Cars & Trucks Logo
Posted on Aug 02, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Transmission locked up, felt like it was stuck in second or third gear. not shifting. shut engine off and restarted , shifting properly now. what causes this.
  • decandL159 Aug 11, 2008
    Thanks for the info.
    I put 1,000 miles on the car since it occurred and even tried to force it to happen again with no success. I commute 120 miles a day and the car is operating normally.
    Thanks again
  • Anonymous Oct 08, 2008
    odometer stopped working as far as keeping speed then went to drive it as well and the automatic guire shift didn't seem to want to shift and sounded better when I put it into second then as to manually shift the car I shifted to D and only occasionally sounds smooth after which, also battery wont hold a charge at all and have changed it.
Anonymous
Level 3:
  • Master 1,586 Answers
  • Posted on Aug 02, 2008
Anonymous
Master
Level 3:
Answers
1586
Questions
0
Helped
820781
Points
5018
It was a temporary fault that put the car into limp mode (a safeguard operating condition designed to protect the transmission in case of serious failure). Sometimes a transient fault can occur, and the car goes into limp mode just to be sure it's not for real. Shutting off and restarting the car is the usual way to clear the fault and return the car to normal operation - if the problem was real, the car would've stayed in limp mode after restart, or gone into limp once you started driving again. I wouldn't sweat this one, since it went right back to normal operation.
What will make my 05 Dodge Magnum shift the first to second then go into third and it hit reverse
There could be several reasons why your 2005 Dodge Magnum is experiencing problems with shifting from second to third gear and then suddenly hitting reverse, including:
  1. Transmission Fluid Level: Low transmission fluid level can cause erratic shifting, slipping, or stalling in your vehicle. Make sure to check your transmission fluid level and add if necessary.
  2. Shift Solenoid: A faulty shift solenoid can cause problems with shifting in your transmission. The solenoids control the flow of transmission fluid through the valve body, which controls the shifting of gears. If the shift solenoid is failing or has failed, it can cause the transmission to slip, shift erratically, or get stuck in a gear.
  3. Transmission Pump: The transmission pump is responsible for pumping transmission fluid through the transmission and to the torque converter. If the pump is failing, it may not be able to pump fluid properly, leading to problems with shifting and slippage.
  4. Valve Body: The valve body controls the flow of transmission fluid through the transmission and directs the shifting of gears. If the valve body is failing, it can cause the transmission to shift erratically or get stuck in a gear.
  5. Transmission Control Module (TCM): The TCM is responsible for controlling the transmission's shifting and overall performance. If the TCM is failing, it can cause the transmission to shift erratically or get stuck in a gear.
It's best to have a qualified mechanic diagnose and repair the issue as they will have the necessary tools and expertise to properly diagnose and fix the issue.
96 3.3 won't shift into 3rd
Standard transmission? Could be one of two possibilities. 1) third gear synchro is worn out. If so you might be able to get it into gear by matching the engine speed to the the proper speed for that gear. 2) possibly there is a worn bushing in the shift linkage. The first one is a lot more expensive, you should probably get the whole transmission rebuilt if 1 is diagnosed. I would find a good transmission guy. I wouldn't think the third gear synchro would go first, more likely second but if someone rested their hand on the shifter while the transmission was in third a lot it would wear it out. Good luck.
Can't shift my 1995 Mazda MVP out of park and the wheel is not locked and the key will not come out.
For gear shift issues and gear stuck issues,the help links are provided below. Click the link below to go through troubleshooting procedure:---- ---- Car will not move when in gear?
http://repairhelpcenter.blogspot.in/2012/02/car-will-not-move-when-in-gear.html ---- transmission sticks in first gear? http://technoanswers.blogspot.com/2012/01/mercedes-benz-transmission-sticks-in.html ----- Transmission not engaging in first gear? http://technoanswers.blogspot.com/2012/01/mercedes-benz-not-engaging-in-first.html ----- Vehicle only goes in First gear?
http://howtobyme.blogspot.com/2011/11/chrysler-pt-cruiser-only-goes-in-first.html
Car is stuck in park and the shift will not move?
