Hi I have a 1995 Jeep Grand Cherokee Limited with the infinity cd radio. I hav not tried the cd player but I know that the radio works fine FM only AM does not work. The LED light does not light up. All of the buttons light up when I put on the lights. I am so confused. Any help is grately appreciated. If I need a new radio does anyone have any reccomendations on were to buy one?
THANKS!
The display goes out due to heat causing a surface mount resistor to lift off the top circuit board in the upper left part of the board.
I replaced mine with a radial lead resistor raised above the board, and the display has been working since 2012. Can't remember if it was a 15 Ohm or 15k Ohm resistor that I pulled from an old scrap TV board.
There is a YouTube video with the fix and correct resistor.
It sounds like the radio is defective, but check the fuses that power it 1st, if they are all ok then you can get a used working radio on Ebay, have bought them there myself with no problems, cost was reasonable.
My clock display went out on my infinity radio for a 99 Jeep Grand Cherokee. The radio/cd player work fine.
I haven't torn into it to figure out where power for the display comes from.
