2000 Pontiac Montana Logo
Posted on Mar 21, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The winshield wipers on my 2002 montana are not moving. The motor works but wipers do not move. I can tighten the screw in the middle but there appears that there should be one ot two pins inserted vertically through the two or three plates. The top plate has a center hole for the hex screw and two other holes - one just off center and the second one on the outside edge. A second lower plate has a counter clockwise curved slot from the interior to the ouside edge. There is a bottom plate as well. A loose pin was found partially inserted into one of the top plate holes. The pin can be inserted all the way through the three plates - top outside hole, curved slot middle plate and the bottom plate, however, there is nothing to keep in place - seems to be missing a retaining clip. Do I need a new pin with retaining clip or do I need two pins? If I had labelled pictures of a correctly assembled unit it would be helpful. At this point I
warren forbes
Level 2:
Scholar:
  • Expert 113 Answers
  • Posted on Mar 28, 2011
warren forbes
Expert
Level 2:
Scholar:
Answers
113
Questions
0
Helped
27207
Points
228
Sounds like to me that part is just worn out and you should just replace the whole unit and be done with it.
Windshield Wipers park in the up Position
tRY REMOVING THE WIPERS WHEN IN UP POSTION AND REINSTALLIMG THEM IN THE DOWN POSTION THEN TURN THE WIPERS ON AND SAEE WHAT HAPPENS THEN . ALSO CHECK ALL MOUNTS ON THE WIPER MOTOR AND ANY ADJUSTMENT LINKAGE TO SEE IF THEY ARE LOOSE AND MOVED IN ANY WAY
1helpful
Windshield wiper motor/crank arm on top
Heat or something like Pb Blaster
Engine schematics 2002 pontiac montana
Hi there:
Isnt a diagram but If you have removed the motor, here is the motor installation procedure....
INSTALLATION PROCEDURE
Align the wiper motor to the wiper drive system module. NOTE: Refer to Fastener Notice in Service Precautions.
Install the wiper drive system module to wiper motor screws. Tighten Tighten the wiper drive system module to wiper motor screws to 7 N.m (62 lb in) .
Connect the electrical connector to the wiper motor.
Install the crank arm on the wiper motor.
Rotate the washer solvent container into the installation position.
Install the washer solvent container screws. Tighten Tighten the washer solvent container screws to 6 N.m (53 lb in) .
Inspect the wipers for proper operation.
Also, here is the crank arm procedure...
REMOVAL PROCEDURE
Remove the wiper system module cover.
Remove the drive link from the wiper motor crank arm.
2.1. Loosen the drive link screws.
2.2. Remove the drive link from the wiper motor crank arm.
Remove the wiper motor crank arm cover and seal.
Remove the wiper motor crank arm from the wiper motor.
4.1. Loosen the wiper motor crank arm screw.
4.2. Tap on the wiper motor crank arm screw with a soft-faced mallet while holding up on the wiper motor crank arm until the wiper motor crank arm loosens from the wiper motor.
4.3. Remove the wiper motor crank arm screw and the wiper motor crank arm from the wiper motor.
Install the wiper motor crank arm onto the wiper motor.
1.1. Turn the ignition switch to the ACCY position.
1.2. Set the wiper switch to PULSE position. The wiper motor should be operating.
1.3. Turn the ignition switch to OFF when the wiper motor is in the innerwipe position.
IMPORTANT: Do not rotate the wiper motor shaft during the installation of the wiper motor crank arm.
1.4. Install the wiper motor crank arm on the wiper motor while maintaining a 4-8 mm (0.157-0.315 in) gap between the V-grove in the wiper motor crank arm and the tab.
Install the wiper motor crank arm screw. Tighten Tighten the wiper motor crank arm screw to 16 N.m (12 lb ft) .
Install the wiper motor crank arm cover and seal.
Check the gap between the wiper motor crank arm and tab. If the gap is not 4-8 mm (0.157-0.315 in) , remove the wiper motor crank arm and repeat installation steps.
Install the drive link onto the wiper motor crank arm.
Install the drive link screws. Tighten Tighten the drive link screws to 5 N.m (44 lb in) .