http://howtobyme.blogspot.com/2011/08/car-is-stuck-in-park-and-shift-will-not.html
---- Engine will not go out of park mode? http://technoanswers.blogspot.in/2012/02/2002-nissan-sentra-will-not-go-out-of.html ---- Car stuck in park? http://technoanswers.blogspot.in/2012/02/nissan-sentra-stuck-in-park.html ----- Car will not come out of Park?
http://howtobyme.blogspot.com/2011/11/car-will-not-come-out-of-park.html
Automatic transmission will not go into high gear?
http://howtobyme.blogspot.com/2011/11/automatic-transmission-will-not-go-into.html
--- Car wont downshift sometimes?
http://schematicsdiagram.blogspot.com/2011/12/car-wont-downshift-sometimes.html
---- Transmission will shift into drive?
http://schematicsdiagram.blogspot.com/2011/12/buick-park-avenuetransmission-will.html
----- Auto wont shift from park? http://schematicsdiagram.blogspot.com/2011/12/ford-taurus-wont-shift-from-park.html ---- Car Transmission will not go into Park mode?
http://schematicsdiagram.blogspot.com/2011/12/car-transmission-will-no-go-into-park.html
----- Shift indicator directly goes to 2nd when key is turned ON?
http://schematicsdiagram.blogspot.com/2011/12/shift-indicator-directly-goes-to-2nd.html
---- Third gear missing and engine losing power?
http://schematicsdiagram.blogspot.com/2012/01/third-gear-missing-and-engine-losing.html
------- Vehicle has whining sound in gear?
http://technoanswers.blogspot.com/2012/01/chevrolet-silverado-has-whining-sound.html
----- Hard to shift gears on Manual transmission?
http://technoanswers.blogspot.com/2012/01/hard-to-shift-gears-on-manual.html
------ Car hard shift at slow speeds?
http://technoanswers.blogspot.com/2012/01/car-hard-shift-at-slow-speeds.html
--- Automatic transmission shift lever hard to move on cold mornings?
http://technoanswers.blogspot.com/2012/01/automatic-transmission-shift-lever-hard.html
------ Gear shifts hard?
http://schematicsdiagram.blogspot.in/2012/02/2000-nissan-maxima-shifts-hard.html
------- Vehicle noticed sluggish delayed shifts while driving?
http://schematicsdiagram.blogspot.in/2012/03/vehicle-noticed-sluggish-delayed-shifts.html
This will help.
Thanks.
FOR MORE HELP GO TO: ---
Car repair guide? http://technoanswers.blogspot.in/2012/03/car-repair-guide.html
I have a Toyota Corolla AE 100 manual gear shift gets stuck
why my 2006 corolla car gearbox is stuck in third gear and cannot move
1helpful
When it shift from third gear to second gear it makes an abrupt shift. This problem is only from third to second gear, the other gears shift nice and quiet. The transmission is new only 3 months old.
Hopefully this Transmission is still under warranty?
If its a stick the shifter or schronizers could be the culprit. If the vehicle is an automatic,shift solenoid, shifter, problems in 2nd and 3rd circuitry (band or clutch not releasing properly ),manual shift valve .
Take it back to whom ever did the rebuild or transmission work tell them the problem .
Business is so demanding these days they will probably do the right thing.
The transmission is not shifting properly. It seems to be stuck in 2nd or third gear. I cannot shift it manually. The shift indicator light on the steering column does not indicate what gear I'm in. I have...
I think that the rod that connect to the transmission needs
some adjustment if it is stuck on 2, then you need to loosen the screw and adjust the transmission by hand set it to PARK and
then your stick shift you set it in PARK the rod should be connected to the transmission you tighten the screw and your
DONE....
NO SECOND GEAR IN TRANNY
sounds like what happened to my camaro. it sounds like a stuck valve. i suggest taking it in for an estimate at a transmission specialist.
When the engine gets warm the transmission doesn't shift properly
have you replaced the fluid and filter? sometimes if the filter is clogged all of the fluid will stay on top of it instead of settling back into the pan. so when you run it it stays on top then you shut it off and it will slowly drain back to the bottom so its good for a little while until all the fluid is stuck over the filter again.
Top Mercury Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Mercury Expert? Answer questions, earn points and help others
