Question about Riso RZ220 Duplicator
We have problem in our riso rz 230 the problem is that whenever changing new ink cart. only 60% ink is consumed and an error shows replace ink cart. C01-563 and if we are checking through test mode the machine shows 0% ink is left.and the Ink Cart. becomes useless, it cannot be used in other machine also.
Posted by braj_comp on
R Daniel Wolfe
    Master:
  • 469 Answers
Clean the cartridge with alcohol, dry, put it back in .
Posted on Dec 31, 2017
3 Related Answers
Anonymous
  • 19 Answers
SOURCE: Riso GR 1700 OK light will not come back on ,nor will it release
switch on the machine and press the astrex button left of the zero button. The code that comes on the display would be helpful. or you you could shoot in the dark and reset the machine by switching off holding down the 2 top right side buttons and switching on the machine. Then release the buttons and off and on with machine.
Posted on Apr 02, 2009
Anonymous
  • 17 Answers
SOURCE: i have a problem error fo115 of riso rz-220
F01-115 means no master on drum at start of printing. Make sure you make a master before trying to print.
Posted on Mar 30, 2010
Anonymous
SOURCE: risograph rz 200ep shows error code d-139
ereur 101
Posted on Apr 27, 2010
Master roll rz
yes but it is always good to use original consumables. plus if your unit is under warranty, you can ask for help with the company anytime.
Jan 22, 2014 | Riso RZ220 Duplicator
Riso rz 390
There should be a built in head cleaner. I think you can access it through the control panel, then device and printers. right click on the printer with the issue, scroll down to printer properties. there should be a box that says "print test page" when the test page prints it should ask you if it is ok, this is where the clean head should be.
Jan 18, 2014 | Office Equipment & Supplies
Risograph rz 230 ep
Reset the printer & copier, according with your owner manual.
Please make autodiagnostic, read your owner manual.
However if the problem persist, go to website from your supplier and get support free via ONLINE chat.
God bless you
Jul 24, 2013 | Office Equipment & Supplies
Error code P98 on riso
what this problem for Erorr P98 Riso RZ 230 AW
Nov 28, 2012 | Riso RZ390 Duplicator
RISO RZ 990 Error code D17-237
i think your copier was not used for a long time , so the nozzles inside the drum unit are dry and blocked and you are getting d17 -237 , that over ink on one side of the drum and not evenly covered with ink . you need to take off the drum unit and if possible open it , take off the film , and get inside and clean the nozzles . if not , you will be forced to change your drum unit .
Jul 28, 2012 | Riso Office Equipment & Supplies
Somebody that speak Spanish? Riso RZ 220 UI have a code that say P18 531. What is the problem?
P18-531 means: Print drum lock sensor is still ON even after 100 milliseconds after the print drum lock solenoid is activated.
Mar 16, 2011 | Riso RZ220 Duplicator
Error Code -534 on my Riso RZ 390. Drum is stuck in machine and won't release.
D04-534 means incorrect ink cartridge set. This could be caused either a) it IS the incorrect ink cartridge, or b) the RF tag that is struck to the end of the ink bottle is damaged. Try a new ink bottle.
Make sure to use RISO ink designed and made specific for an RZ230.
Jan 03, 2010 | Riso RZ390 Duplicator
Riso 390 has error code d4-534
The machine do not reconise the ink.At the back of the ink there is a electronic chip that tells the machine what tipe of ink it is.There is a problem with that chip or the ink is not compatible.Replace your ink in most cases this will solve it,but let me know if I can futher assist.
Thanks for supporting us.
Dec 11, 2009 | Riso RZ220 Duplicator
What does the error code E 01 stand for?risograph 4050
If its CR or TR, E-01 is main motor lock. turn off machine and hold reset button in while you turn the machine on again. Make sure your master removal unit and master feed unit are closed corectly.
Apr 07, 2009 | Riso RZ220 Duplicator
346 people viewed this question
Top Riso Office Equipment & Supplies Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Muntejaya Ginting
Muntejaya Ginting
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