Install the wiper system module cover.
Additional procedures: Wiper Motor Module Replacement.
TOOLS REQUIRED
J 39822 Wiper Arm Puller
REMOVAL PROCEDURE
Set wiper switch to the PULSE position.
Turn the ignition off when the wiper arms are in the innerwipe position and not moving.
Disconnect the washer hose from the washer nozzle.
Remove the cover from the wiper arm nut.
Remove the wiper arm nut from the wiper transmission drive shaft.
Using J 39822 remove the wiper arm from the wiper transmission.
Remove the wiper blade from the wiper arm.
Clean the knurls of the wiper transmission drive shaft with a wire brush.
Install the wiper blade onto the wiper arm.
Install the wiper arm onto the wiper transmission drive shaft. IMPORTANT: Hold the measuring device at 90 degrees (perpendicular) to the wiper blade tip.
Measure the distance from the wiper blade tip to the solid edge of the windshield blackout. Position the wiper arms at the following distances:
LH - 147 mm (5.79 in) above the glass blackout.
RH - 123 mm (4.84 in) below the glass blackout.
Install the wiper arm nut onto the wiper transmission drive shaft. Tighten Tighten the wiper arm nut to 48 N.m (35 lb ft) .
Install the cover on the wiper arm nut. IMPORTANT: Lubricate the washer hose with the windshield washer solvent to ease installation on the washer nozzle.
Install the washer hose on the washer nozzle.
Remove the wiper arms from the vehicle.
Remove the air inlet grille panel.
Remove the wiper motor.
Remove the air inlet panel to wiper motor module screws.
Remove the wiper motor module from the vehicle.
Remove the insulators from the wiper motor module.
Install the insulators onto the wiper motor module.
Align the wiper motor module to the air inlet panel. NOTE: Refer to Fastener Notice in Service Precautions.
Install the air inlet panel to wiper motor module screws. Tighten Tighten the air inlet panel to wiper motor module screws to 10 N.m (89 lb in) .
Install the wiper motor.
Install the air inlet grille panel.
Install the wiper arms onto the vehicle.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
My windscreen wipers are not working its not moving but wen i put them on i can hear the moter working, plz help me
Sounds like you need a new winshield wiper motor,if you can hear the motor but the blades wont move try moving them by hand while the motor is going mybe you will get lucky
1helpful
Motor that moves the windshield wiper on the drivers side of our 2000 Ponitica Montana stopped working, I have been told that this part will cost me 300.00 dollars. I can not afford that, can you help me?
If the wiper on the passengers side is working normally and only the drivers side is not working.Then it is not the motor because there is only one motor and it works both sides.What you need to do is remove the drivers side wiper and clean the splines on the wiper transmission and reinstall the wiper and tighten it down.The hardest part is usually getting the wiper off.But if yours is not moving then it should come right off.All you need is a 13mmwrench or socket to remove the nut that holds the wiper on.You can do this yourself and it will cost nothing.The usual problem is they just come loose.Hope this helps.Good luck.
Pontiac montana wiper reterned in up right after
While wipers off in parked position, remove wiper arm and re-position arm to correct stowed position.
Re-tighten any wiper arm attachment nuts/screws etc.
Check wiper attachment arm for damage or cracks at the spigot mount. Replace if damaged.
The winshield wiper on my 2007 Jetta its no
You likely don't need a new motor. You just have to get your wipers repacked with grease.
1helpful
Winshield wipers stick
Had the same problem on my '92 and 97. on the wiper motor there is a front cover held by a center screw... remove the cover there should be a small computer circuit board... disconect and replace... the cards are known to fail and a new replacement part, not a used one. they all fail on the older models.. new one has corrected the issue with the card... hope this works;;
1998 buick regal winsheild wipers will not sit in theoff position wipe winshield one last time comes back up and stops in middle of windshield
Does the wiper still make noise like it is trying to go? If so open the cap where is attached and tighten the nut on the wiper. If does not make noise you will need a wiper motor.
2answers
Winshield wiper
c2e618a.gif2003 > G 2.4 DOHC > Body Electrical System
Top Pontiac Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Pontiac Expert? Answer questions, earn points and help others
