Question about GE Spacemaker 26976 Cordless Phone
GE Spacemaker Kitchen Phone/Radio/Answering Machine Model 26976 GE 1
I have not had this unit long, and really like it, but suddenly I can't answering the phone when it rings.
I hear it ring, and people leave messages, but I can't get a dial tone or pick up a call. Everything else works fine. When I touch "speaker," I can hear a dial tone, but that's as far as I get. I just bought a new battery, even though the unit is only several months old, and so far that does not seem to solve the problem. The red light is on, indicating the battery is charging, but I still have the above-mentioned problems.
My phone company has been here and there are no problems with the phone line.
Any suggestions? Can I buy a replacement phone? Thanks so much for answering this email.
Posted by mmm60 on
  • davemallary Dec 04, 2018
    Did you find an answer to your question? My phone is very old, but it has the same model number and the same exact problem.
ray gallant
    Top Expert:
  • GE Master
  • 69,326 Answers
I would pack it and send it to GE for repair replacement as defective
Posted on Mar 23, 2017
5 Related Answers
Anonymous
  • 201 Answers
SOURCE: brand new cordless handset -- no dial tone, no ring!
I doubt it's the battery. As I understand it the base works fine and the problem is only with a cordless phone. Are you using an external charger stand for the cordless handset? These phones need to be registered to the base unit. That is usually done by installing the cordless phone in the base unit but you may need to do that shortly after insalling the battery or you could have a register button or setting.
Posted on Jul 07, 2007
Anonymous
  • 84 Answers
SOURCE: changing the number of rings to answer on our Model 28112 GE Cordless phone
the voicemail ring count has to be setup on your phone line thru your voicemail menu,and has nothing to do with the answering machine. if you don't want the answering machine to pickup, just shut it off. follow the prompt's for your voicemail settings, there you'll be able to set the amount of rings you want.
hope this helps.
wg
Posted on Feb 14, 2008
Anonymous
  • 4 Answers
SOURCE: No dial tone
It seems you can receive the calls and dial the numbers, by clicking hand free key you will hear the tone. Regarding answering machine I wonder you activate it or not for activating the machine just click the On/Off key on the base or from the main menu on the hand set choose Voice Mail section then activate Answering Machine, in this section you have other options such as Ring Delay (for choosing the delay before Ans.Mach. pick up the phone), Announcements (playing and recording announcements) and Massage Length. Reza from Iran
Posted on Oct 11, 2008
Anonymous
  • 10 Answers
SOURCE: no dialtone
If you use Dsl as a internet provider make sure you have the filters on each phone. If you use cablevision and have a wireless connection make sure you chage the phone to a 5.2ghz because you might have the wireless router with the same ghz causing a coflict. This will also create loss. of internet connections then you use the phone
Posted on Jan 19, 2009
Anonymous
SOURCE: Storing Speed Dial Phone Nmbers
Emergency/quick dial numbers: Pick up handset, push store, enter the phone number (it will not call the number), push store again, Push A,B or C. hand up handset. Frequently called numbers, pick up the handset, push store, enter the phone number, push store again, push key pad 1, or 2, etc. for memory location. Hang up handset. How to change a stored number. just repeat the sequence. How to clear a stored number, repeat the storage skip step 3 (do not enter the phone number). How to correct an error while storing, just hang up and repeat.
Posted on Jun 06, 2009
Had a power outage during a lighting storm and now the GE spacemaker phone/unit does not work; it's showing in the display screen "Initializing". The phone works, but when you press any of...
Does it have a battery backup? If so, after disconnecting the AC power adapter, remove the battery for 15 minutes, then re-insert it (make sure it is a good battery), plug the AC adapter back in, and try again. Hopefully, this will re-set it. If not, it probably isn't worth tryiing to repair. May have to buy a new phone.
May 06, 2017 | GE Spacemaker 26976 Cordless Phone
Tip
GE Digital Messaging System / Answering Machine...
GE branded Consumer Electronics are now sold by Thomson Consumer Electronics, Inc. Please call Thomson at 1-800-447-1700 for electronics product support. Or go to website and choose your product. Product page offers Product Spec Sheet or Instruction Book for download in pdf file format.
http://www.home-electronics.net/ge/pc/viewCategories.asp?idCategory=5
Consumer Electronics include:
Answering Machine Cordless Phone Answering System Spacemaker Radio Audio Products Spacemaker Telephone Caller ID Box Spacemaker TV Camcorder Speaker Phone Cassette Recorder Telephone CD Player Television Clock Radio Video Camera
Your welcome !! ;-)
on Feb 01, 2008 | GE Telephone pr521w
Hi-Our GE spacemaker phone will no longer record messages when someone attempts to leave a message. The phone will just ring and never attempt to record. It was working fine for until recently. We have...
