I will check the shop manual, but the module does control ride for stiffness, increased stiffness at higher speeds, etc. If the bags are inflated, then the module cintrols how much air to allow in or out based on inputs to the module. See if you can get one from a salvage yard form a cash for clunkers car.
A dealer can run a test for fault codes in the computer. Call and ask how much for just a scan for fault codes in the air suspension module.
Vehicle Dynamic Suspension
The vehicle dynamic suspension consists of the following components:
- Rear air suspension control (RAS) module (5A919)
- Snorkel
- Drier
- Air compressor (5319)
- Air suspension switch (5K761)
- Solenoid valve (5311)
- Air spring (5560)
- Air suspension height sensor (5359)
- Air line
Rear Air Suspension Control Module
A microprocessor controls the air suspension system. The microprocessor and its supporting hardware are contained in the rear air suspension control module. The rear air suspension control module responds to signals from various sensors in the vehicle to maintain the programmed ride height while the vehicle is either moving or stopped. The rear air suspension control module accomplishes this by opening and closing solenoid valves to control the amount of air in the air spring(s). The rear air suspension control module turns on the compressor by applying voltage through the compressor relay to inflate the air spring(s) and raise the vehicle. The rear air suspension control module opens the vent solenoid to lower the vehicle by releasing air from the air spring(s) in response to signal inputs from the air suspension height sensor(s).
Air Suspension Switch
CAUTION: The air suspension switch must be turned to the OFF position when the vehicle is hoisted, jacked, towed, jump started, or raised off the ground, to avoid unnecessary operation of the system and possible damage to the air suspension system components.
The air suspension switch provides a signal to the rear air suspension control module in the ON position to activate the system to maintain the programmed vehicle height.
Air Compressor
NOTE: The compressor contains a thermal overload circuit breaker. The circuit breaker automatically resets after a cool down period and after being tripped by excessive compressor motor heat.
The air compressor assembly consists of the compressor pump, electric motor and vent solenoid (must be installed as an assembly).
Air Suspension Height Sensor
The air suspension height sensor sends signals to the air suspension control module. There are three possible conditions that the air suspension control module interprets from the signals of the air suspension height sensors. The conditions are trim height, below trim height, or above trim height.
Solenoid Valve, Air Spring
WARNING: Never rotate an air spring solenoid valve to the release slot in the air spring end cap fitting until all pressurized air has escaped from the air spring to prevent vehicle damage or personal injury.
The air spring solenoid valve allows air to enter and exit the rear air springs during height adjustment operations. The air spring solenoid valve is electrically operated and controlled by the air suspension control module.
Steering Sensor
The steering sensor provides the steering rate and position to the air suspension control module to avoid overcompensation of the air suspension during turns.
Inspection and Verification
- Verify the customer concern.
NOTE: If the door ajar indicator is illuminated, repair the door ajar indicator. For additional information, refer to Section 413-09 .
Visually inspect for obvious signs of mechanical and electrical damage.
Visual Inspection Chart
Mechanical
Electrical
- Restricted suspension movement
- Excessive vehicle load
- Cut, severed or crimped air line(s)
- Incorrectly mounted, damaged or disconnected height sensor
- Damaged air spring(s)
- Central junction box (CJB) Fuse:
- Battery junction box (BJB) Fuse 12 (30A)
- Loose or corroded connectors
- Damaged air spring solenoid(s)
- If the concern remains after the inspection, connect New Generation STAR (NGS) Tester to the data link connector (DLC) located beneath the instrument panel and select the vehicle to be tested from the NGS Tester menu. If NGS Tester does not communicate with the vehicle:
- check that the program card is properly installed.
- check the connections to the vehicle.
- check the ignition switch position.
- If the NGS still does not communicate with the vehicle, refer to the New Generation STAR Tester manual.
- Carry out the DATA LINK DIAGNOSTIC TEST. If NGS Tester responds with:
- CKT914, CKT915 or CKT70 = ALL ECUS NO RESP/NOT EQUIP. Refer to Section 418-00 .
- NO RESP/NOT EQUIP for rear air suspension control module, go to Pinpoint Test A.
- SYSTEM PASSED, retrieve and record the continuous diagnostic trouble codes (DTCs), erase the continuous DTCs and perform self-test diagnostics for the rear air suspension control module.
- If the DTCs retrieved are related to the concern, go to Rear Air Suspension Control Module Diagnostic Trouble Code (DTC) Index to continue diagnostics.
- If no DTCs related to the concern are retrieved, proceed to Symptom Chart to continue diagnostics.
NOTE: If rear air suspension control module C251 is disconnected before rear air suspension control module C250, DTCs C1830, C1770, C1790 and C1795 will be retrieved and must be cleared before an accurate list of continuous DTCs can be retrieved. The DTCs C1441 and C1442 will only be retrieved when running the electronic variable orifice (EVO) functional test on NGS Tester. The DTC C1897 will only be retrieved once per ignition switch cycle.
Module —Air Suspension Control
Removal
WARNING: Before performing maintenance on any air suspension components, disconnect the power to the system by turning off the air suspension switch located on the LH side of the luggage compartment to prevent vehicle damage or personal injury.
CAUTION: Electronic modules are sensitive to static electrical charges. If exposed to these charges, damage may result.
- Turn the air suspension switch off.
- Disconnect the battery ground cable (14301).
- Pull out the lower instrument panel insulator.
- Remove the pushpins.
- Remove the lower instrument panel insulator.
- Disconnect the power point.
- Disconnect the courtesy lamp.
- Remove the rear air suspension control module.
- Remove the screws.
- Disconnect the electrical connectors.
Installation
NOTE: When the battery is disconnected and reconnected, some abnormal drive symptoms may occur while the vehicle relearns its adaptive strategy. The vehicle may need to be driven 16 km (10 mi) or more to relearn the strategy.
To install, reverse the removal procedure.
compressor ingages but the blower wont start. intermitting.
compressor ingages but blower wont start intermitting
