Communications Experts
Ekse
Marvin
Marvin
Are you a Logitech Radio Communication Expert? Answer questions, earn points and help others