Apparently you have the answering machine turned off.
When speakerphone is OFF (not in TALK mode), press flash/program button and CID VOL(+) / CID VOL(-) arrow keys to move the pointer > to point at ANSWER ON/OFF, press flash/program button to show SET ANSWERER ON OFF.
Use the CID VOL(+) / CID VOL(-) arrow keys to select ON.
If you need one, you can download the manual here.
Feb 09, 2011 | GE Spacemaker 26976 Cordless Phone
How to retrieve messages when not at home? Model 26976GE 1A
REMOTE ACCESS
This section explains the remote access process for use with any touchtone
phone.
1. Dial the phone number for the answering machine.
2. After the answering system answers, press any numbered key on the
touch-tone pad to bypass the outgoing announcement, or wait until
the announcement finishes.
3. Enter the security code after you hear the tone.
4. Follow the voice menu to use the answering machine's remote functions.
The remote feature enables you to perform the following functions:
To Press this button
Review message 1
Play back messages 2
Stop message play back 2
Erase message 0
(during message playback)
Skip message 3
Turn off/on answerer 4
Review voice menu options 7
No valid dialing tones for 15 seconds will hang up the telephone line.
You can get the manual on the link below if you need page 31.
http://www.home-electronics.net/USER-GUIDES/26976_DOM_ES_CL_IB.pdf
Good luck
Dec 04, 2010 | GE Spacemaker 26976 Cordless Phone
The hand set has no dial tone. Also the display turns off and the phone beeps once shortly after the "Talk" button is pushed. I replaced the battery but still get the same results. Do I need a new handset...
Unplugged wall unit from the 110 volt outlet and the phone line from the unit for about 10 or more minutes. The phone worked after the phone line was reconnected and the wall unit plugged back in.
Dont know which solved the problem but I suspect it might have been unpluging from the 110 which could have reset the wall unit.
Oct 26, 2009 | GE Spacemaker 26976 Cordless Phone
Answering machine is suddenly speaking spanish
I have had this same problem, for about the same amount of time... I cant stand it!! Okay, here is the solution.. Press and hold the Skip button, on the base of the answering machine, for two seconds.. TA DAH!! all better. lol...
Take Care!
Jamie Nelson.
Gig Harbor, Washington. U.S.A.
Feb 12, 2009 | Uniden Cordless Phone
Need to shorten the amount of rings before it answers.
http://www.home-electronics.net/ge/pc/IB/27851GE1_IB.pdf
Dec 09, 2008 | GE 28112EE2 Digital Answering Machine
My answering system and my instructions are all in won't pick up
is the incoming phone line plugged into the answering machine directly? the answering machine should then be plugged into the phone. the signal comes through the answering machine then to the phone. you may have the connections reversed on the answering machine. check those connections.
Nov 26, 2008 | GE 27831 2.4 GHz Twin Cordless Phone
Instructions
Hi. I just bought one of these phones and wanted more information than what the manual offered, so I went to the GE website to see what they had. Below I put what I found, maybe it can help you. Click on the blue box that towards the bottom left for the manual for download.
After the link, I also put extra information tabout this phone that helped me find the manual for you- it wasnt easy to find. OK, best of luck.
http://www.home-electronics.net/ge/pc/viewPrd.asp?idcategory=0&idproduct=89
GE Home Electronics In 1987 GE sold its home electronics business to Thomson®, Inc. For a time, Thomson® produced many products that carried the GE name, but now only manufactures telephone and communications products.
The items that they support but no longer manufacture include:
Audio products
Camcorder
Cassette recorder
CD player
Clock radio
Spacemaker radio
Spacemaker TV
Television
Video camera
For assistance with any of these older products or your current GE telephone products
please call 1-800-447-1700 in the US.
In Canada, call 1-800-522-0338 (English)
or 1-800-522-0445 (French).
Thomson, Inc.
PO Box 671988
Marietta, GA 30006-0034
For more information about the Thomson® line of GE brand telephone products, visit Thomson® at www.ge.com/phones.
These products include:
Answering machine
Answering system
Caller ID box
Cordless phone
Speaker phone
Spacemaker telephone
Oct 14, 2008 | GE 25922 Cordless Phone
GE Spacemaker 26976 Cordless Phone Logo
1,066 people viewed this question
Top GE Lands Phones Experts
Bruce Robin
Marvin
Marvin
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
