Hi,if you know where the fues box is your half way there.
just buy a electricle screwdriver that has a light inside it with a wire that has got a crockerdile clip on the end,
put the cockerdile clip on a earth the body of the car,
then look at the fues on the top of the fues there is two little bits of metal these are where you will put the screwdriver blade to,
if yoy put the ignition on then go back to the fuesestuch one side of the fues on the little bit of metal the screwdriver should light,This is the power side,now if you tuch the screwdriver on the other bit of metal the light should come on again,if it dose the fues is ok,
if not the fues is falty(replace fues)do this to all the fueses and you will find the fues that is falty.
all the best.
SOURCE: NEEED FUSE FUSE BOX LAYOUT FOR 2003 DODGE GRAND CARAVAN
I'm not sure about the fuse box layout on that model, but I do have a tip for finding fuse related problems. Get a cheap test light and connect the alligator clip to the negative battery terminal. Roll the key to the RUN position ( do not start). Look carefully at the fuses while they are plugged in. You should see a little silver tab on both sides of the top of each fuse. Touch one with the probe of your test light. It should light up. Now touch the other side. If it doesn't light up on both, the fuse is blown. If it doesn't light up on either side, then there is no power getting to the fuse and you'll have to do more digging, but it may be normal. Some circuits are only energized under specific conditions.
SOURCE: Lost Fuse Box Diagram - Altima 2005 2.5L
i need to know what ENG CONT AND ENG MTG means on the fuse box of my 2006 altima.
SOURCE: Fuse box layout for a 2002 VW Cabrio
Fuse colors
30 A-green25 A-white20 A-yellow15 A-blue10 A-red7,5 A-brown5 A-beige3 A-violetFuse locations
Fuse Location
Fuse locations for options not shown can be found in the corresponding wiring diagrams.
Amp.
1-Headlight, Low Beam, Left (56b)102-Headlight, Low Beam, Right (56b)103-License Plate Lights (58) 104-Rear Window Wiper And Washer System155-Windshield Wiper/Washer156-Fresh Air Blower, A/C (X)207-Tail Lights, Right (58R)108-Tail Lights, Left (58L)109-Rear Window Defogger2010-Fog Lights1511-Headlight, High Beam, Left (56a)1012-Headlight, High Beam, Right (56a)1013-Horn (15)1014-Back-Up Lights1015-Engine Electronics (15)1016-Power Sunroof, Front Map/Reading Light1517-Emergency Flashers (15)1018-Fuel Pump (FP), Heated Oxygen Sensor (HO2S) Control Module2019-Coolant Fan, A/C Relay (30)3020-Brake Lights (30)1021-Interior Lights, Clock, Luggage Compartment Light (30)1522-Cigarette Lighter, Radio, Luggage Compartment Release10Separate Fuses
(Located above the relays)
-Fuse for ABS hydraulic pump relay30-Fuse for ABS main relay30-Fuse for A/C30-Fuse for power windows20-Fuse for cruise control5-Fuse for cigarette lighter15In the engine compartment above the brake booster:
-Glow plugs50
Did u ever come across the fuse layout for the 98nissan? I am now in the need for one...
