Question about Fuji FinePix A120 Digital Camera
I have a fuji finepix A120 and would like to get a new xd card but i dont know where to buy one.and what kind is compatiable with this type of camera.. i bought an olympus 2gb but it does not work its says not initialized &when i do format it it then says write error? so where and what kind do i need to take more pics?
Posted by dragongir662 on
5 Related Answers
Anonymous
SOURCE: Card not initialized
While the camera is on, press menu and go all the way to the right. Choose "Set-up" and it will take you to a window with several tabs. Choose the tab called "1" and then choose to format the card here.
Posted on Jun 11, 2007
Anonymous
  • 133 Answers
SOURCE: Fuji FinePix 3800 Initialization glitch
Yes, you'll need to format the xD Picture Card. You may be able to do this inside the camera in the options, if not - you'll need to connect it to your computer to get it to appear as a drive letter in "My Computer". Select the new drive in My Computer, this will be your card, right click it and click Format, then proceed to format it. This should sort your problem out.
Posted on Sep 07, 2007
Anonymous
Turn camera from "off" to "play" ( photo view..._
Pressing the “MENU/OK” button as you would to erases files. There is an option to format the xD-Picture Card. Formatting erases protected files, but allows you to then take photos.
Posted on Dec 31, 2007
Anonymous
  • 423 Answers
SOURCE: I cannot get card to work in my fuji finepix a 340 says write error
If your new xD card is an "H" or "M" type card, it is only compatable with the A340 following a firmware upgrade to the camera. http://www.fujifilm.ca/x3721.xml is a link to the software and steps you can take to perform the upgrade.
Posted on Apr 09, 2008
Tazman_138
  • 6 Answers
SOURCE: xd picture card
You will need to do a firmware update to be able to use your new 'M' XD card. Also you will need a AC adapter to be able to use the update for your camera.
It is a Fuji site and it works.
Good luck.
http://www.fujifilm.ca/x3719.xml
Posted on Jun 10, 2008
From where I can buy memory card for finepix E510 camera
The Fuji Finepix E510 takes a memory card type called "xD Picture Card". You can buy it most retail stores, but you'll save a lot of money buying online.
The Upgrade Place has low prices and a Camer Memory Finder Tool. See the capacities available and click to buy xD Picture Cards at discount prices here: FujiFilm FinePix E510 Memory Cards
May 12, 2010 | Fuji FinePix E510 Digital Camera
Memory card won't work
Try this site for a firmware update. You need to get a AC power adapter for it to work though. It is from Fuji and it worked fine for my A120. The older XD cards are of a different format then the newer ones so if your new XD card has an 'M' on it you will need to do the firmware solution.
Good luck
May 31, 2008 | Fuji FinePix A120 Digital Camera
NEW CARD
Good luck.
May 26, 2008 | Fuji FinePix A120 Digital Camera
Xd picture card
Good luck.
Fuji finepix a120
format the card in your camera may solve the problem
Mar 19, 2008 | Fuji FinePix S5000 Digital Camera
Internal memory fuji finepixa820
the only way to prevent it is buy a XD card
Fuji Finepix S7000 Zoom Memory Cards (xD-Picture Card - M Type) & Accessories The following memory cards are compatible with your Fuji Finepix S7000 Zoom. Every memory card we offer is manufactured to the highest standard and carries a 2 year minimum warranty. Your Fuji Finepix S7000 Zoom accepts xD-Picture Card - M Type cards. The largest xD-Picture Card - M Type card you can use in your Fuji Finepix S7000 Zoom is 2048MB
View all Fuji Digital Cameras
Feb 18, 2008 | Fuji FinePix S7000 Digital Camera
FUJI A350
dont know if this helps but i had a problem that was similar, turns out card is not compatible, check here to see if you have a compatible card
http://www.fujifilm.com/products/digital_cameras/accessories/card/index.html#compati
Nov 26, 2007 | Fuji FinePix A350 Digital Camera
Problem with new XD card
This could possibly be a problem with the card reader ..Just insert a different card and see if it works..If it reads other cards..then i advice that you get new card coz the recovery softwares and stuff r pretty expensive and will be a waste of money..
Oct 30, 2007 | Fuji FinePix A120 Digital Camera
Fuji FinePix A120 Digital Camera Logo
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Rob Hill
Rob Hill
Are you a Fuji Camera Expert? Answer questions, earn points and help others
